Hello! So I’m running Caddy2 to reverse_proxy https://octoprint.org/ and GitHub - jacksonliam/mjpg-streamer: Fork of http://sourceforge.net/projects/mjpg-streamer/. Works great for octoprint, however whenever I use the /webcam
path, cpu on spikes to 50%+ on one core.
*.example.com {
issuer zerossl {
disable_http_challenge
disable_tlsalpn_challenge
resolvers 1.1.1.1 8.8.8.8
dns cloudflare <key>
reverse_proxy localhost:5000
handle_path /webcam* {
reverse_proxy localhost:8080
While directly connecting to GitHub - jacksonliam/mjpg-streamer: Fork of http://sourceforge.net/projects/mjpg-streamer/, I see about 2-4% cpu usage on one core.
Note that I am running caddy v2 on a raspberry pi 4b 8gb, so perhaps arm64 is coming into play here? Either way, I’m surprised cpu spikes that much, though mjpeg does make a lot of requests. Do you think this is normal? Is there any optimizations to be had here in my config? Thanks!
