Handle_path being ignored when paired with handle in same block
v2.4.6
Ubuntu Server 18.04
caddy run --config /etc/caddy/Caddyfile
	email aditya@diwakar.io
	acme_dns cloudflare {env.CLOUDFLARE_AUTH}
aditya.diwakar.io {
	root * /var/www/html
*.diwakar.io *.aditya.diwakar.io {
	@api host api.aditya.diwakar.io api.diwakar.io
	handle @api {
		handle_path /cot* {
			redir "https://cot-reports.americas.diwakar.io{uri}"
			respond "api matched {host}{uri}"
*.americas.diwakar.io {
	@cot host cot-reports.americas.diwakar.io
	handle @cot {
		reverse_proxy 127.0.0.1:8756
I am trying to redirect all of the following api.aditya.diwakar.io/cot*, api.diwakar.io/cot*cot-reports.americas.diwakar.io/*. Essentially a simple domain change ignoring the /cot* prefix. The above configuration is what I believe should work, using handle_path that automatically would strip the prefix.
However, none of the URLs are getting matched with the handle_path, and instead are getting matched with the catch-all handle at the bottom of the api block. Running curl -iL https://api.aditya.diwakar.io/cot/disaggregated/067651 leads to:
HTTP/2 200
server: Caddy
content-length: 58
date: Sun, 12 Dec 2021 07:24:50 GMT
api matched api.aditya.diwakar.io/cot/disaggregated/067651
No error messages, just incorrect behavior as mentioned in 3.
Removing the second handle block in the handle @api block seems to fix the behavior and it correctly redirects to cot-reports.americas.diwakar.io/..., but it is not working with what I believe is the proper configuration. Of course, I am new to Caddy and could be making a silly mistake. Thanks! :smiley:
Interesting. If you adapt your config to JSON, you’ll see that your handle block gets sorted before the handle_path for some reason. That shouldn’t happen. There’s a bug in there somewhere. I’ll have to investigate later.
As a workaround, you can probably use route @api instead for the wrapping one, if you don’t need mutual exclusivity/fallback for the outer part.
Thanks @francislavoie for the response! I do unfortunately need a fallback on the outer subdomain. Do you know of any other workarounds in the meanwhile?
At first glance, I tried:
@cot path /cot*
handle @cot {
    uri strip_prefix /cot
    redir https://cot-reports.americas.diwakar.io{uri}
However, this doesn’t correctly redirect and cot still shows up in the redirected URL. Maybe I’m missing something?
With regard to a potential bug, should I go ahead and open a GitHub issue so this is tracked?
That’s okay, I’ll look into this right now, I have a hunch as to what’s going on. I’ll link back to this issue when I have a potential fix.
I think this might work:
@cot path_regexp cot ^/cot(.*)$
handle @cot {
	redir https://cot-reports.americas.diwakar.io{re.cot.1}?{query}
Francis, thank you :pray: (Been a bit busy over here lately.)
Sounds good, thanks. I was leaning towards path_regexp anyways. Glad I /potentially/ uncovered some unintended behavior.
Alright, found the problem, made a fix:
