Help: cache, ratelimit, forward auth, conditional upstreams
I am trying to migrate an API frontend from nginx to Caddy.
The nginx is rather convoluted, but does almost everything it needs to do, except shared cache. After unsuccessfully trying the memcached (no ttl) and redis (strange behaviour) I decide to at least try to do this with caddy. I do have a bit of experience with caddy, but I ran into issues this time and I’d really could use a bit of help.
The configuration should do the following:
  • direct the requests to the correct api instances, depending if the request is public or not: there are two instances: pubapi and api
  • pre-authenticate the requests before hitting the cache if the the request use basic auth AND is supposed to be cached - this is to make sure private cache objects are not accessed by unauthorized requests
  • enable cache for some endpoints
I am using the argsort module to make sure the identical requests get a single key.
I am using @matt 's caddy-ratelimit module and @darkweak 's darkweak/souin module with the go-redis storage.
Issues I still have:
  • mode bypass seems to not work unless I am also drop the Cache-Control and Expires headers coming from the API (yes, the API is not the best API out there)
  • I would really want to cache just the responses with status code 200 but that seems to be impossible at the moment; if @darkweak confirms that is the case, I will open an issue in the proper github repo.
  • the forward_auth does not prevent by itself the access to the cache or the backend if the response from the auth backend is not 2xxx
mode_bypass not working. It will start cache once i drop Cache-Control and Expires from upstream.
{"level":"debug","ts":"2024-10-27T16:18:39.572Z","logger":"http.handlers.cache","msg":"You're running Souin with the following storages REDIS"}
{"level":"debug","ts":"2024-10-27T16:18:39.572Z","logger":"http.handlers.cache","msg":"Storer initialized: []types.Storer{(*redis.Redis)(0xc001d8a680)}."}
{"level":"debug","ts":"2024-10-27T16:18:39.572Z","logger":"http.handlers.cache","msg":"Try to load the storer REDIS-redis:6379--12-souin-redis-1m0s as surrogate backend"}
{"level":"debug","ts":"2024-10-27T16:18:39.572Z","logger":"http.handlers.cache","msg":"Surrogate storage initialized."}
{"level":"debug","ts":"2024-10-27T16:18:39.572Z","logger":"http.handlers.cache","msg":"Set zacache as Cache-Status name"}
{"level":"debug","ts":"2024-10-27T16:18:39.572Z","logger":"http.handlers.cache","msg":"Allow 2 method(s). [GET HEAD]."}
{"level":"debug","ts":"2024-10-27T16:18:39.572Z","logger":"http.handlers.cache","msg":"The cache logic will run as bypass: &{Strict:false Bypass_request:true Bypass_response:true}"}
{"level":"info","ts":"2024-10-27T16:18:39.572Z","logger":"http.handlers.cache","msg":"Set backend timeout to 10s"}
{"level":"info","ts":"2024-10-27T16:18:39.572Z","logger":"http.handlers.cache","msg":"Set cache timeout to 10s"}
{"level":"info","ts":"2024-10-27T16:18:39.572Z","logger":"http.handlers.cache","msg":"Souin configuration is now loaded."}
{"level":"debug","ts":"2024-10-27T16:18:39.577Z","logger":"http.handlers.cache","msg":"Cleanup..."}
{"level":"debug","ts":"2024-10-27T16:19:39.443Z","logger":"http.handlers.cache","msg":"Incomming request &{Method:GET URL:/v2/public/test2 Proto:HTTP/1.1 ProtoMajor:1 ProtoMinor:1 Header:map[Accept:[*/*] Accept-Encoding:[gzip] User-Agent:[curl/8.7.1] X-Forwarded-For:[xx.xx.xx.xx] X-Forwarded-Host:[some.host] X-Forwarded-Proto:[https]] Body:0xc0000104b0 GetBody:<nil> ContentLength:0 TransferEncoding:[] Close:false Host:some.host Form:map[] PostForm:map[] MultipartForm:<nil> Trailer:map[] RemoteAddr:10.100.254.16:37774 RequestURI:/v2/public/test2 TLS:<nil> Cancel:<nil> Response:<nil> ctx:0xc000d64600 pat:<nil> matches:[] otherValues:map[]}"}
{"level":"debug","ts":"2024-10-27T16:19:39.444Z","logger":"http.handlers.cache","msg":"Request cache-control &{MaxAge:-1 MaxStale:-1 MaxStaleSet:false MinFresh:-1 NoCache:false NoStore:false NoTransform:false OnlyIfCached:false StaleIfError:0 Extensions:[]}"}
{"level":"debug","ts":"2024-10-27T16:19:39.451Z","logger":"http.handlers.cache","msg":"Request the upstream server"}
{"level":"debug","ts":"2024-10-27T16:19:40.020Z","logger":"http.handlers.cache","msg":"Response cache-control &{MustRevalidate:false NoCache:map[] NoCachePresent:false NoStore:true NoTransform:false Public:false Private:map[] PrivatePresent:false ProxyRevalidate:false MaxAge:-1 SMaxAge:-1 Immutable:false StaleIfError:-1 StaleWhileRevalidate:-1 Extensions:[]}"}
/etc/caddy # caddy version
/etc/caddy # caddy build-info | grep souin
dep     github.com/darkweak/souin       v1.7.2  h1:i9t/fdCgvBuKM7NNYcqnCQCmFlk9nEF91ltuksfFyjs=
dep     github.com/darkweak/souin/plugins/caddy v1.7.2  h1:EVYHOcRsr3XnM45RiGKATogk3qy1/cH8rVR8p+BDe14=
/etc/caddy # caddy build-info | grep redis
dep     github.com/darkweak/storages/go-redis   v0.0.10 h1:lwUwcLB1LlO7NFC/tPB/8IOOAHbkJjvE9VFVi+DcmiE=
dep     github.com/darkweak/storages/go-redis/caddy     v0.0.10 h1:iHtq111uKyGXFvN+OrL5x0pR3bf7BcBqXt9dVRWwA2Q=
dep     github.com/redis/go-redis/v9    v9.5.4  h1:vOFYDKKVgrI5u++QvnMT7DksSMYg7Aw/Np4vLJLKLwY=
/etc/caddy # caddy build-info | grep rate
dep     github.com/mholt/caddy-ratelimit        v0.0.0-20240828171918-12435ecef5db      h1:30N0UnATYd7E8iaWSSOTlsr2/rd8v+7w0X+2Jc8FDJk=
docker and docker-compose
standard docker image build with xcaddy, run with docker-compose
caddy run --config /etc/caddy/Caddyfile
  web:
    command:
      - caddy
      - run
      - --config
      - /etc/caddy/Caddyfile
    build: .
    restart: always
Dockerfile:
ARG VERSION=%%VERSION%%
ARG VCS_URL
ARG VCS_REF
ARG BUILD_DATE
ARG TARGETPLATFORM
ARG TARGETOS
ARG TARGETARCH
FROM caddy:${VERSION}-builder AS builder
RUN CGO_ENABLED=0 GOARCH=${TARGETARCH} GOOS=${TARGETOS} \
    xcaddy build \
    --with github.com/greenpau/caddy-security \
    --with github.com/lucaslorentz/caddy-docker-proxy/v2 \
    --with github.com/teodorescuserban/caddy-argsort \
    --with github.com/teodorescuserban/caddy-cookieflag \
    --with github.com/teodorescuserban/caddy-ip-map \
    --with github.com/mholt/caddy-ratelimit \
    --with github.com/darkweak/storages/go-redis/caddy \
    --with github.com/darkweak/souin/plugins/caddy
#    --with github.com/caddyserver/cache-handler
# FROM caddy:${VERSION}-alpine
FROM alpine:3.20
ENV XDG_CONFIG_HOME=/config XDG_DATA_HOME=/data
WORKDIR /etc/caddy
COPY etc ./
RUN apk add nss-tools curl && \
    rm -rf /var/cache/apk/*
# CMD ["caddy", "docker-proxy", "--caddyfile-path", "/etc/caddy/Caddyfile"]
CMD ["caddy","run","--config","/etc/caddy/Caddyfile","--adapter","caddyfile"]
# to be able to tunnel into the admin api to grab profiles
#EXPOSE 12019
		output file /logs/main.log
		format json {
			time_format iso8601
		level debug
	local_certs
	auto_https disable_redirects
	# lets rate limit before cache, we have no idea if that's cached or not
	order rate_limit before cache
	import ./include/cache.caddyfile
import ./include/snippets.caddyfile
	argsort lowercase
	import ./include/ratelimit.caddyfile
	map {http.request.uri} {is_public_url} {
		default 0
		"~^/v1/public*" 1
		"~^/v2/public*" 1
	map {http.request.uri} {needs_cache} {needs_subrequest} {
		default 0 0
		"~^/v2/public/Summary" 1 0
		"~^/v1/public/Show" 1 0
		"~^/v1/fbs/flow/custom-search" 1 1
		"~^/v2/fbs/org" 1 1
		"~^/v1/fbs/flow/usage-years/org/[0-9]+" 1 1
	map {http.request.header} {auth_type} {
		default none
		"~^Bearer .*" bearer
		"~^Basic .*" basic
	@needs_foward_auth expression `{needs_subrequest} == "1"`
	# until devs will expect X-Forwarded-Uri instead of X-Original-URI,
	# we'll do with the expanded version
	# forward_auth @needs_foward_auth pubapi:3000 {
	# 	uri /internal/basicAuthCheck
	#  	copy_headers Authorization
	reverse_proxy @needs_foward_auth pubapi:3000 {
		method GET
		rewrite * /internal/basicAuthCheck
		header_up X-Forwarded-Method {method}
		header_up X-Forwarded-Uri {uri}
		# that needs to go
		header_up X-Original-Uri {uri}
		@good status 2xx
		handle_response @good {
			request_header {
				Authorization {rp.header.authorization}
	@needs_cache expression `{needs_cache} == "1"`
	cache @needs_cache
	@go_public expression `{auth_type} == "none" || {auth_type} == "special"`
	import logs pubapi
	handle @go_public {
		import gotobackend pubapi:3000
	import logs api
		import gotobackend api:3000
/etc/caddy/include/snippet.caddyfile:
(logs) {
		output file /logs/{args[0]}
		format filter {
			wrap json {
				time_format iso8601
			fields {
				common_log delete
				request>headers>Authorization delete
(gotobackend) {
	header X-Backend {args[0]}
	header Server "{http.request.host}"
	# mode bypass seems to not work
	@remove_cache_headers expression `{needs_cache} == "1"`
	reverse_proxy @remove_cache_headers {
		header_down -Server
		#header_down -Surrogate-Control
		header_down -Cache-Control
		header_down -Expires
		to {args[0]}
	reverse_proxy {
		header_down -Server
		to {args[0]}
/etc/caddy/include/cache.caddyfile:
cache {
	cache_name zacache
	# allowed_http_verbs GET HEAD
	api {
		prometheus
		souin
	log_level debug
	# see https://github.com/darkweak/souin/issues/345#issuecomment-1560574770
	mode bypass
	ttl 15s
	stale 60s
	timeout {
		backend 10s
		cache 100ms
	default_cache_control public
	key {
		template {http.request.uri}
		hash
	redis {
		configuration {
			Addrs redis:6379
			DB 12
/etc/caddy/include/ratelimit.caddyfile:
# add here any naughty IP.
ipmap {http.request.remote.host} 	{is_bad_ip} {
	default 						0
	1.1.1.1						    1
# add here any referrer that would need a higher rate limit than the rest.
map {http.request.header.Referer} 	{is_our_app} {
	default 						0
	"https://fbs.example.local/"	1
# ipmap {http.request.remote.host} {is_our_ip} {
ipmap {remote_ip} {is_our_ip} {
	default 0
	127.0.0.1 1
	10.0.0.0/8 1
rate_limit {
	log_key
	zone bad_ip {
		match expression `{is_bad_ip} == "1"`
		key {remote_host}
		events 1
		window 5s
	zone our_ip {
		match expression `{is_our_ip} == "1"`
		key {remote_host}
		events 4
		window 1s
	zone our_app {
		match expression `{is_our_app} == "1"`
		key {remote_host}
		events 5
		window 1s
	zone unknown_source {
		match expression `{is_bad_ip} == "0" && {is_our_ip} == "0" && {is_our_app} == "0"`
		key {remote_host}
		events 1
		window 3s
The rate limit works really well, I only had to order rate_limit before cache. I was surprised by how good it works, despite a much simpler interface than what I am used to coming from nginx.
The caching seems to work really well with redis although:
  • mode bypass seem to not work; the API really wants to send out Expires: 0 and a ridiculous Cache-Control: no-store, no-cache, must-revalidate, proxy-revalidate and without dropping manually the two headers there is no cache (and I dont see anything specific in the debug log saying “I dont cache because…”)
  • it is caching almost all responses with the default ttl, including some staus codes it shouldn’t, according to the code I’ve seen here, like 429 generated by the rate llimit;
  • the forward_auth does not prevent the request returning 403 if the authentication is incorrect, instead unauthorized users can access private cache objects created by authenticated users
I hope I did not forget anything.
@matt @francislavoie @darkweak, I am very grateful for all the work you did on caddy and on various modules.
I would really appreciate if you take a look and provide some ideas.
I think this is a directive order issue. cache sets itself to be ordered before rewrite which means it always runs before any forward_auth stuff (and also you’re not using forward_auth which further changes the directive order to use reverse_proxy’s order). You’ll need to wrap them up in a route or something to control the order it runs in.
Alright, will try. But does it looks ok to you? I feel it’s missing some ‘respond “denied” 403’?
That’s what error does. It’s a directive that triggers an error.
Thank you for your suggestion, @francislavoie, it looks like using routes did the trick!
It looks like the config below works well.
I should probably add the rate limit inside the routes as well to make sure the expanded forward_auth doesn’t run before the rate limit.
I could probably have a snippet to be imported in the two routes, snipet that has the forward_auth, cache and rev proxy.
The only functional issue remaining seems to be that everything is being logged to the api.log file and nothing to pubapi.log file.
It looks like I cannot include the log directive in route or in handle, nor can I use a @matcher or map variable for the log. Any ideas? :\
	argsort lowercase
		default 0
		"~^/v1/public*" 1
		"~^/v2/public*" 1
		default 0 0
		"~^/v1/public/fbs/flow" 1 0
		"~^/v2/public/planS" 1 0
		"~^/v1/fbs/fgow/custom-search" 1 1
		"~^/v2/fbs/sorg" 1 1
		default none
		"~^Basic .*" basic
		"~^Basic dGVzdD.*" special
	@go_private expression `{auth_type} == "bearer" || {auth_type} == "basic"`
	import logs pubapi
	route @go_public {
		# if not accepted, the client will just get the 403 from the authenticator
			method GET
			rewrite /internal/basicAuthCheck
			# that needs to go
			@good status 2xx
				request_header X-Stamped-By me
		cache @needs_cache
	import logs api
	route @go_private {
		reverse_proxy @needs_foward_auth api:3000 {
			method GET
			# that needs to go
			@good status 2xx
		cache @needs_cache
Adding a snippet for the whole thing inside the route works well.
The log file issue remains.
(do_a_branch) {
	reverse_proxy @needs_foward_auth {args[0]}:3000 {
		method GET
		# that needs to go
		@good status 2xx
	cache @needs_cache
	import gotobackend {args[0]}:3000
	@go_private expression `{auth_type} != "none" && {auth_type} != "special"`
	import logs pubapi
	route @go_public {
		import do_a_branch pubapi
	import logs api
	route @go_private {
		import do_a_branch api
Correct, log is a top-level config directive, not a handler directive, so it can’t be used within any handle/route. You can use log_name and log_skip (which are handler directives) to control where logs for a particular request go. Review those docs.
Awesome, log_name works well.
Thank you @francislavoie !
Did you know that quite a few things in the doc don’t appear in the search? I had no idea about log_name (although log_skip is mentioned once on the log doc page).
this is how it look now (hopefully this is saving someone from a few hours of head-banging):
(logs) {
	log {args[0]} {
		no_hostname
		output file /logs/{args[0]}.log {
			roll_keep_for 10d
		format json {
			time_format iso8601
(gotobackend) {
	# mode bypass will work on v > 1.7.2
	# @remove_cache_headers expression `{needs_cache} == "1"`
	# reverse_proxy @remove_cache_headers {
	# 	header_down -Server
	# 	# header_down -Surrogate-Control
	# 	# these will be fixed in the next souin version (>1.7.2)
	# 	# header_down -Cache-Control
	# 	# header_down -Expires
	# 	to {args[0]}
	reverse_proxy {
		header_down -Server
		to {args[0]}
(do_a_branch) {
	# 	uri /internal/check
		method GET
		rewrite /internal/check
		# that needs to go
		@good status 2xx
	cache @needs_cache
	argsort lowercase
	import ./include/mapping.caddyfile
	import logs pubapi
	import logs api
	log_name @go_public pubapi
	log_name @go_private api
	route @go_public {
	route @go_private {
Many thanks to @francislavoie for jumping to the rescue and to @darkweak for fixing the mode bypass for stubborn APIs in the next release!
Unfortunately we don’t have a lot of control over the search, it’s indexed and produced by Algolia Docsearch. Last I looked (a few weeks ago) it did index those pages, but I don’t know why it doesn’t show up in search. Anyway, you should look through the Directives page for the source of truth index of directives
