Caddyfile
Debian 10 via systemd, installed using official Debian repo
PHP 7.4.14 (cli) (built: Jan 12 2021 13:59:46) ( NTS )
sudo systemctl start caddy
https://support.millhousen.tech {
root * /var/www/html/support.millhousen.tech/public
output file /tmp/caddy.log
format console
Site returns 500 Internal Server Errors
1.6112718672741082e+09 error http.log.access.log0 handled request {“request”: {“remote_addr”: “198.232.120.195:53742”, “proto”: “HTTP/2.0”, “method”: “GET”, “host”: “support.millhousen.tech”, “uri”: “/”, “headers”: {“Sec-Fetch-Dest”: [“document”], “Accept-Encoding”: [“gzip, deflate, br”], “User-Agent”: [“Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/88.0.4324.96 Safari/537.36”], “Accept”: [“text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,/;q=0.8,application/signed-exchange;v=b3;q=0.9”], “Sec-Gpc”: [“1”], “Sec-Fetch-Site”: [“none”], “Sec-Fetch-Mode”: [“navigate”], “Sec-Fetch-User”: [“?1”], “Accept-Language”: [“en-US,en;q=0.9”], “Upgrade-Insecure-Requests”: [“1”]}, “tls”: {“resumed”: false, “version”: 772, “cipher_suite”: 4865, “proto”: “h2”, “proto_mutual”: true, “server_name”: “support.millhousen.tech”}}, “common_log”: “198.232.120.195 - - [21/Jan/2021:23:31:07 +0000] "GET / HTTP/2.0" 500 591”, “duration”: 0.040016708, “size”: 591, “status”: 500, “resp_headers”: {“Content-Encoding”: [“gzip”], “Vary”: [“Accept-Encoding”], “Server”: [“Caddy”], “Cache-Control”: [“no-cache, private”], “Date”: [“Thu, 21 Jan 2021 23:31:07 GMT”], “Content-Type”: [“text/html; charset=UTF-8”], “Status”: [“500 Internal Server Error”]}}
I tried searching for configs in order to match the Nginx config provided by the Freescout team (a Laravel app), but most of the time the discussion ended up simplifying the config to what I already have.
Maybe the Nginx config for Freescout is different than that of other Laravel apps?
