We are using the admin port (2019) to create dynamic routes. After the latest update, this stopped working.
After a reboot:
curl localhost:2019/config/
{"error":"host not allowed: localhost:2019"}
But, restart the service:
$ sudo systemctl restart caddy
$ curl localhost:2019/config/
{"apps":{"http":{"servers":{"srv0":{"automatic_https":{...
This now works for reading, but when trying to update and make changes via the API port, you get:
connect ECONNREFUSED ::1:2019
From the Journal:
Jun 18 08:34:47 pop-os caddy[404079]: {"level":"info","ts":1718721287.4569757,"logger":"admin.api","msg":"received request","method":"GET","host":"localhost:2019","uri":"/config/","remote_ip":"127.0.0.1","remote_port":"45120","headers":{"Accept":["*/*"],"User-Agent":["curl/7.81.0"]}}
So, a “GET” on port 2019 works, but a “POST” gets a connection refused.
$ caddy version
systemd
# This is pointing to Let's Encrypt Staging environment (for dev)
# https://letsencrypt.org/docs/staging-environment/
# This will allow you to get things right before issuing trusted
# certificates and reduce the chance of your running up against rate limits.
# causes all certificates to be issued internally by default,
# rather than through a (public) ACME CA such as Let's Encrypt.
# This is useful in development environments.
local_certs
# configure automatic HTTPS. It can either disable it entirely (off)
# or disable only HTTP-to-HTTPS redirects (disable_redirects).
auto_https off
(header_options) {
header_up Access-Control-Allow-Origin *
header_up Access-Control-Allow-Credentials true
header_up Access-Control-Allow-Headers Cache-Control,Content-Type
localhost:80 {
# bind :80
# serve photography folder
root /files/* /opt/ivt/photography
root * /opt/ivt/apps/6.5.0/packages/client/spa
route /weather/* {
uri replace /weather /socket.io
reverse_proxy * http://localhost:3010 {
import header_options
route /ptz/* {
uri replace /ptz /socket.io
reverse_proxy * http://localhost:3006 {
route /liveview/* {
uri replace /liveview /socket.io
reverse_proxy * http://localhost:3004 {
route /archive/* {
uri replace /archive /socket.io
reverse_proxy * http://localhost:3003 {
route /alarms/* {
uri replace /alarms /socket.io
reverse_proxy * http://localhost:3002 {
route /console_socket/* {
uri replace /console_socket /console/socket.io
reverse_proxy * http://localhost:3001 {
route /web_app_socket/* {
uri replace /web_app_socket /web/socket.io
route /api/* {
