Geofilter and blocked paths with white listed ip, static html returning zero bytes
I have a simple geofilter to block any country other that AU (Australia).
I have 2 restricted folders /analytics and /help to everyone except 1 ip
Both /analytics and /help have static html pages and no errors are return, just a zero byte page.
These static pages were working today before I discovered I have incorrectly configured the geofilter (didn’t have the not maxmind_geolocation).
Reverted this change but still the static pages return zero size.
What is wrong with my config?
	"level": "info",
	"ts": 1728446643.680025,
	"logger": "http.log.access.log0",
	"msg": "NOP",
	"request": {
		"remote_ip": "139.99.231.218",
		"remote_port": "57365",
		"client_ip": "139.99.231.218",
		"proto": "HTTP/2.0",
		"method": "GET",
		"host": "opsdev.systems368.com",
		"uri": "/help/fault_type_help.html",
		"headers": {
			"Accept-Language": [
				"en;q=0.6"
			"Sec-Ch-Ua-Mobile": [
				"?0"
			"Sec-Ch-Ua-Platform": [
				"\"Windows\""
			"Sec-Fetch-Site": [
				"none"
			"Accept-Encoding": [
				"gzip, deflate, br, zstd"
			"Cache-Control": [
				"max-age=0"
				"1"
			"Sec-Fetch-Mode": [
				"navigate"
			"Sec-Fetch-User": [
				"?1"
			"Sec-Ch-Ua": [
				"\"Brave\";v=\"129\", \"Not=A?Brand\";v=\"8\", \"Chromium\";v=\"129\""
			"Accept": [
				"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8"
			"Sec-Fetch-Dest": [
				"document"
			"Cookie": [
				"REDACTED"
			"Priority": [
				"u=0, i"
			"User-Agent": [
				"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36"
			"Sec-Gpc": [
				"1"
		"tls": {
			"resumed": false,
			"version": 772,
			"cipher_suite": 4865,
			"proto": "h2",
			"server_name": "opsdev.systems368.com"
	"bytes_read": 0,
	"user_id": "",
	"duration": 0.000063194,
	"size": 0,
	"status": 0,
	"resp_headers": {
		"Server": [
			"Caddy"
		"Alt-Svc": [
			"h3=\":443\"; ma=2592000"
Ubuntu 24.04.1 LTS
systemctl start caddy.service
Type=notify
(common) {
        encode zstd gzip
opsdev.systems368.com {
         import common
        @geofilter {
            not maxmind_geolocation {
            db_path "/usr/share/GeoIP/GeoLite2-Country.mmdb"
            allow_countries AU
          respond @geofilter "Whoopsie...."  403
        file_server @geofilter {
           root  /var/www/html
        @blocked {
             path /analytics/* /help/*
             not remote_ip 139.99.231.218
        respond @blocked "The Computer Says No..." 403
        reverse_proxy /rpc/* localhost:3000
        reverse_proxy /ws localhost:7890
        reverse_proxy /places/* localhost:5000
        reverse_proxy /authusers/* localhost:4000
                output file /var/log/caddy/caddy.log {
                        roll_size 100mb
                        roll_keep 2
                        roll_keep_for 48h
Please run caddy fmt -w on your config. Your indentation is very messy, so it’s hard to follow what your config is trying to do.
This means that Caddy did not run any handlers to write a response for that request. Your matchers result in the request falling through without matching any handler.
Keep in mind, directives are sorted according to the directive order, which means all respond will be tried before all reverse_proxy, before all file_server.
Okay, I’ve run that. the new config is
(common) {
encode zstd gzip
import common
    @geofilter {
                    allow_countries AU
            root /var/www/html
    @blocked {
                    roll_size 100mb
                    roll_keep 2
                    roll_keep_for 48h
Use triple backticks ``` (the key to the left of 1 on US keyboards), not triple quotes for code blocks. Or just click the </> button.
But like I said, you need to think through your matchers and the order in which your directives run. I don’t have a clear understanding of your goal, but that request clearly didn’t match any of your existing matchers so it fell through unhandled.
apologies,
(common) {
        encode zstd gzip
        import common
        @geofilter {
                        allow_countries AU
                root /var/www/html
        @blocked {
                        roll_size 100mb
                        roll_keep 2
                        roll_keep_for 48h
Okay, to give you a better understanding:
I have a flutter app that is working well despite the issues I am having with the static html.
the /analytics is running goaccess so I can monitor who/what i accessing my api service.
the /help is the internal help information for users, and I don’t really want that exposed to the whole internet/siders/crawlers et al.
I absolutely love Caddy (been working with it for since it’s inception, and I am stretching my capabilities to get it to do what I want… and at the same time build out my app…)… happy to engage a professional to make it happen
Whew, this logic is a bit hard to follow.
You’re responding 403 to this matcher - and then file serving to the same matcher? Surely that can’t be the behaviour you want, right?
I wonder if you wouldn’t be better off, logically speaking, separating things into mutually exclusive handle blocks. Something like:
example.com {
  @australia maxmind_geolocation {
    allow_countries AU
  handle @australia {
    # Do stuff in this section for Australian users
    # Do stuff in this section for everyone else
  # Do stuff for all users outside the handles
Remember that the point of all code and config is not for the benefit of the machine to understand it; the purpose is for the human to be able to read and understand what you’re making the machine do. Structures like the above can help make it more obvious how you’re handling things.
Thanks for the advice and your approach is a good one. At the moment, I’ve restructured using snippets and it now seems to work.
config now looks likes this:
(geofilter) {
    @geofilter {
        allow_countries AU
(block_paths) {
    @blockedPaths {
    respond @blockedPaths "The Computer Says No..." 403
(common) {
    import common
    import geofilter
    import block_paths
    root * /var/www/html
                roll_size 100mb
                roll_keep 2
                roll_keep_for 48h
