Get visitors IP instead of load balancer
I am getting the private IP address of my load balancer instead of the users actual IP.
N/A
I use Caddy within Docker.
Ubuntu 24.05, Docker
			roll_keep_for 90d
		format console {
			time_format wall
	servers :443 {
		listener_wrappers {
			http_redirect
			tls
	servers {
		max_header_size 4kb
		timeouts {
			read_body 10s
			read_header 10s
			write 10s
			idle 1m
http://localhost {
	respond /health "Caddy is up and healthy!" 200
{$APP_URL} {
	reverse_proxy php:8080 {
		# Health check
		health_uri /up
		health_interval 10s
		health_timeout 5s
You should configure the PROXY protocol on your load-balancer or ensure it sets X-Forwarded-For and configure the load-balancer’s IP address as trusted_proxy.
I’ve enabled Proxy Protocal on the load balancer and added trusted_proxies 10.0.0.0/16 to the servers secton in my Caddyfile but when I visit the site I get Secure Connection Failed
Is this incorrect?
It’s an or, not an and. If you configured the proxy protocol, tell Caddy it must check for it.
I did try using proxy_protocol earlier and then enabling Proxy Protocal on the LB but that doesn’t work either. I get the same " Secure Connection Failed" error when visiting the site. Same issue when I disabled Proxy Protocal on the LB.
I’ve also tried the trusted_proxies and get the same error as above.
So to confirm, I need to enable Proxy Protocal on the LB and add proxy_protocol or am I misunderstanding?
{"level":"debug","ts":1739815060.8913403,"logger":"http.stdlib","msg":"http: TLS handshake error from 10.0.0.2:26940: tls: first record does not look like a TLS handshake"}
Sorted
Please post your solution
