Hi!
I’m running my webserver on a server at my house which means no static IP and ISP making it a little bit of a headache. To get around this, I’ve got two cloud servers with static IPs that connect to my main server via a VPN. My DNS settings point to the cloud servers that then proxy everything through the VPN and to my home server.
My biggest issues are with automatic certificates (but so far the renewals seem to have no problems) not liking this setup and I can’t seem to get HTTP to HTTPS redirection to function, either. I can access sites over port 80 and over port 443 but on sites that expect to be accessed over HTTPS, I get an error instead of a redirection.
Caddyfile:
bitwarden.example.com {
proxyprotocol 10.10.0.0/16
proxy /notifications/hub/negotiate 172.16.1.2:80 {
proxy /notifications/hub 172.16.1.2:3012 {
websocket
proxy / 172.16.1.2:80 {
calendar.example.com {
proxy / http://172.16.0.5:5232/ {
header_upstream X-Script-Name /
cloud.example.com {
proxy / http://172.16.0.15:2015 {
http://, https:// {
tls cert key
redir https://example.com
HAProxy:
global
log /dev/log local0
log /dev/log local1 notice
chroot /var/lib/haproxy
stats socket /run/haproxy/admin.sock mode 660 level admin expose-fd listeners
stats timeout 30s
user haproxy
group haproxy
daemon
ca-base /etc/ssl/certs
crt-base /etc/ssl/private
ssl-default-bind-ciphers ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+$
ssl-default-bind-options no-sslv3
defaults
log global
mode tcp
option tcplog
option dontlognull
timeout connect 5000
timeout client 50000
timeout server 50000
errorfile 400 /etc/haproxy/errors/400.http
errorfile 403 /etc/haproxy/errors/403.http
errorfile 408 /etc/haproxy/errors/408.http
errorfile 500 /etc/haproxy/errors/500.http
errorfile 502 /etc/haproxy/errors/502.http
errorfile 503 /etc/haproxy/errors/503.http
errorfile 504 /etc/haproxy/errors/504.http
frontend http
bind *:80
bind :::80
mode tcp
default_backend http_backend
frontend https
bind *:443
bind :::443
mode tcp
default_backend https_backend
mode tcp
stick store-request src
stick-table type ip size 200k expire 30m
server http_server 10.10.1.2:80 send-proxy-v2
mode tcp
server https_server 10.10.1.2:443 send-proxy-v2
When I browse to a site over plain HTTP I get:
400 Bad Request
And with this setup if I try and add a new subdomain and wait for it to autofetch certificates:
Oct 01 10:07:20 atitlan caddy[40124]: 2019/10/01 10:07:20 [ERROR][surprise.example.com]failed to obtain certificate: acme: Error -> One or more domains had a problem:
Oct 01 10:07:20 atitlan caddy[40124]: [surprise.example.com] acme: error: 400 :: urn:ietf:params:acme:error:dns :: No valid IP addresses found for surprise.example.com, url:
Oct 01 10:07:20 atitlan caddy[40124]: (attempt 1/3; challenge=http-01)
Oct 01 10:07:21 atitlan caddy[40124]: 2019/10/01 10:07:21 [INFO] [surprise.example.com] acme: Obtaining bundled SAN certificate
Oct 01 10:07:21 atitlan caddy[40124]: 2019/10/01 10:07:21 [INFO] [surprise.example.com] AuthURL: https://acme-v02.api.letsencrypt.org/acme/authz-v3/587925984
Oct 01 10:07:21 atitlan caddy[40124]: 2019/10/01 10:07:21 [INFO] [surprise.example.com] acme: Could not find solver for: tls-alpn-01
Oct 01 10:07:21 atitlan caddy[40124]: 2019/10/01 10:07:21 [INFO] [surprise.example.com] acme: use http-01 solver
Oct 01 10:07:21 atitlan caddy[40124]: 2019/10/01 10:07:21 [INFO] [surprise.example.com] acme: Trying to solve HTTP-01
Oct 01 10:07:22 atitlan caddy[40124]: 2019/10/01 10:07:22 [INFO] Unable to deactivated authorizations: https://acme-v02.api.letsencrypt.org/acme/authz-v3/587925984
Oct 01 10:07:22 atitlan caddy[40124]: 2019/10/01 10:07:22 [ERROR][surprise.example.com] failed to obtain certificate: acme: Error -> One or more domains had a problem:
Oct 01 10:07:22 atitlan caddy[40124]: [surprise.example.com] acme: error: 400 :: urn:ietf:params:acme:error:dns :: No valid IP addresses found for surprise.example.com, url:
Oct 01 10:07:22 atitlan caddy[40124]: (attempt 2/3; challenge=http-01)
Oct 01 10:07:23 atitlan caddy[40124]: 2019/10/01 10:07:23 [INFO] [surprise.example.com] acme: Obtaining bundled SAN certificate
Oct 01 10:07:23 atitlan caddy[40124]: 2019/10/01 10:07:23 [INFO] [surprise.example.com] AuthURL: https://acme-v02.api.letsencrypt.org/acme/authz-v3/587926452
Oct 01 10:07:23 atitlan caddy[40124]: 2019/10/01 10:07:23 [INFO] [surprise.example.com] acme: Could not find solver for: tls-alpn-01
Oct 01 10:07:23 atitlan caddy[40124]: 2019/10/01 10:07:23 [INFO] [surprise.example.com] acme: use http-01 solver
Oct 01 10:07:23 atitlan caddy[40124]: 2019/10/01 10:07:23 [INFO] [surprise.example.com] acme: Trying to solve HTTP-01
Oct 01 10:07:23 atitlan caddy[40124]: 2019/10/01 10:07:23 [INFO] Unable to deactivated authorizations: https://acme-v02.api.letsencrypt.org/acme/authz-v3/587926452
Oct 01 10:07:23 atitlan caddy[40124]: 2019/10/01 10:07:23 [ERROR][surprise.example.com] failed to obtain certificate: acme: Error -> One or more domains had a problem:
Oct 01 10:07:23 atitlan caddy[40124]: [surprise.example.com] acme: error: 400 :: urn:ietf:params:acme:error:dns :: No valid IP addresses found for surprise.example.com, url:
Oct 01 10:07:23 atitlan caddy[40124]: (attempt 3/3; challenge=http-01)
Oct 01 10:07:24 atitlan caddy[40124]: 2019/10/01 10:07:24 [INFO] [surprise.example.com] acme: Obtaining bundled SAN certificate
Oct 01 10:07:25 atitlan caddy[40124]: 2019/10/01 10:07:25 [INFO] [surprise.example.com] AuthURL: https://acme-v02.api.letsencrypt.org/acme/authz-v3/587926880
Oct 01 10:07:25 atitlan caddy[40124]: 2019/10/01 10:07:25 [INFO] [surprise.example.com] acme: use tls-alpn-01 solver
Oct 01 10:07:25 atitlan caddy[40124]: 2019/10/01 10:07:25 [INFO] [surprise.example.com] acme: Trying to solve TLS-ALPN-01
Oct 01 10:07:26 atitlan caddy[40124]: 2019/10/01 10:07:26 [INFO] Unable to deactivated authorizations: https://acme-v02.api.letsencrypt.org/acme/authz-v3/587926880
Oct 01 10:07:26 atitlan caddy[40124]: 2019/10/01 10:07:26 [ERROR][surprise.example.com] failed to obtain certificate: acme: Error -> One or more domains had a problem:
Oct 01 10:07:26 atitlan caddy[40124]: [surprise.example.com] acme: error: 400 :: urn:ietf:params:acme:error:dns :: No valid IP addresses found for surprise.example.com, url:
Oct 01 10:07:26 atitlan caddy[40124]: (attempt 1/3; challenge=tls-alpn-01)
Oct 01 10:07:27 atitlan caddy[40124]: 2019/10/01 10:07:27 [INFO] [surprise.example.com] acme: Obtaining bundled SAN certificate
Oct 01 10:07:27 atitlan caddy[40124]: 2019/10/01 10:07:27 [INFO] [surprise.example.com] AuthURL: https://acme-v02.api.letsencrypt.org/acme/authz-v3/587927319
Oct 01 10:07:27 atitlan caddy[40124]: 2019/10/01 10:07:27 [INFO] [surprise.example.com] acme: use tls-alpn-01 solver
Oct 01 10:07:27 atitlan caddy[40124]: 2019/10/01 10:07:27 [INFO] [surprise.example.com] acme: Trying to solve TLS-ALPN-01
Oct 01 10:07:28 atitlan caddy[40124]: 2019/10/01 10:07:28 [INFO] Unable to deactivated authorizations: https://acme-v02.api.letsencrypt.org/acme/authz-v3/587927319
Oct 01 10:07:28 atitlan caddy[40124]: 2019/10/01 10:07:28 [ERROR][surprise.example.com] failed to obtain certificate: acme: Error -> One or more domains had a problem:
Oct 01 10:07:28 atitlan caddy[40124]: [surprise.example.com] acme: error: 400 :: urn:ietf:params:acme:error:dns :: No valid IP addresses found for surprise.example.com, url:
Oct 01 10:07:28 atitlan caddy[40124]: (attempt 2/3; challenge=tls-alpn-01)
Oct 01 10:07:28 atitlan caddy[40124]: 2019/10/01 10:07:28 [INFO] SIGQUIT: Quitting process immediately
Let me know if I can provide anything else to help out or if there is a friendlier solution for proxying from my proxy/frontend to my server at home. If it seems like a HAProxy headache, I don’t mind using something else.
