Mac
caddy run --config CONFIG
N/A
I tried both
localhost {
reverse_proxy 192.168.64.36:31245
and
localhost {
reverse_proxy {
to h2c://192.168.64.36:31245
versions h2c 2
I have a service running with plaintext gRPC at 192.168.64.36:31245:
grpc-health-probe -addr=192.168.64.36:31245
status: SERVING
I’m trying to get Caddy to proxy to it. I tried both configurations above. Neither of them work (testing via GitHub - grpc-ecosystem/grpc-health-probe: A command-line tool to perform health-checks for gRPC applications in Kubernetes etc.):
$ grpc-health-probe -addr=localhost:80
timeout: failed to connect service "localhost:80" within 1s
$ grpc-health-probe -addr=localhost:443
timeout: failed to connect service "localhost:443" within 1s
$ grpc-health-probe -tls -tls-no-verify -addr=localhost:443
error: health rpc failed: rpc error: code = Unavailable desc = Bad Gateway: HTTP status code 502; transport: missing content-type field
$ grpc-health-probe -h
Usage:
-addr string
(required) tcp host:port to connect
-connect-timeout duration
timeout for establishing connection (default 1s)
-rpc-timeout duration
timeout for health check rpc (default 1s)
-service string
service name to check (default: "")
-tls
use TLS (default: false, INSECURE plaintext transport)
-tls-ca-cert string
(with -tls, optional) file containing trusted certificates for verifying server
-tls-client-cert string
(with -tls, optional) client certificate for authenticating to the server (requires -tls-client-key)
-tls-client-key string
(with -tls) client private key for authenticating to the server (requires -tls-client-cert)
-tls-no-verify
(with -tls) don't verify the certificate (INSECURE) presented by the server (default: false)
-tls-server-name string
(with -tls) override the hostname used to verify the server certificate
-user-agent string
user-agent header value of health check requests (default "grpc_health_probe")
-v verbose logs
I’m wondering what I miss. Thanks!
2021/01/30 01:34:08.758 INFO using provided configuration {"config_file": "Caddyfile", "config_adapter": ""}
2021/01/30 01:34:08.759 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["localhost:2019", "[::1]:2019", "127.0.0.1:2019"]}
2021/01/30 01:34:08.759 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc0003a9ab0"}
2021/01/30 01:34:08.759 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2021/01/30 01:34:08.760 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2021/01/30 01:34:08.775 INFO tls cleaned up storage units
2021/01/30 01:34:08.885 INFO pki.ca.local root certificate is already trusted by system {"path": "storage:pki/authorities/local/root.crt"}
2021/01/30 01:34:08.886 INFO http enabling automatic TLS certificate management {"domains": ["localhost"]}
2021/01/30 01:34:08.886 WARN tls stapling OCSP {"error": "no OCSP stapling for [localhost]: no OCSP server specified in certificate"}
2021/01/30 01:34:08.886 INFO autosaved config {"file": "/Users/owen/Library/Application Support/Caddy/autosave.json"}
2021/01/30 01:34:08.886 INFO serving initial configuration
2021/01/30 01:35:39.425 ERROR http.log.error net/http: HTTP/1.x transport connection broken: malformed HTTP response "\x00\x00\x06\x04\x00\x00\x00\x00\x00\x00\x05\x00\x00@\x00" {"request": {"remote_addr": "[::1]:49680", "proto": "HTTP/2.0", "method": "POST", "host": "localhost:443", "uri": "/grpc.health.v1.Health/Check", "headers": {"Grpc-Timeout": ["999971u"], "Content-Type": ["application/grpc"], "User-Agent": ["grpc_health_probe grpc-go/1.35.0-dev"], "Te": ["trailers"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "proto_mutual": true, "server_name": "localhost"}}, "duration": 0.001378605, "status": 502, "err_id": "pdfm91ysu", "err_trace": "reverseproxy.statusError (reverseproxy.go:783)"}
2021/01/30 01:37:22.692 ERROR http.log.error net/http: HTTP/1.x transport connection broken: malformed HTTP response "\x00\x00\x06\x04\x00\x00\x00\x00\x00\x00\x05\x00\x00@\x00" {"request": {"remote_addr": "[::1]:49696", "proto": "HTTP/2.0", "method": "POST", "host": "localhost:443", "uri": "/grpc.health.v1.Health/Check", "headers": {"Content-Type": ["application/grpc"], "User-Agent": ["grpc_health_probe grpc-go/1.35.0-dev"], "Te": ["trailers"], "Grpc-Timeout": ["999968u"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "proto_mutual": true, "server_name": "localhost"}}, "duration": 0.001004614, "status": 502, "err_id": "20k02j536", "err_trace": "reverseproxy.statusError (reverseproxy.go:783)"}
N/A
