Header_up -field in reverse_proxy will affect placeholders {http.request.header.field}?
:12345 {
    respond "hello world! {http.request.header.Origin}"
:23456 {
    @origin {
        header Origin *
    @preflight {
        header Origin *
        method OPTIONS
    header @origin {
        Access-Control-Allow-Origin "{http.request.header.Origin}"
        Access-Control-Allow-Credentials true
        Access-Control-Expose-Headers "Content-Length,Content-Range"
        defer
    header @preflight {
        Access-Control-Allow-Methods "GET,POST,PUT,DELETE,HEAD,OPTIONS"
        Access-Control-Allow-Headers "{http.request.header.Access-Control-Request-Headers}"
        Access-Control-Max-Age 86400
    reverse_proxy http://localhost:12345 {
        header_up -Origin
        header_down -Server
Docker 20.10.10
caddy run;
docker run --name caddy --net=host -e TZ=Asia/Shanghai -e GO111MODULE=on -e GOPROXY=https://goproxy.cn,direct --restart=always -v /data/www:/data/www:ro -v /opt/caddy/config:/etc/caddy:ro -v /opt/caddy/log:/log -w /etc/caddy -d caddy:builder-alpine sh -c "if [ ! -x /usr/bin/caddy ]; then xcaddy build --output /usr/bin/caddy --with github.com/caddyserver/format-encoder; fi; caddy run"
:12345 {
:23456 {
    @origin {
        header Origin *
    @preflight {
        header Origin *
        method OPTIONS
    header @origin {
        defer
    header @preflight {
        header_up -Origin
        header_down -Server
I want to use caddy to support CORS and disable the CORS logic of the upstream.
curl -v http://localhost:23456 -H "Origin: test"
*   Trying ::1...
* TCP_NODELAY set
* Expire in 150000 ms for 3 (transfer 0x55695f06af50)
* Expire in 200 ms for 4 (transfer 0x55695f06af50)
* Connected to localhost (::1) port 23456 (#0)
> GET / HTTP/1.1
> Host: localhost:23456
> User-Agent: curl/7.64.0
> Origin: test
< HTTP/1.1 200 OK
< Access-Control-Allow-Credentials: true
< Access-Control-Allow-Origin:
< Access-Control-Expose-Headers: Content-Length,Content-Range
< Content-Length: 13
< Date: Sun, 05 Dec 2021 04:56:33 GMT
< Server: Caddy
hello world!
I couldn’t find the relevant information in the forum, and then pulled out the simplest Caddyfile, which contains no other information and can be reproduced 100%.
Caddyfile can be simpler.
:12345 {
:23456 {
    @origin {
        header Origin *
    header @origin {
        defer
        header_up -Origin
        header_down -Server
Caddy’s reverse_proxy module doesn’t make a full copy of the request, it instead just mutates the existing request. This means that certain kinds of header modifications don’t get properly reset afterwards (they probably should, might be a bug).
But there is a workaround for now. You can use the header_regexp matcher to pull the values out and store them in the replacer so that you can use them again later. It would look something like this:
I wonder if copying the request, like the std lib’s proxy does, is a reasonable tradeoff. (It would perform less well, however, adding plenty of allocations.)
save the header modified by header_up into a temporary map?
Thank you, this can really help me.
