I run caddy on isaacs.site and I’m trying to run the Grav CMS. If you’re trying to access this domain right now I’ve commented out the entire isaacs.site block so the server will start back up again in the meantime. Same with :80
CentOS 8, PHP 7.3 FPM, no SELinux
experimental_http3
sync.isaacs.site {
reverse_proxy localhost:8384
encode zstd gzip
mail.isaacs.site, autodiscover.isaacs.site, autoconfig.isaacs.site {
reverse_proxy localhost:8080
encode zstd gzip
isaacs.site {
root * /var/www/isaacs.site
php_fastcgi / unix//run/php-fpm/www.sock
respond /403 "403 Forbidden" 403
# rewrite rules I'm having issues with, attempted to adapt from https://github.com/getgrav/grav/blob/develop/webserver-configs/Caddyfile but I have no idea what I'm doing
rewrite ^/(\.git|cache|bin|logs|backups|tests)/.*$ /403
# deny running scripts inside core system folders
rewrite /(system|vendor)/.*\.(txt|xml|md|html|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ /403
# deny running scripts inside user folder
rewrite /user/.*\.(txt|md|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ /403
# deny access to specific files in the root folder
rewrite /(LICENSE\.txt|composer\.lock|composer\.json|nginx\.conf|web\.config|htaccess\.txt|\.htaccess) /403
# global rewrite should come last.
rewrite {path} {path}/
rewrite * /index.php?_url={uri}&{query}
# trying to be the fallback server, instead redirects all websites on port 80
#:80 {
# respond "Hi there. You might want to be at https://isaacs.site."
I’m trying to run the Grav CMS. It seems like they haven’t updated the Caddyfile in a while (still v1) on the repo and none of the rewrite rules work. I’ve tried adapting them to the new format but I don’t know if we can even still use regex or if there’s a better way to do these rules that I’m missing.. nothing I’ve tried seems to help. This is the example Grav config: grav/webserver-configs/Caddyfile at develop · getgrav/grav · GitHub
In addition to this I’m also having problems with the :80 bracket below, I just want a default listener online for anything else that’s pointed to it but not configured with a simple message, self signed SSL is fine too.
validate: adapting config using caddyfile: parsing caddyfile tokens for 'rewrite': /etc/caddy/Caddyfile:20 - Error during parsing: Wrong argument count or unexpected line ending after '/403'
I tried escaping / in the rules, escaping ., adding ^ to the beginning, adding $ to the end, not sure what else I should be doing to get these to work..
For the :80 rule I’m having issues with I’ve tried changing it to localhost and *:80 but it continues to take over every host’s port 80 instead of just the undefined ones. Again I’m fine with SSL as well but I’d at least like non-SSL to work and display a page on undefined domains since that’s still the default request browsers do on a new URL.
