Handle_errors doesnot seem to be working?
I’m trying to use the example code from the docs to replicate the 404 behaviour. But cant seem to get it working.
curl : The remote server returned an error: (404) Not Found.
At line:1 char:1
+ curl https://www.indrajeethaldar.com/example.html
    + CategoryInfo          : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-WebRequest], WebEx
   ception
    + FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
installed it using the docs - the LTS version here Install — Caddy Documentation.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.2 LTS
Release: 22.04
Codename: jammy
The above html page does not exist
also started the caddy system with
sudo caddy start --config Caddyfile
indrajeethaldar.com {
        redir https://www.indrajeethaldar.com{uri}
www.indrajeethaldar.com {
        root * /home/indrajeet/portfolio
handle_errors {
        rewrite * /{err.status_code}
        reverse_proxy https://http.cat {
                replace_status {err.status_code}
Tried using this example handle_errors (Caddyfile directive) — Caddy Documentation
Directives must always be in a site block. You put handle_errors outside your site, so Caddy thinks you’re trying to configure handle_errors as one of your domain names.
Wait so where should I put the directives - the documentation dosent say anything about that
I think you will find this page helpful: :slight_smile:
