caddy.service file (not API)
or
caddy start/stop/reload
Raspberry Pi (Raspbian Buster Lite)
caddy start --config <path to file>
caddy reload --config <path to file>
N/A
mydomain.duckdns.org {
output file /var/log/caddy/portainer.log
format console
@internal {
remote_ip 192.168.0.0/16
handle @internal {
reverse_proxy 127.0.0.1:9000
respond 403
jellyfin.mydomain.duckdns.org {
output file /var/log/caddy/jellyfin.log
format console
reverse_proxy 127.0.0.1:8096
omv.mydomain.duckdns.org {
output file /var/log/caddy/omv.log
format console
reverse_proxy 127.0.0.1:81
nas.mydomain.duckdns.org {
output file /var/log/caddy/nas.log
format console
root * /srv/dev-disk-by-label-HomeDrive/
@noAccess {
not path */RESTRICTED/*
file_server @noAccess browse {
hide RESTRICTED Games "TV SHOWS"
basicauth {
username (hashbrown64)
@iPhone {
not remote_ip xxx.xxx.xxx.xxx
respond @iPhone 403
3. The problem Iām having:
I am trying to figure out the secret recipe for hiding files properly in Caddy v2. I understand that folders/files can be denied by using a ānamed matcherā with ānot pathā and calling that out in the file_server directive which I am using for my āRESTRICTEDā folder.
Using that method is great but any user can still see the folder (although access is denied) and I would like to have it invisible to all as well as denying permission.
I have tried many variations of using the hide module and it does work very well. My problem is I canāt figure out how to make it only hide one instance of a named folder and not all of them.
As you see in my caddyfile I have one folder with not path and then I also hid that folder along with another called Games and one called āTV SHOWSā.
@noAccess {
It does exactly what I want it to do except all of my Games folders in every directory are hidden. I only want to hide one Games folder and thatās the one in ā¦Arcade/Games
I have tried all of these:
hide RESTRICTED /srv/dev-disk-by-label-HomeDrive/Arcade/Games "TV SHOWS"
hide RESTRICTED */srv/dev-disk-by-label-HomeDrive/Arcade/Games "TV SHOWS"
hide RESTRICTED */srv/dev-disk-by-label-HomeDrive/Arcade/Games*
hide RESTRICTED */Arcade/Games "TV SHOWS"
hide RESTRICTED /Arcade/Games "TV SHOWS"
hide RESTRICTED /Arcade/Games* "TV SHOWS"
hide RESTRICTED */Arcade/Games/* "TV SHOWS"
And probably a few other things. I have also separated the hidden folders with a semi-colon which works but still doesnāt allow me to hide just one directory. i.e. hide RESTRICTED ; Games ; "TV SHOWS"
Iām sure thereās a way to get the desired results but I just canāt crack the code.
Any help would be greatly appreciated.
