So I am in the process of setting up a Caddy reverse proxy server, in an LXC container (running clean standard Debian 9.7.1 stable, nothing else on there). Latest Caddy version as of yesterday, only used the Cloudflare TLS DNS plugin additional to the main Caddy download. This is my Caddyfile:
This yields the following result (swapped out my actual domain and scrambled the unique IDs for privacy reasons):
root@caddy:~# CLOUDFLARE_EMAIL=email@domain.com CLOUDFLARE_API_KEY=my_api_key caddy
Activating privacy features... 2019/03/04 09:30:37 [INFO] [test.domain.com] acme: Obtaining bundled SAN certificate
2019/03/04 09:30:38 [INFO] [test.domain.com] AuthURL: https://acme-v02.api.letsencrypt.org/acme/authz/-DoDVgmCQhf23l2if7KfVh3Fw9fzwOsm4xlLMaoLQZQ
2019/03/04 09:30:38 [INFO] [test.domain.com] acme: Could not find solver for: tls-alpn-01
2019/03/04 09:30:38 [INFO] [test.domain.com] acme: Could not find solver for: http-01
2019/03/04 09:30:38 [INFO] [test.domain.com] acme: use dns-01 solver
2019/03/04 09:30:38 [INFO] [test.domain.com] acme: Preparing to solve DNS-01
2019/03/04 09:30:38 [INFO] cloudflare: new record for test.domain.com, ID 0dofka1867ba2cjdk3958f6ee47aab73
2019/03/04 09:30:38 [INFO] [test.domain.com] acme: Trying to solve DNS-01
2019/03/04 09:30:38 [INFO] [test.domain.com] acme: Checking DNS record propagation using [192.168.1.10:53]
2019/03/04 09:30:38 [INFO] Wait for propagation [timeout: 2m0s, interval: 2s]
2019/03/04 09:30:38 [INFO] [test.domain.com] acme: Waiting for DNS record propagation.
2019/03/04 09:30:40 [INFO] [test.domain.com] acme: Waiting for DNS record propagation.
2019/03/04 09:30:42 [INFO] [test.domain.com] acme: Waiting for DNS record propagation.
2019/03/04 09:30:44 [INFO] [test.domain.com] acme: Waiting for DNS record propagation.
2019/03/04 09:30:46 [INFO] [test.domain.com] acme: Waiting for DNS record propagation.
2019/03/04 09:30:49 [INFO] [test.domain.com] acme: Waiting for DNS record propagation.
2019/03/04 09:30:56 [INFO] [test.domain.com] The server validated our request
2019/03/04 09:30:56 [INFO] [test.domain.com] acme: Cleaning DNS-01 challenge
2019/03/04 09:30:57 [INFO] [test.domain.com] acme: Validations succeeded; requesting certificates
2019/03/04 09:30:58 [INFO] [test.domain.com] Server responded with a certificate.
done.
https://test.domain.com
http://test.domain.com
WARNING: File descriptor limit 1024 is too low for production servers. At least 8192 is recommended. Fix with `ulimit -n 8192`.
Can you elaborate on how you run Caddy (what parameters, etc)?
Everything I’ve done is described in my original post, I haven’t changed any other settings. I installed Caddy using the bash install script (which I got straight from the main Caddy website). I haven’t changed anything other than I listed above. I have the Caddyfile in the home folder, I run as root user since it’s just a simple LXC container.
The DNS record in your Cloudflare dashboard points to the right origin server IP address
The A records of example.com indeed point to my server IP on the cloudflare webpage.
A direct request (such as via curl ) to your origin server returns a good result (i.e. valid certificate)
What command should I run exactly? If I do curl https://test.example.com I just get the source code of the Cloudflare error site, not sure what command I should run.
You need to override the DNS resolution that curl usually does in order to point it manually at the origin itself. The --resolve flag lets you manually specify an IP address to use for a port and hostname on a given request:
You could slightly modify from curl -IL to curl -ILX GET to fix that status 405, but suffice to say it’s connecting over HTTPS and not running into any validation issues, which is good.
So Caddy’s doing its job, which means it’s something wrong on the Cloudflare side of things. Try relaxing the SSL requirement from Strict to Full, make another connection attempt, and see what you get.
I have a feeling this issue might have to do with my old Synology box. I initially had a reverse proxy set-up there that didn’t work very well - and it handled a certificate for example.com (but NOT the CNAME of test.example.com). Perhaps that is what messing with it - because when I switch up Cloudflare to Full instead of Full (strict), go to test.example.com, I get a connection timeout error and I see that the URL port gets redirected to 5001, which is a Synology port. That is really strange…
Due to that 5001 port being added, I have a feeling that could be a factor here. Is there a way to reset the certficated? I can easily delete them from my Synology reverse proxy GUI, should I do that?
Additionally, is it OK to have port 80 forwarded to both my Synology box and also the new Caddy LXC container? That’s what I currently do (port 443 only goes to the Caddy server).
Is there a way to reset the certs and have my domain start from scratch with the certs in order to get everything working?
How can the the edge firewall decide which host to send those packets to? It has to send it to one. It makes no sense to duplicate/mirror the packets. So it will always send them to the first port forward on the list (I’m surprised it let you add the same port forward to multiple hosts).
My strong recommendation is to forward only to Caddy, then have Caddy reverse proxy your Synology box, if appropriate. Caddy’s very good at what it does, very simple, and makes accommodating less-than-simple apps like Synology’s GUI very straightforward.
With all that said, if port 443 only goes to Caddy already, I’m not sure how you ended up with a redirect to Synology unless Caddy or the Python upstream server issued that redirect. I’d definitely consider wiping the port forward list out and set up entries from scratch to ensure there’s no weirdness going on.
Aaaand that’s what the issue was! Port 443 was forwarded to both Caddy and the Synology box. Removing the Synology port forward was all it took to fix it. Yay! Thanks so much for your help.
