I’m trying to create a reverse proxy to my Pi-Hole instance so I can type pihole.internal into my browser and end up at 192.168.1.218/admin (where 192.168.1.218 is the IP where Pi-Hole is located). The specific part I’m having trouble with is attaching /admin to the path.
admin@caddy:~$ curl -vk https://pihole.internal
* Host pihole.internal:443 was resolved.
* IPv6: fe80::be24:11ff:feaa:86a5
* IPv4: 192.168.1.218
* Trying 192.168.1.218:443...
* Connected to pihole.internal (192.168.1.218) port 443
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384 / x25519 / id-ecPublicKey
* ALPN: server did not agree on a protocol. Uses default.
* subject: CN=pi.hole
* start date: Jul 26 03:08:32 2025 GMT
* expire date: Jul 26 03:08:32 2055 GMT
* issuer: CN=pi.hole; O=Pi-hole; C=DE
* SSL certificate verify result: self-signed certificate in certificate chain (19), continuing anyway.
* Certificate level 0: Public key type EC/secp384r1 (384/192 Bits/secBits), signed using ecdsa-with-SHA256
* Certificate level 1: Public key type EC/secp384r1 (384/192 Bits/secBits), signed using ecdsa-with-SHA256
* using HTTP/1.x
> GET / HTTP/1.1
> Host: pihole.internal
> User-Agent: curl/8.9.1
* Request completely sent off
< HTTP/1.1 403 Forbidden
< Cache-Control: no-cache, no-store, must-revalidate, private, max-age=0
< Expires: 0
< Pragma: no-cache
< X-DNS-Prefetch-Control: off
< Content-Security-Policy: default-src 'self' 'unsafe-inline';
< X-Frame-Options: DENY
< X-XSS-Protection: 0
< X-Content-Type-Options: nosniff
< Referrer-Policy: strict-origin-when-cross-origin
< Content-Type: text/html; charset=utf-8
< Date: Sat, 26 Jul 2025 07:27:40 GMT
< Connection: close
<!DOCTYPE html>
* Pi-hole: A black hole for Internet advertisements
* (c) 2017 Pi-hole, LLC (https://pi-hole.net)
* Network-wide ad blocking via your own hardware.
* This file is copyright under the latest version of the EUPL.
* Please see LICENSE file for your rights under this license.
<html lang="en">
<head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1">
<title>Pi-hole pihole</title>
<meta name="csrf-token" content="">
<link rel="apple-touch-icon" href="/admin/img/favicons/apple-touch-icon.png" sizes="180x180">
<link rel="icon" href="/admin/img/favicons/favicon-32x32.png" sizes="32x32" type="image/png">
<link rel="icon" href="/admin/img/favicons/favicon-16x16.png" sizes="16x16" type="image/png">
<link rel="manifest" href="/admin/img/favicons/manifest.json">
<link rel="mask-icon" href="/admin/img/favicons/safari-pinned-tab.svg" color="#367fa9">
<link rel="shortcut icon" href="/admin/img/favicons/favicon.ico">
<meta name="msapplication-TileColor" content="#367fa9">
<meta name="msapplication-TileImage" content="/admin/img/favicons/mstile-150x150.png">
<meta name="theme-color" content="#367fa9">
<!-- Theme fonts -->
<link rel="stylesheet" href="/admin/vendor/fonts/source-sans-pro/source-sans-pro.css?v=1753499303">
<style>
html { background-color: #000; }
</style>
<!-- Common styles -->
<link rel="stylesheet" href="/admin/vendor/bootstrap/css/bootstrap.min.css?v=1753499303">
<link rel="stylesheet" href="/admin/vendor/icheck/icheck-bootstrap.min.css?v=1753499303">
<link rel="stylesheet" href="/admin/vendor/animate/animate.min.css?v=1753499303">
<link rel="stylesheet" href="/admin/vendor/bstreeview/bstreeview.min.css?v=1753499303">
<link rel="stylesheet" href="/admin/vendor/font-awesome/css/all.min.css?v=1753499303">
<link rel="stylesheet" href="/admin/vendor/nprogress/nprogress.min.css?v=1753499303">
<link rel="stylesheet" href="/admin/vendor/datatables/datatables.min.css?v=1753499303">
<link rel="stylesheet" href="/admin/vendor/datatables-buttons/datatables.buttons.min.css?v=1753499303">
<link rel="stylesheet" href="/admin/vendor/datatables-select/datatables.select.min.css?v=1753499303">
<link rel="stylesheet" href="/admin/vendor/daterangepicker/daterangepicker.min.css?v=1753499303">
<link rel="stylesheet" href="/admin/vendor/bootstrap-toggle/bootstrap-toggle.min.css?v=1753499303">
<link rel="stylesheet" href="/admin/vendor/waitMe-js/waitMe.min.css?v=1753499303">
<link rel="stylesheet" href="/admin/vendor/select2/select2.min.css?v=1753499303">
<link rel="stylesheet" href="/admin/vendor/adminLTE/AdminLTE.min.css?v=1753499303">
<!-- Theme styles (default-auto) -->
<link rel="stylesheet" href="/admin/style/pi-hole.css?v=1753499303">
<link rel="stylesheet" href="/admin/style/themes/default-dark.css?v=1753499303" media="(prefers-color-scheme: dark)">
<link rel="stylesheet" href="/admin/style/themes/default-light.css?v=1753499303" media="not (prefers-color-scheme: dark)">
<noscript><link rel="stylesheet" href="/admin/vendor/js-warn/js-warn.css?v=1753499303"></noscript>
<!-- scripts -->
<script src="/admin/vendor/jquery/jquery.min.js?v=1753499303"></script>
<script src="/admin/vendor/bootstrap/js/bootstrap.min.js?v=1753499303"></script>
<script src="/admin/vendor/adminLTE/adminlte.min.js?v=1753499303"></script>
<script src="/admin/vendor/bootstrap-notify/bootstrap-notify.min.js?v=1753499303"></script>
<script src="/admin/vendor/waitMe-js/modernized-waitme-min.js?v=1753499303"></script>
<script src="/admin/vendor/nprogress/nprogress.min.js?v=1753499303"></script>
<script src="/admin/scripts/js/utils.js?v=1753499303"></script>
<body class="hold-transition layout-boxed login-page page--">
<div class="box login-box">
<section style="padding: 15px;">
<h2 class="error-headline text-danger">403</h2>
<div class="error-content">
<h3><i class="fa fa-times-circle text-danger"></i> Oops! Access denied.</h3>
<p>
You don't have permission to access <code>-</code> on this server.<br>
Did you mean to go to <a href="/admin/">your Pi-hole's dashboard</a> instead?
</p>
</div>
</section>
</div>
</body>
</html>
* TLSv1.3 (IN), TLS alert, close notify (256):
* shutting down connection #0
* TLSv1.3 (OUT), TLS alert, close notify (256):
admin@caddy:~$ caddy version
Caddy is running in a Proxmox LXC using Ubuntu 24.10. Pi-Hole is running as a separate LXC on the same machine.
I installed Caddy using the documentation here: Install — Caddy Documentation
chmod o+r /usr/share/keyrings/caddy-stable-archive-keyring.gpg
chmod o+r /etc/apt/sources.list.d/caddy-stable.list
sudo apt update
sudo apt install caddy
N/A
proxmox.internal {
reverse_proxy https://192.168.1.217:8006 {
# WARNING: this is unsafe if this is ever exposed to the global internet!!!
# This is acceptable as long as the network is local, private, secure, and trusted
tls_insecure_skip_verify
pihole.internal {
rewrite * /admin{uri}
reverse_proxy https://192.168.1.218 {
My reference for rewrite with reverse proxy is here: rewrite (Caddyfile directive) — Caddy Documentation
