Global option for setting certificate issuer resolvers
1. The problem/doubt I’m having:
Hello,
As can be found in the documentation, to set the resolvers of the certificate issuers there are several options:
The question is: Is there any global option to configure the resolvers of all issuers like the tls directive? If I am not mistaken, currently the only alternative would be using the cert_issuer global option.
Thank you very much in advance.
Best regards.
Sorry for the delay, I had a busy week.
No, we only add global options for important/common options for issuers. For resolvers, you’ll need to either configure the issuers in global options, or use the tls directive (you can use snippets to copy it into each site)
