I have a caddy v1 to caddy v2 upgrade question.
I have this in V1 caddyfile.
gzip {
not /api/stream/
I have seen it is now encoding gzip, but how do I do the not part?
gzip {
not /api/stream/
Check out the upgrade guide!
To exclude certain requests, read up on request matchers:
I checked the upgrade guide and saw the matching thing, but I am not entirely sure how to utilize it properly. Is there any examples that shows more in-depth? But yes this is what I am looking for.
You’re looking to define a named matcher block, then you’ll configure it with a not matcher which will invert the path matcher.
