Forwardproxy do not block websites
I`ve built Caddy with forwardproxy plugin from the caddy2 branch using that command
xcaddy build --with github.com/caddyserver/forwardproxy@caddy2
I added the blocked website in Caddyfile.
I am launching Caddy on my local machine.
But when I go to a blocked website via a browser, it works as usual.
no errors
{"level":"info","ts":1691700550.863602,"msg":"using provided configuration","config_file":"./Caddyfile","config_adapter":""}
{"level":"warn","ts":1691700550.8641882,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"./Caddyfile","line":5}
{"level":"info","ts":1691700550.869654,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1691700550.869654,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1691700550.869654,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1691700550.869654,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0004d3380"}
{"level":"info","ts":1691700550.869654,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:C:\\Users\\ыва\\AppData\\Roaming\\Caddy"}
{"level":"info","ts":1691700550.8702059,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1691700550.8702059,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1691700550.8702059,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1691700550.8707547,"msg":"autosaved config (load with --resume flag)","file":"C:\\Users\\ыва\\AppData\\Roaming\\Caddy\\autosave.json"}
{"level":"info","ts":1691700550.8707547,"msg":"serving initial configuration"}
{"level":"info","ts":1691700550.8707547,"logger":"tls","msg":"finished cleaning storage units"}
v2.7.2 h1:QqThyoyUFAv1B7A2NMeaWlz7xmgKqU49PXBX08A+6xg=
clone a relevant master branch
Windows 10
route {
	forward_proxy {
		basic_auth user1 0NtCL2JPJBgPPMmlPcJ
		ports 80 443
		acl {
			deny facebook.com agame.com
			allow all
