Intro
— Guard is an elegant IPQS plugin for Caddy. Acting as a middleware between your web server.
— Features are built in, you can tell Guard to intercept or to pass data to your web server.
Install
xcaddy build --with github.com/z3ntl3/caddyguard
Example
order guard before reverse_proxy
:2000 {
guard /api* {
rotating_proxy 1.1.1.1
timeout 3s
ip_headers cf-connecting-ip {
more1
more2
more3
pass_thru
reverse_proxy http://localhost:2000
Keep in mind that you need to order manually.
Caddyfile syntax
guard [matcher] {
rotating_proxy <arg>
timeout <arg>
ip_headers <args...> {
<arg>
<arg>
<arg>
pass_thru
Sub-directives
Doc
Should comfort net.http.
Supported protocols are
socks
,http
andhttps
If scheme is not provided,
http
is assumed.
Examples
guard /api* { rotating_proxy 1.1.1.1 }
Here
http://1.1.1.1
is assumed.
guard /api* { rotating_proxy socks5://1.1.1.1 }
Here
socks5://1.1.1.1
is assumed.NOTE
Underlying client may change. Proxifier > may be binded to this plugin. Which is our own low-level proxy client library. -
timeout <arg>
Doc
- Should comfort time.
Aka arg values like:
10s
,1m
etc…Examples
guard /api* { timeout 1s }
ip_headers <args...> {...}
Doc
- Can be arbitrary values. Tells Guard plugin to find the real ip address in one of those headers.
Values like:
cf-connecting-ip
,x-forwarded-for
and etc…, seem logicalExamples
guard /api* { ip_headers header1 { header2 } }
pass_thru
Doc
Accepts no args, and disallows opening a block. It acts like a turn on.Providing
pass_thru
simply means to pass data down to the next handler, aka your web server/reverse proxy instead of writing a HTTP response itself. Provides useful data by manipulating the request headers, while it moves down to the next handlers.If
pass_thru
is provided, then there are some important headers your web server should consume:X-Guard-* Headers
X-Guard-Success
If it is set to
1
, it means success otherwise-1
means false.X-Guard-Info
Contains explainatory description.
X-Guard-Query
The IP which got queried. Not present when
X-Guard-Rate
isUNKNOWN
.X-Guard-Rate
Either
DANGER | LEGIT | UNKNOWN
DANGER
Reports that the IP reputation is badLEGIT
Reports that the IP reputation is goodLEGIT
Reports that the IP reputation is unknown, aka scan failure. Typically exceededtimeout
constraints.
Additional notes
Guard uses InternetDB to perform scans. It’s completely free, and allows high traffic throughput. You can always use rotating_proxy
sub-directive with Guard to send rotated requests, to prevent rate limits if you require higher quota.
Determination of a bad IP happens in the following way:
- If InternetDB knows anything about the queried IP, then it is an IP with bad reputation.
Credits
— Programmed by z3ntl3, will be used at the revamped api.pix4.dev
