Help blocking sub sub domains
1. Caddy version (caddy version): 1
NAME=“Ubuntu”
VERSION=“18.04.3 LTS (Bionic Beaver)”
caddy -conf Caddyfile -log caddy.log
paste full file contents here
root /srv/current/
log /srv/current/log/caddy-access.log
errors /srv/current/log/caddy-error.log
gzip
tls dev@example.com
proxy / unix:/srv/current/tmp/sockets/puma.sock {
*.example.com {
root /srv/current/
gzip
dns godaddy
:443 {
root /srv/current/
gzip
tls dev@example.com {
ask http://localhost:9005/allowed
I’d like to block sub sub domains.
Currently the *.example.com is working perfectly
We are also using the automatic tls to serve custom domains
The issue is that any sub sub domain (hello.hello.example.com) is actually trying to create a cert and bots are hitting a bunch of subdomains and we are hitting the limits.
failed to obtain certificate: acme: error: 429 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rateLimited :: Error creating new order :: too many certificates already issued
I’ve looked through the docs and also tried to find any similar question/answer without success.
Ruh-roh. What is http://localhost:9005/allowed returning in those situations?
For simplicity everything right now returns a 200. I guess I can figure out a way to block it there.
Yep. That’s the exact intended purpose of the ask subdirective.
FYI, Caddy v1 is no longer maintained, we urge you to consider upgrading to v2 as soon as possible.
