explain what you are trying to do,
I want bitnami wordpress to run over HTTPS thru caddy -
show what you have already tried,
sub.example.com {
proxy / ipaddress:81 {
insecure_skip_verify
except /map.xml /robots.txt
include error messages and log output,
on chrome console: error mixed content. https page request http, request blocked.
so despite the website itself accessible from HTTPS, the layout etc are broken because it keeps requesting CSS etc from HTTP.
how to fix this? maybe i can tell caddy to force rewrite all http to https?
thankyou
EDIT
when i use
sub.example.com {
proxy / ipaddress:444 {
chrome give error
Bad Request
Your browser sent a request that this server could not understand.
Reason: You’re speaking plain HTTP to an SSL-enabled server port.
Instead use the HTTPS scheme to access this URL, please.
EDIT
this Caddy behind caddy, serving mixed content · Issue #1033 · caddyserver/caddy · GitHub
explains that wordpress doesnt correctly handle https (the last reply). it seems he then fixed the problem but didnt share the solution. bummer
EDIT
i installed HTTPS Redirection plugin, and tell it to force anything including static contents thru https.
now the website it works, but it still have broken mixed content because it still asks resources from external sites (e.g. GRAVATAR) thru http instead of HTTPS.
i think i really need to know how to force rewrite http to https thru caddy
