V2.4.1
I run Caddy in docker on a synology DS720+:
See above
#!/bin/bash
docker run -d \
-p 2080:80 \
-p 2443:443 \
--name Caddy \
--restart unless-stopped \
-v /volume1/docker/Caddy/Data:/data \
-v /volume1/docker/Caddy/Config:/config \
-v /volume1/docker/Caddy/Caddyfile:/etc/caddy/Caddyfile \
Caddy
I run in docker on a synology DS720+. I don’t use the synology interface or package but run the bash script instead.
www.server_1.nl {
reverse_proxy * 192.168.3.201:5000
output file /data/caddy-server_1nl.log {
roll_keep_for 14d
www.server_2.nl {
reverse_proxy * 192.168.3.200:31417
output file /data/caddy-server_2.log {
roll_keep_for 14d
ha.server_3.nl {
reverse_proxy * 192.168.3.200:8123
output file /data/caddy-haserver_3nl.log {
roll_keep_for 14d
server_4.nl {
reverse_proxy * http://192.168.3.200:10080
output file /data/caddy-server_4nl.log {
roll_keep_for 14d
www.server_4.nl {
roll_keep_for 14d
I use Caddy to direct traffic to the right server. The users can log in to the correct servers and have no issue. I can’t see the original users IP address, I see the internal docker address instead.
This is a log entry:
{"level":"info","ts":1626532822.3207395,"logger":"http.log.access.log1","msg":"handled request","request":{"remote_addr":"172.17.0.1:44994","proto":"HTTP/1.1","method":"GET","host":"www.server_3.nl","uri":"/webapi/entry.cgi?camId=8&api=SYNO.SurveillanceStation.Camera.Event&version=1&method=MotionEnum&_sid=KRPQMVPOGQlrQcZ1Pm4eAHWGIa2ncMBO9ScRFbzOrvkMffPzHIdtZoICSSas0-jrtxq5xDarYROClLxFWFM4mw","headers":{"Cookie":["id=KRPQMVPOGQlrQcZ1Pm4eAHWGIa2ncMBO9ScRFbzOrvkMffPzHIdtZoICSSas0-jrtxq5xDarYROClLxFWFM4mw; smid=bbIyvQfSpJAVpHWQpn6cn-oQXJL5EmdAhxBzK_W3EY3KO5rgqa0vHbdkI76yzAVzOIt6i2aU7dDO9llQZsK9Tw"],"User-Agent":["python-requests/2.25.1"],"Accept-Encoding":["gzip, deflate"],"Accept":["*/*"],"Connection":["keep-alive"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"http/1.1","proto_mutual":true,"server_name":"www.server_3.nl"}},"common_log":"172.17.0.1 - - [17/Jul/2021:14:40:22 +0000] \"GET /webapi/entry.cgi?camId=8&api=SYNO.SurveillanceStation.Camera.Event&version=1&method=MotionEnum&_sid=KRPQMVPOGQlrQcZ1Pm4eAHWGIa2ncMBO9ScRFbzOrvkMffPzHIdtZoICSSas0-jrtxq5xDarYROClLxFWFM4mw HTTP/1.1\" 200 370","duration":0.11634775,"size":370,"status":200,"resp_headers":{"Date":["Sat, 17 Jul 2021 14:40:22 GMT"],"Content-Type":["application/json; charset=\"UTF-8\""],"Server":["Caddy"],"Vary":["Accept-Encoding"],"X-Content-Type-Options":["nosniff"],"Expires":["0"],"Content-Encoding":["gzip"],"Set-Cookie":["id=KRPQMVPOGQlrQcZ1Pm4eAHWGIa2ncMBO9ScRFbzOrvkMffPzHIdtZoICSSas0-jrtxq5xDarYROClLxFWFM4mw;expires=Sat, 24-Jul-2021 14:40:22 GMT;path=/;HttpOnly"],"Cache-Control":["max-age=0, no-cache, no-store, must-revalidate"],"Pragma":["no-cache"],"X-Xss-Protection":["1; mode=block"]}}
Log file entry in Docker.
17T15:57:53.468056638Z {"level":"error","ts":1626537473.4675727,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"www.server_4.nl","error":"no information found to solve challenge for identifier: www.server_4.nl"}
I made sure that the proxy server is trusted by the Synology. I looked into header management in the documentation. It should be okay by default. Maybe there is something wrong in the docker file, because I don’t see the original IP in the log file anywhere. I am a bit surprised about this part in the log:
Where does this come from?
