2.3.0
Running inside Docker
Docker
Currently I have multiple docker-compose files so I run like this
docker-compose -f docker-compose-fe.yml up -d
docker-compose -f docker-compose-be.yml up -d
Dockerfile
FROM caddy:2.3.0-alpine
COPY /usr/src/app/dist/project-fe /srv
project-fe:
image: project-fe:latest
container_name: project-fe
- 443:443
- ./caddydata:/data
- ./caddyconfig:/config
default:
external:
project-be:
image: project-be:latest
container_name: project-be
default:
external:
dev.domain.xyz {
root * /srv
try_files {path} /index.html
reverse_proxy /api/* http://project-be:8080
encode zstd gzip
basicauth * {
icetea5 bWFuYWdlcjo...=
Currently I’m having a backend and frontend running in same Docker machine in different containers.
I have REST API on backend container with the path of /api/test
and I’m trying it to access through frontend and the response that I’m getting is the contents of index.html
file And feels like the requests doesn’t get proxied to the backend container
"level": "info",
"ts": 1618171112.2697785,
"logger": "http.log.access",
"msg": "handled request",
"request": {
"remote_addr": "xx.xx.xxx.x:xxxxx",
"proto": "HTTP/2.0",
"method": "GET",
"host": "dev.domain.xyz",
"uri": "/api/test",
"headers": {
"Accept-Language": [
"en-US,en;q=0.9,lt;q=0.8"
"Sec-Ch-Ua": [
"\"Google Chrome\";v=\"89\", \"Chromium\";v=\"89\", \";Not A Brand\";v=\"99\""
"Accept": [
"application/json, text/plain, */*"
"Sec-Ch-Ua-Mobile": [
"?0"
"Sec-Fetch-Mode": [
"cors"
"Sec-Fetch-Dest": [
"empty"
"Authorization": [
"Basic bWFuYWdlcjo...="
"User-Agent": [
"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/89.0.4389.114 Safari/537.36"
"Sec-Fetch-Site": [
"same-origin"
"Referer": [
"https://dev.domain.xyz/"
"Accept-Encoding": [
"gzip, deflate, br"
"tls": {
"resumed": true,
"version": 772,
"cipher_suite": 4865,
"proto": "h2",
"proto_mutual": true,
"server_name": "dev.domain.xyz"
"common_log": "xx.xx.xxx.x - icetea5 [11/Apr/2021:19:58:32 +0000] \"GET /api/test HTTP/2.0\" 200 1260",
"duration": 0.000859889,
"size": 1260,
"status": 200,
"resp_headers": {
"Content-Type": [
"text/html; charset=utf-8"
"Last-Modified": [
"Sun, 11 Apr 2021 19:38:35 GMT"
"Content-Encoding": [
"gzip"
"Vary": [
"Accept-Encoding"
"Server": [
"Caddy"
"Etag": [
"\"qrezwb5pp\""
Pretty much tried reading googling as much as possible but didn’t seemd to find an answer. All I did was double check if containers are connected correctly, I’ve tried to ssh into Caddy container and from there execute:
wget http://project-be:8080/api/test
to backend container and got response that I was expecting it
and I get the desired response from REST API. So I assume that the Docker configuration should be alright, but perhaps there is an issue I’m not aware in the Caddyfile configuration
