Docker Compose with Docker for Mac.
OS X Big Sur 11.2.2 (20D80)
caddy run --config /etc/caddy/config.json --resume
version: "3"
image: caddy
command: [ 'caddy', 'run', '--config', '/etc/caddy/config.json', '--resume' ]
- 127.0.0.1:8080:80
- 127.0.0.1:2019:2019
- ./caddy/config.json:/etc/caddy/config.json
"admin": {
"disabled": false,
"listen": "0.0.0.0:2019"
"apps": {
"http": {
"servers": {
"sites": {
"listen": [
":80"
"routes": [
"group": "site_daa01c0b-8b74-4098-9107-05592ad89eae",
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"handler": "headers",
"response": {
"set": {
"Cache-Control": [
"public",
"max-age=0",
"must-revalidate"
"encodings": {
"gzip": {
"level": 1
"handler": "encode",
"minimum_length": 0
"handler": "static_response",
"body": "Hi !"
"match": [
"host": [
"main.localhost"
When using the encode
handle configured with gzip
, I’m not seeing any Content-Encoding
headers added to the response. The docs mention that an encoding is selected when the Accept-Encoding
header is present. I’m assuming that when a single encoding is configured and no header is set, Caddy uses the only encoding configured.
I thought maybe the handler was used in the wrong place, but in the docs it seems it’s always used before the file_server
handler.
