Hello,
is it possible to install sendy.co on a caddyserver? The requirements of sendy.co
is an Apache server.
Or do you know an alternative to sendy.co?
Thank you and greetings
I’ve never used it, but going by Get Started with Sendy it looks like they just assume a traditional LAMP stack. I don’t think there should be any problem if you switch out Apache (the “A” in LAMP) with Caddy. You will need to set up MySQL and PHP though.
I’m working on this now
How did it go? Is it running?
