Gzip does not work any more
Caddyserver does not use gzip compression any more. It was worked perfect
on Windows 10, using CaddyServer v2.8.9 but now I changed my PC (Windows 11 ) and it does not use gz files any more. There is no Content-encoding in the Response-headers and full js and css files are used, even if there are gz files.
I used 2.8.9, 2.9.0 and 2.9.1
Windows 11
caddy run --config Caddyfile
:88 {
		encode gzip zstd
		@static path /js/* /css/* /sync/*
    handle @static {
        file_server {
            precompressed gzip
			reverse_proxy localhost:4000 localhost:4001 localhost:4002 {
				lb_policy least_conn
        output file logfile.log
        format console
        level ERROR
    tls ..\pem.crt ..\key.key
There may be a conflict going on since you’re using encode AND precompressed. These are the details on precompressed.
If you are still having problems, give us the Caddy logs. You’ll need to add the global option debug before.
Hello
I removed precompressed and it still does not work. I’m focused on 2 files, all.js and all.css.
For both files, I have gz archive and like said, same Caddyfile worked on Windows 10.
log file is here:
http://simplest.icu/logfile.log.txt
Thank you for your help.
Can you please upload your Caddy logs?
I uploaded it there
I don’t know how to upload it right here.
