1. Caddy version:
Caddy Version: v2.6.2 h1:wKoFIxpmOJLGl3QXoo6PNbYvGW4xLEgo32GPBEjWL8o=
I am using docker-compose
I installed via docker-compose.
Ubuntu 20.04.5 LTS, systemd, Dockercat
docker-compose up -d
version: '3'
image: caddy:latest
- ./site:/srv
- ./caddy_data:/data:rw
- ./caddy_config:/config:rw
reddfeed:
build: Reddfeed
container_name: reddfeed
image: reddfeed:latest
peertube:
image: chocobozzz/peertube:production-bullseye
container_name: peertube
default:
ipv4_address: 172.18.0.42
env_file:
- ./Peertube/.env
- 9000:9000
- assets:/app/client/dist
- ./Peertube/docker-volume/data:/data
- ./Peertube/docker-volume/config:/config
depends_on:
- postgres
- redis
- postfix
postgres:
image: postgres:13-alpine
container_name: peertube-postgres
env_file:
- ./Peertube/.env
- ./Peertube/docker-volume/db:/var/lib/postgresql/data
redis:
image: redis:6-alpine
container_name: peertube-redis
- ./Peertube/docker-volume/redis:/data
postfix:
image: mwader/postfix-relay
container_name: peertube-postfix
env_file:
- ./Peertube/.env
- ./Peertube/docker-volume/opendkim/keys:/etc/opendkim/keys
default:
ipam:
driver: default
config:
- subnet: 172.18.0.0/16
assets:
synhang.ddns.net {
tls MYEMAIL@protonmail.com
reverse_proxy /posts* reddfeed:5000{uri}
reverse_proxy /sub/* reddfeed:5000{uri}
reverse_proxy /watch* peertube:9000
My intention is to have ‘/’ go to a static webpage (which it does fine). If a user types this location: https:// synhang. ddns .net/posts it should reverse_proxy to the reddfeed container which is a flask app listening on 0.0.0.0:5000. If the user types the /sub/ URI they need an additional section behind it like so: https://synhang.ddns.net/sub/arduino. Finally, if a user types this URI: https:// synhang .ddns .net/watch it should redirect to my peertube instance which is listening on port 9000.
When loading the local IP in a browser to access the resources directly. I.e. http://192.168.0.23:5000/posts or http://192.168.0.23:5000/sub/arduino I can access the resources just fine. Likewise if I load http://192.168.0.23:9000 I get the peertube instance. But if I try to access it via the domain. I get these errors:
For the :5000 URIs I get a 502 bad gateway error. And for the /watch endpoint I get
Loading module from “https://synhang.ddns.net/client/en-US/runtime.ce410da37895951f.js” was blocked because of a disallowed MIME type (“”).
and errors such as:
GET https://synhang.ddns.net/client/en-US/styles.89b7ff258a4af6c2.css
Which is a 404
There are many such errors
I know with Nginx I can have and include mime.types; directive to catch most mimes but how do I do this with caddy.
But the 502 and 404 errors are not occurring when running from within the LAN
