Handle ordering does not work
v2.5.0 h1:eRHzZ4l3X6Ag3kUt8nj5IxATprhqKq/wToP7OHlXWA0=
Distributor ID:	Ubuntu
Description:	Ubuntu 20.04 LTS
Release:	20.04
Codename:	focal
caddy run --config ~/Caddyfile
x.com:443 {
    log
    @websockets {
        header Connection *Upgrade*
        header Upgrade websocket
        #: https://caddy.community/t/caddy-v2-how-to-proxy-websoket-v2ray-websocket-tls/7040/13
  handle_path /path {
    reverse_proxy @websockets localhost:10000 {
      header_up -Origin
     file_server browse {
        root {env.HOME}/Downloads
Without the last handle block, my reverse proxy works fine. But with that block added, nothing works (not the reverse proxy or the file server).
When looking at the adapted JSON config, it seems the last handle block is still matching on /path/. But I might be mistaken.
I tried changing the last handle block to handle / and hanle_path /, which made the reverse proxy work again, but the file server still did not work.
Path matching is exact in Caddy. You used handle_path /path which will only match requests to exactly /path and nothing else, not /path/foo etc.
What exactly are you trying to do? What request paths should serve what?
I had a misplaced }. This worked:
x.com:443 {
    # log
    @websockets {
   handle_path /path {
      header_up -Origin
