koledi
(Koledi)
May 14, 2020, 5:53am
1
CLI
Solus 4.1
./caddy adapt --pretty --validate --config caddy.conf --adapter caddyfile > caddy.json
./caddy run --config caddy.json
#### c. Service/unit/compose file:
koledi.com:4430 www.koledi.com:4430 {
bind 127.0.0.1
## Self-signed
tls cert.pem cert.key
@www {
host www.koledi.com
redir @www https://koledi.com:4430{uri} permanent
route {
-server
Cache-Control "max-age=604800, public"
header /libs/* {
Cache-Control "public, max-age=31536000, immutable"
reverse_proxy localhost:8080
curl -IL https://koledi.com/libs/foo.js
Cache-Control response header is “max-age=604800, public”, expects “public, max-age=31536000, immutable”
Reorder header directives.
Change path pattern /libs/*, /libs*, /libs/, /libs
Remove route {}
Header directive adapted from header (Caddyfile directive) — Caddy Documentation
route {
header Cache-Control max=age=3600
header /static/* Cache-Control max=age=31536000
Luckily there’s a tool just for this! The handle directive:
handle /libs/* {
header Cache-Control "public, max-age=31536000, immutable"
header Cache-Control "max-age=604800, public"
Interesting. That might be a bug then. We might need to look into that @matt
Had a similar issue over here:
We’re looking into why this is the case.
I might have to look closer at this one…
koledi
(Koledi)
May 14, 2020, 6:17am
4
Using the handle example results in two Cache-Control response headers, instead of replacing the original header,
$ curl -IL https://koledi.com/libs/foo.js
cache-control: public, max-age=31536000, immutable
cache-control: max-age=86400,public
The second header is from the backend (hence the header rewrite).
That’s some weird behaviour.
Your initial configuration works for me.
~/Projects/test
➜ cat Caddyfile
http://:8080 {
route {
header /libs/* {
~/Projects/test
➜ curl -I localhost:8080/
HTTP/1.1 200 OK
Cache-Control: max-age=604800, public
Server: Caddy
Date: Thu, 14 May 2020 06:17:38 GMT
~/Projects/test
➜ curl -I localhost:8080/libs/
HTTP/1.1 200 OK
Cache-Control: public, max-age=31536000, immutable
Server: Caddy
Date: Thu, 14 May 2020 06:17:43 GMT
Simplified variant as well behaved as expected:
~/Projects/test
➜ cat Caddyfile
http://:8080 {
route {
header /libs/* Cache-Control "public, max-age=31536000, immutable"
~/Projects/test
HTTP/1.1 200 OK
Server: Caddy
Date: Thu, 14 May 2020 06:20:24 GMT
~/Projects/test
HTTP/1.1 200 OK
Server: Caddy
Date: Thu, 14 May 2020 06:20:28 GMT
@francislavoie ’s handle method also worked.
~/Projects/test
➜ cat Caddyfile
http://:8080 {
handle /libs/* {
~/Projects/test
HTTP/1.1 200 OK
Server: Caddy
Date: Thu, 14 May 2020 06:22:36 GMT
~/Projects/test
HTTP/1.1 200 OK
Server: Caddy
Date: Thu, 14 May 2020 06:22:38 GMT
koledi
(Koledi)
May 14, 2020, 6:48am
7
I forgot to mention that my config has -server (updated my first post),
route {
-server
header /libs/* {
If I access https://koledi.com/libs/foo.js, the response header is Cache-Control: max-age=604800, public, instead of 31536000.
Here’s the weird thing, if I comment out the -server,
route {
#-server
header /libs/* {
This will result in duplicate “Cache-Control”, just like my previous comment,
I think you should test with reverse_proxy with “cache-control: max-age=86400,public” header.
matt
(Matt Holt)
May 14, 2020, 6:50am
8
That might be a bug in our docs… why would I write a route for mutually-exclusive header directives…
See here @matt : Header directive is not mutually exclusive - #3 by Whitestrake
Specifically the last comment I left in that thread:
I think that question bears a little more looking into.
At the moment, I’m thinking it might be best just to include an example like this in the header documentation:
route {
header Cache-Control max-age=3600
header /static/* Cache-Control max-age=31536000
header /favicon.ico Cache-Control max-age=31536000
And explain what the use case is for it.
This is an interesting case where the behaviour we’d usually expect to be ideal - that is, evaluating the more specific route first - is ac…
matt
(Matt Holt)
May 14, 2020, 6:58am
10
@francislavoie and I figured that one out and it is already fixed on master; but I think this is a separate issue because the route block does not change the order of its directives. Our docs currently recommend using route with two header directives inside it for mutual-exclusivity, but I wonder if I wrote that before I had finished designing the route and handle directives… I just think our docs are wrong.
I don’t remember us doing a fix for this, are you thinking of the not matcher thing? That was separate.
matt
(Matt Holt)
May 14, 2020, 5:11pm
12
No, I was referring to the route-ordering bug where ordering a directive’s handler based on its path matcher length was wrong. We fixed that.
Also, the example in the docs are correct, it turns out. So, I was wrong about that.
Just so you know, the reverse proxy appends headers from the backend, it doesn’t replace them. Header operations on the response are applied immediately, unless explicitly deferred until later: Modules - Caddy Documentation
If true, header operations will be deferred until they are written out. Superceded if Require is set. Usually you will need to set this to true if any fields are being deleted.
So if you have a header directive like above, it will set the Cache-Control header right away, then the reverse proxy will append the one from the backend. That’s why the reverse proxy has its own header controls, so you can manipulate headers to/from the backend independently of to/from the client.
Okay so I think this is what we need?
route {
-server
defer
header /libs/* {
defer
Read the note at the top:
By default, header operations are performed immediately unless any of the headers are being deleted, in which case the header operations are automatically deferred until the time they are being written to the client.
That would explain why it behaved that way when you had -server in there, because it switches modes automatically if you’re also deleting a header.
Also, you could tell your reverse proxy to stop adding cache control headers. Or tell Caddy to strip them out:
reverse_proxy localhost:8080 {
header_down -Cache-Control
matt
(Matt Holt)
May 14, 2020, 11:21pm
15
Perhaps the header directive should overwrite changes resulting from reverse_proxy? But I don’t know how to make that work well. Feel free to open an issue on GitHub so we can discuss it. It’d be interesting to see how other servers handle this. I feel like it’s a complicated issue.
koledi
(Koledi)
May 15, 2020, 1:30am
16
http://localhost:8080 {
header Cache-Control "max-age=86400, public"
http://localhost:8081 {
header_up Host localhost
$ curl -IL http://localhost:8081
Response header has no Cache-Control.
http://localhost:8080 ...
Response header has two Cache-Control.
header_down "max-age=604800, public"
This works, but I have multiple backends and prefer to use a single header directive, instead of duplicating header_down.
koledi
(Koledi)
May 15, 2020, 1:39am
17
That’s v1 behaviour, if the header matches any response from backend, the response header is replaced, while still forwarding other (unmatched) response headers; v2 appends to it instead (as you mentioned), resulting in duplicate response headers, unless there is header removal or defer.
koledi
(Koledi)
May 15, 2020, 1:49am
18
defer does work, but I need to switch the order (probably related to “Can't get simple alias to work - #9 by matt ”, and may have been fixed).
route {
header /libs/* {
defer
-server
defer
I also tried comment out the -server and it still works. Removing route also works and regardless of header order.
