1. Output of caddy version:
As a systemd service (systemctl)
Stock debian 11, with caddy as a debian package
caddy reload
2022/10/28 18:50:11.337 INFO using adjacent Caddyfile
$ cat /lib/systemd/system/caddy.service
# caddy.service
# for your installation.
Type=notify
$ cat /etc/caddy/Caddyfile
# Caddyconfig
kitsunehosting.net {
# RP to lsio
reverse_proxy 10.85.3.10:433
Hello all and thanks for taking a look at this with me! Im trying to migrate myself to caddy from a nginx/linuxserverio approach, but I have so many configs and subdomains, i’d like to take things one step at a time.
I want to point caddy to the old reverse proxy first, and slowly move everything over to just native caddy, I’m not exactly sure how to do this, I really want to forward just.. everything over? Ultimately I’m trying to host two domains at once and I think I can do that with caddy and i’d also just like to simplify my setup, the docker+nginx setup was getting super bloated..
I explained this a little long winded, what Im asking rn is: how do i reverse proxy just one domain (or subdomain) to an existing reverse proxy?
I did try a bunch! i looked at the docs and played around with getting the reverse proxy keywords to just point to my old rp or even a simple webserver, but, so far no luck, and by no luck I mean I either get a “cant be reached” or “SSL error” The way I’ve set my network up I have the old, and the new caddy RP right next to each other, so for testing I’ve just been sliding the port forwarding over to point at caddy
I was able to get this to work:
$ cat Caddyfile
# Caddyconfig
# RP to lsio
#reverse_proxy 10.85.3.10:433
respond "Hello, world!"
So I can at least be sure that caddy is visible from the outside!
