Get an SSL certificate when ports 80 and 443 are unavailable on OpenVZ and X-UI panel
I installed the X-UI panel on a VPS with OpenVZ Debian 10 OS.
IP is not personal. Only ports 15800-15820 are available.
By http://name.ru:port the panel opens. The task is to configure SSL for the domain.
I installed caddy, it seems to issue SSL automatically when I try to access http://name.ru:port
But not in my case, because... 443 is not available.
The command does not work: journalctl -u caddy --no-pager | less +G`
root@xui:~# caddy version
apt install -y debian-keyring debian-archive-keyring apt-transport-https curl
curl -1sLf ‘https://dl.cloudsmith.io/public/caddy/stable/gpg.key’ \
/etc/apt/trusted.gpg.d/caddy-stable.asc
curl -1sLf ‘https://dl.cloudsmith.io/public/caddy/stable/debian.deb.txt’ \
/etc/apt/sources.list.d/caddy-stable.list
echo “deb [trusted=yes] https://apt.fury.io/caddy/ /” \ | tee -a /etc/apt/sources.list.d/caddy-fury.list
apt update
sudo apt install caddy
Debian 10 Minimal Installing whithout docker
systemctl start caddy
        root * /usr/share/caddy
        # php_fastcgi localhost:9000
If you can’t expose your server publicly on ports 80 and 443, you’ll need to use the ACME DNS challenge to get a certificate.
See How to use DNS provider modules in Caddy 2
And Build from source — Caddy Documentation
