Would appreciate it if anybody can provide some insight. I tried looking on the forums and found a few threads, however none of the fixes worked for me.
I have guacamole set up internally at 192.168.2.3:8080
Caddy works great otherwise. I have a bunch of other things running through my reverse proxy that work. Guac is just the one that’s been giving me a hard time.
I checked the Caddy logs and did notice an error I hadn’t seen before:
2018/02/04 17:03:28 [timeouts] failed to get certificate: acme: Error 400 - urn:acme:error:malformed - Error creating new authz :: DNS name does not have enough labels
All of my other setups work fine though (I have around 10), so I’m not sure if this is contributing to the issue. I also changed the http to https, but that didn’t do anything either.
Thank you all for your help! I got this to work by tinkering around with unRAID. It turns out it wouldn’t work on the same IP as unRAID (presumably something else was occupying 8080 without me know). So what I did to fix the issue was use the br0 interface and assign Guacamole to 192.168.2.14 instead of the default 192.168.2.3. Works great! I hope this fixes the issue for anybody else that runs into the same problem.
I do have another question however. Would it be possible to bypass the login screen and go directly into the VM? I tried adding this to Caddyfile " proxy / http://192.168.2.14:8080/#/client/c/1 (this link goes directly to the VM when I’m logged in locally). Then I realized there’s the Guac front end I need to bypass. Any ideas?
I haven’t done it myself, but this looks like exactly what you’re after!
Guacamole normally enforces authentication, requiring all users to have a corresponding set of credentials. If you would rather just type in your server’s URL and gain access to your computer, you can do this with the “noauth” extension.
