Howdy. I’m working on installing Kirby CMS on my web server. I’ve got the server itself up and running, and Kirby semi-works, but it needs its rewrite rules to actually do anything.
Here’s the relevant .htaccess section:
<IfModule mod_rewrite.c>
# enable awesome urls. i.e.:
# http://yourdomain.com/about-us/team
RewriteEngine on
# make sure to set the RewriteBase correctly
# if you are running the site in a subfolder.
# Otherwise links or the entire site will break.
# If your homepage is http://yourdomain.com/mysite
# Set the RewriteBase to:
# RewriteBase /mysite
# block text files in the content folder from being accessed directly
RewriteRule ^content/(.*)\.(txt|md|mdown)$ index.php [L]
# block all files in the site folder from being accessed directly
# except for requests to plugin assets files
#RewriteRule ^assets/plugins/([a-zA-Z0-9\.\-_%=]+)/(.*)$ site/plugins/$1/assets/$2 [L,N]
#RewriteCond $1 !^plugins/[a-zA-Z0-9\.\-_%=]+/assets/.*
RewriteRule ^site/(.*) index.php [L]
# block all files in the kirby folder from being accessed directly
RewriteRule ^kirby/(.*) index.php [L]
# make panel links work
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule ^panel/(.*) panel/index.php [L]
# make site links work
RewriteRule ^(.*) index.php [L]
</IfModule>
Any assistance here is appreciated. Bonus if I can add additional directories to which it’d allow access for listings, as the CMS isn’t all I use the server for.
Would you mind sharing your current Caddyfile? PHP files being delivered as text sounds like you’ve possibly got a mistake in your fastcgi directive.
That rewrite looks good, but could use some additions, I gave it a shot:
# security
rewrite {
if_op or
if {file} ends_with .txt
if {file} ends_with .md
if {file} ends_with .mdown
if {uri} starts_with /site/
if {uri} starts_with /kirby/
to /index.php
rewrite /panel {
to /panel/index.php
rewrite {
to {path} {path}/ /index.php
I’d been screwing around with it earlier, hence the commented parts. It’d either serve up a 404 or PHP depending on what I did. The root index.php seems to load/execute correctly.
[IP] {
root /var/www/pinopsida.com
log /var/log/caddy/pinopsida.com.access.log
errors /var/log/caddy/pinopsida.com.errors.log
fastcgi / 127.0.0.1:9000 php
gzip
rewrite / /index.php{uri}
# rewrite {
# r ^content/(.*)\.(txt|md|mdown)$
# to index.php
# rewrite {
# r ^site/(.*)
# to index.php
rewrite /panel {
# r ^panel/(.*)
to {path} {path}/ /panel/index.php
# rewrite {
# r ^(.*)
# to {path} {path}/ index.php
Honestly, apart from a few small things, that Caddyfile looks pretty good to me.
rewrite / /index.php{uri} worries me. I don’t know for sure if ordering matters, but I’d move it down to the bottom of the caddyfile and change the rewrite to {path} {path}/ /index.php. Nothing appends the URI to the index in that .htaccess file, so I wouldn’t do it here.
Do you get any error logs when Caddy serves up the panel index.php?
I replaced my rewrites with yours, and it works almost completely, but now it seems to be throwing 500s on the CSS; one URL in question is http://[IP]/panel/assets/css/form.min.css?v=2.4.0
There’s no output to caddy’s error log, nor to php-fpm’s.
Ahh, I didn’t know the site would be serving css out of the /panel subfolder. This should solve those 500s (which will be the result of the css request being rewritten to the php file):
# security
rewrite {
if_op or
to /index.php
rewrite /panel {
rewrite {
