Hi guys, extreme noob here. I’ve always messed with Linux and Media servers locally but never remotely. The best I did was open up the port on my router and enter the IP on my phone. Now I want to do things properly with HTTPS and Reverse Proxy.
I bought a domain for cheap and I’m tryin got point my Jellyfin to this(Jellyfin created with the help of DockSTARTer) my whole setup is in containers. I followed this youtube video
I do exactly what is done in this video but it doesn’t work! I’ve spent much of the day on this issue.
Feb 29 21:01:14 archlinux systemd[1]: Starting Caddy web server...
Feb 29 21:01:14 archlinux caddy[128092]: {"level":"info","ts":1709220674.3407578,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Feb 29 21:01:14 archlinux caddy[128092]: {"level":"warn","ts":1709220674.3408637,"msg":"No files matching import glob pattern","pattern":"/etc/caddy/conf.d/*"}
Feb 29 21:01:14 archlinux caddy[128092]: {"level":"info","ts":1709220674.3427844,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000397700"}
Feb 29 21:01:14 archlinux caddy[128092]: {"level":"info","ts":1709220674.342832,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Feb 29 21:01:14 archlinux caddy[128092]: {"level":"info","ts":1709220674.3428516,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Feb 29 21:01:14 archlinux caddy[128092]: {"level":"info","ts":1709220674.3430142,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc000397700"}
Feb 29 21:01:14 archlinux caddy[128092]: Valid configuration
Feb 29 21:01:14 archlinux caddy[128101]: caddy.HomeDir=/var/lib/caddy
Feb 29 21:01:14 archlinux caddy[128101]: caddy.AppDataDir=/var/lib/caddy
Feb 29 21:01:14 archlinux caddy[128101]: caddy.AppConfigDir=/etc/caddy
Feb 29 21:01:14 archlinux caddy[128101]: caddy.ConfigAutosavePath=/etc/caddy/autosave.json
Feb 29 21:01:14 archlinux caddy[128101]: caddy.Version=v2.7.6 h1:w0NymbG2m9PcvKWsrXO6EEkY9Ru4FJK8uQbYcev1p3A=
Feb 29 21:01:14 archlinux caddy[128101]: runtime.GOOS=linux
Feb 29 21:01:14 archlinux caddy[128101]: runtime.GOARCH=amd64
Feb 29 21:01:14 archlinux caddy[128101]: runtime.Compiler=gc
Feb 29 21:01:14 archlinux caddy[128101]: runtime.NumCPU=4
Feb 29 21:01:14 archlinux caddy[128101]: runtime.GOMAXPROCS=4
Feb 29 21:01:14 archlinux caddy[128101]: runtime.Version=go1.21.4
Feb 29 21:01:14 archlinux caddy[128101]: os.Getwd=/
Feb 29 21:01:14 archlinux caddy[128101]: LANG=en_US.UTF-8
Feb 29 21:01:14 archlinux caddy[128101]: PATH=/usr/local/sbin:/usr/local/bin:/usr/bin
Feb 29 21:01:14 archlinux caddy[128101]: NOTIFY_SOCKET=/run/systemd/notify
Feb 29 21:01:14 archlinux caddy[128101]: USER=caddy
Feb 29 21:01:14 archlinux caddy[128101]: LOGNAME=caddy
Feb 29 21:01:14 archlinux caddy[128101]: HOME=/var/lib/caddy
Feb 29 21:01:14 archlinux caddy[128101]: INVOCATION_ID=f2d94842d98b467ab937a934bb9f0f39
Feb 29 21:01:14 archlinux caddy[128101]: JOURNAL_STREAM=8:341471
Feb 29 21:01:14 archlinux caddy[128101]: SYSTEMD_EXEC_PID=128101
Feb 29 21:01:14 archlinux caddy[128101]: MEMORY_PRESSURE_WATCH=/sys/fs/cgroup/system.slice/caddy.service/memory.pressure
Feb 29 21:01:14 archlinux caddy[128101]: MEMORY_PRESSURE_WRITE=c29tZSAyMDAwMDAgMjAwMDAwMAA=
Feb 29 21:01:14 archlinux caddy[128101]: XDG_DATA_HOME=/var/lib
Feb 29 21:01:14 archlinux caddy[128101]: XDG_CONFIG_HOME=/etc
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"info","ts":1709220674.4350495,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"warn","ts":1709220674.4352012,"msg":"No files matching import glob pattern","pattern":"/etc/caddy/conf.d/*"}
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"info","ts":1709220674.437057,"logger":"admin","msg":"admin endpoint started","address":"unix//run/caddy/admin.socket","enforce_origin":false,"origins":["//127.0.0.1","//::1",""]}
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"info","ts":1709220674.437331,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000379d80"}
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"info","ts":1709220674.4373686,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"info","ts":1709220674.4373856,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"info","ts":1709220674.4376888,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"info","ts":1709220674.4377422,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"info","ts":1709220674.437837,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"info","ts":1709220674.437968,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"info","ts":1709220674.438052,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["www.horizonjelly.cloud"]}
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"error","ts":1709220674.4386406,"msg":"unable to autosave config","file":"/etc/caddy/autosave.json","error":"open /etc/caddy/autosave.json: read-only file system"}
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"info","ts":1709220674.4387152,"msg":"serving initial configuration"}
Feb 29 21:01:14 archlinux systemd[1]: Started Caddy web server.
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"warn","ts":1709220674.4435766,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/var/lib/caddy","instance":"7b369897-75ae-4bfd-9084-b5b1952f77b5","try_again":1709307074.4435737,"try_again_in":86399.999999453}
Feb 29 21:01:14 archlinux caddy[128101]: {"level":"info","ts":1709220674.443689,"logger":"tls","msg":"finished cleaning storage units"}
OS: Arch Linux
Kernel: x86_64 Linux 6.7.6-arch1-1
Installed via
pacman -S caddy
caddy run --config /etc/caddy/Caddyfile
c. My complete Caddy config:
www.domain.mine{
reverse_proxy 192.168.0.104:8096
dns cloudflare APITOKEN
Thank you for being patient.
