Loopios7
(Dan)
#1
Ubuntu 18.04.5 LTS with systemd service
n/a
Type=notify
dev.livefrom.space, livefrom.space {
root * /var/www/dev.livefrom.space
php_fastcgi unix//run/php/php8.0-fpm.sock
handle_errors {
respond "{http.error.status_code} {http.error.status_text}"
I get the index file as a response every time even for urls that don’t exist.
ex: https://livefrom.space/
and https://livefrom.space/page-that-does-not-exist
both return the index.php file in root directory.
n/a
I have tried to set root matching pattern to /
but then any css/
or js/
paths stop working.
This looks like pretty much the same question as this one earlier today:
Loopios7
(Dan)
#3
Thanks, I didn’t see that thread when looking for a solution.
The config I have now does what I wanted:
route {
# Add trailing slash for directory requests
@canonicalPath {
file {path}/index.php
not path */
redir @canonicalPath {path}/ 308
# If the requested file does not exist, try index files
@indexFiles file {
try_files {path} {path}/index.php
split_path .php
rewrite @indexFiles {http.matchers.file.relative}
# Proxy PHP files to the FastCGI responder
@phpFiles path *.php
reverse_proxy @phpFiles unix//run/php/php8.0-fpm.sock {
transport fastcgi {
split .php
handle_errors {
respond "{http.error.status_code} {http.error.status_text}" {http.error.status_code}
You can probably just use this:
php_fastcgi unix//run/php/php8.0-fpm.sock {
index off
Loopios7
(Dan)
#5
doing this resulted in the root path not returning the index file, you had to type out index.php in the url
Ah, in that case you can add this to cover it:
rewrite / /index.php
This will ensure only requests to the root will be rewritten by using a /
matcher.
system
(system)
closed
#7
