Having issues with reverse proxies and cloudflare htps
V2.0.0
I use Ubuntu 18.04 with systemd
sudo systemctl start caddy.service
# caddy.service
# for your installation.
After=network.target
tarek.wtf {
        reverse_proxy 127.0.0.1:9500
voidbot.ai {
        reverse_proxy 127.0.0.1:33349
gateway.voidbot.ai {
        reverse_proxy 127.0.0.1:9003
api.voidbot.ai {
        reverse_proxy 127.0.0.1:5000
I am trying to use reverse proxy with Caddy, with Cloudflare in the front, for whatever reason, only api.voidbot.ai fails, but others seem to be fine.
2020/05/18 15:39:09 http: TLS handshake error from 172.68.x.x:33322: no certificate available for ‘api.voidbot.ai’ from syslog.
Not much.. I’ve tried to check my HTTPS settings on the Cloudflare dashboard, disabled stuff, restarted Caddy, rewritten my config file.
You must have more logs than that. It’s impossible to tell what’s going on without the full logs.
Where else can I look for logs? That’s all I can find, and it’s from syslogs.
Run journalctl -u caddy. You should have logs from when Caddy starts up, etc. I don’t believe that that’s the only log line you have in your logs.
It’d be the same place you got this log entry:
(probably)
There should be many more lines.
Hm. I found this:
caddy[15003]: 2020/05/18 16:09:48 [ERROR] attempt 1: [api.voidbot.ai] Obtain: [api.voidbot.ai] error: one or more domains had a problem:
caddy[15003]: [api.voidbot.ai] acme: error: 403 :: urn:ietf:params:acme:error:unauthorized :: Cannot negotiate ALPN protocol "acme-tls/1" for tls-alpn-01 challenge, url:
caddy[15003]:  - retrying in 1m0s (11.34547339s/720h0m0s elapsed)...
Hopefully that’s helpful
Looking at this thread from last year, this seems to be the same issue:
Unless I am misreading, this is related to Let’s Encrypt. Is it possible to disable it entirely and only rely on Cloudflare certified certificates?
Hmmm. I just added a new sub-domain under /etc/caddy/Caddyfile, restarted… And now api.voidbot.ai gets a SSL cert just fine, but the new sub-domain fails instead. :thinking:
All domains works fine now, I didn’t even change anything, interesting.
Just to answer this question in case anyone else is interested:-
I hope it all does work now, because you can use only Cloudflare certs, but that involves grabbing their origin certificate and specifying it for all your sites with tls cert key, which will disable all Automatic HTTPS features. It will be much smoother without that, when Caddy manage your certificates itself.
tls (Caddyfile directive) — Caddy Documentation
