Hi !
After a docker update and reboot, my configuration is a total mess, I can access to each docker but they don’t communicate between each other, rejecting direct access with “GET / HTTP/2.0” 301 errors in caddy’s logs.
apt-get update fails with this errors
Err:9 http://archive.ubuntu.com/ubuntu xenial/main amd64 Packages
404 Not Found [IP: 91.189.88.149 80]
W: The repository 'http://security.ubuntu.com/ubuntu xenial-security Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'http://archive.ubuntu.com/ubuntu xenial Release' does not have a Release file.
W: The repository 'http://archive.ubuntu.com/ubuntu xenial-updates Release' does not have a Release file.
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial/main/binary-amd64/Packages 404 Not Found [IP: 91.189.88.149 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-amd64/Packages 404 Not Found [IP: 91.189.88.149 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
simple curl command fails until I stop caddy docker image
curl -vIsSL https://agent.digitalocean.com/install.sh
* Trying 151.101.0.233...
* Connected to agent.digitalocean.com (151.101.0.233) port 443 (#0)
* found 168 certificates in /etc/ssl/certs/ca-certificates.crt
* found 672 certificates in /etc/ssl/certs
* ALPN, offering http/1.1
* SSL connection using TLS1.2 / ECDHE_RSA_AES_256_GCM_SHA384
* server certificate verification OK
* server certificate status verification SKIPPED
* SSL: certificate subject name (api.fame.community) does not match target host name 'agent.digitalocean.com'
* Closing connection 0
curl: (51) SSL: certificate subject name (api.fame.community) does not match target host name 'agent.digitalocean.com'
Here is my Caddyfile
www.laurentroger.com {
root /home/laurentroger.com
tls laurent@laurentroger.com {
max_certs 10
log /var/log/caddy/www.laurentroger.com
boiteauxcourses.laurentroger.com {
max_certs 10
log /var/log/caddy/boiteauxcourses.laurentroger.com
proxy / {
policy ip_hash
websocket
upstream http://xx.xx.xx.xx:pppp
backoffice.laurentroger.com {
log /var/log/caddy/backoffice.laurentroger.com
proxy / {
policy ip_hash
websocket
upstream http://xx.xx.xx.xx:ppppp
Any ideas what’s wrong and how to come back to a clean setup ?
I’ve setup a fresh new server, with just one caddy configuration, result is 502 (bad gateway)
x - - [29/Oct/2017:16:39:41 +0000] "GET /websocket HTTP/1.1" 502 16
x - - [29/Oct/2017:16:39:47 +0000] "GET / HTTP/2.0" 502 16
x - - [29/Oct/2017:16:40:01 +0000] "GET / HTTP/2.0" 502 16
x - - [29/Oct/2017:16:40:12 +0000] "GET /websocket HTTP/1.1" 502 16
x - - [29/Oct/2017:16:40:31 +0000] "GET /login/ HTTP/2.0" 502 16
x - - [29/Oct/2017:16:40:42 +0000] "GET /websocket HTTP/1.1" 502 16
Caddyfile is just
api.xxx.xxx {
log /var/log/caddy/api.xxx.xxx
proxy / {
policy ip_hash
websocket
upstream http://x.x.x.x:pppp
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.3 LTS
Release: 16.04
Codename: xenial
caddy from latest docker
docker run -d \
-v $(pwd)/Caddyfile:/etc/Caddyfile \
-v $(pwd)/logs:/var/log/caddy \
-v $HOME/.caddy:/root/.caddy \
-v /etc/ssl/certs:/etc/ssl/certs \
-p 80:80 -p 443:443 \
--name caddy \
abiosoft/caddy
