1. Output of caddy version
On a dedicated Linux VM
As a gate from internet to 3 servers (4 services), with reverse proxy
Also a filter on some countries with caddy-maxmind-geolocation
ubuntu 20.04
systemd
Paste command here.
sudo systemctl enable --now caddy
nothing more?
# Caddyfile
# 13/12/2022
(check_countries) {
@in_countries {
maxmind_geolocation {
db_path "/usr/share/GeoIP/GeoLite2-Country.mmdb"
allow_countries FR PT ES DK SE NL AT BE DE LU IE IT
(respond_out) {
respond "*** Sorry, page not available in this country \{geoip.country_code\} {ip} !!!***"
hestia.bris.fr {
import check_countries
handle @in_countries {
reverse_proxy http://hestia.lan.bris.fr:8080
respond "!!!*** Sorry, page not available in this country \{geoip.country_code\} ***"
crios.bris.fr {
reverse_proxy http://crios.lan.bris.fr:5000
import respond_out
atelier.bris.fr {
reverse_proxy http://atelier.lan.bris.fr:80
import respond_out
acros.i234.me {
reverse_proxy http://crios.lan.bris.fr:7000
import respond_out
I’m not able to add the geoip.country_code in the respond message
There is no country code for internal ip (I use a DNS to be able to use the domain names locally) and so I’m always in a wrong country from a local access
!!!*** Sorry, page not available in this country {geoip.country_code} ***
Dec 13 21:18:05 cerberus caddy[6442]: {"level":"debug","ts":1670962685.1557794,"logger":"http.matchers.maxmind_geolocation","msg":"Detected MaxMind data","ip":"192.168.9.1:60421","country":"","subdivisions":"","metro_code":0}
Dec 13 21:18:05 cerberus caddy[6442]: {"level":"debug","ts":1670962685.1562896,"logger":"http.matchers.maxmind_geolocation","msg":"Country not allowed","country":""}
Dec 13 21:18:05 cerberus caddy[6442]: {"level":"debug","ts":1670962685.2031455,"logger":"http.matchers.maxmind_geolocation","msg":"Detected MaxMind data","ip":"192.168.9.1:60421","country":"","subdivisions":"","metro_code":0}
Dec 13 21:18:05 cerberus caddy[6442]: {"level":"debug","ts":1670962685.2036147,"logger":"http.matchers.maxmind_geolocation","msg":"Country not allowed","country":""}
Dec 13 21:18:05 cerberus caddy[6442]: {"level":"debug","ts":1670962685.4172792,"logger":"http.matchers.maxmind_geolocation","msg":"Detected MaxMind data","ip":"80.12.102.168:39352","country":"FR","subdivisions":"","metro_code":0}
Dec 13 21:18:05 cerberus caddy[6442]: {"level":"debug","ts":1670962685.4177828,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"hestia.lan.bris.fr:8080","total_upstreams":1}
I’ve tried to change {} with @ and { }
with no success and \{ \}
Also put the {geoip.country_code} directly in the ‘respond’ message
Also tried to show ip
Perhaps the last post says it’s not possible, but I’m not sure to understadn everything
