I’m simply trying to see if Caddy is working or not. I added a respond directive just to make sure I can reach my system. But I’m getting The page isn’t redirecting properly errors.
{"level":"info","ts":1694382120.2321503,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1694382120.2348268,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1694382120.2350545,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000328800"}
{"level":"info","ts":1694382120.2350945,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1694382120.2351086,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1694382120.2352796,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1694382120.2353582,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1694382120.2356315,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
{"level":"info","ts":1694382120.2358627,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1694382120.23593,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1694382120.2359698,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1694382120.2359867,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["links.sintan1729.uk"]}
{"level":"info","ts":1694382120.2367013,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1694382120.23671,"msg":"serving initial configuration"}
Running inside a Docker on AlmaLinux 9.2
docker compose up -d
caddy-cloudflare:
image: 'iarekylew00t/caddy-cloudflare:latest'
restart: always
- '80:80'
- '443:443'
- './caddy_data:/data'
- './caddy_config:/config'
- './Caddyfile:/etc/caddy/Caddyfile'
- proxy_network
proxy_network:
external: true
acme_dns cloudflare <REDACTED>
links.sntn1729.uk {
respond "Hi!"
