Help converting nginx rewrite rules to caddyfile
Hi,I have some trouble, please help converting nginx rewrite rules to caddyfile , thanks
location / {
            try_files $uri $uri/ /index.php$is_args$args;
You can use rewrite.
I think that might be looks like this:
rewrite {
    to /index.php{uri}
Yep, but you’ll also want to try the files on disk first, though:
rewrite {
  to {path} {path}/ /index.php{uri}
