Sorry for newbie question
I tried to set-up the caddy forward proxy listening on two ports (1234 and 1235). Adding the forward package did work.
I want to achieve that if the proxy is called on one port the proxy should forward the request.
Accessing the proxy on the other port the proxy should not permit the access and maybe also return a custom html.
To test the scenario i configured windows proxy config to use either port 1234 or port 1235.
But when i type in an url in the webbrowser the custom html never shows up.
Also tried to setup the second port with "respond “no access” 403. But the respond is not shown.
Caddy is running in a virtual machine with Ubuntu 20.04 where the ip of the machine is 192.168.1.99
caddy add-package github.com/caddyserver/forwardproxy
above did install successfully
192.168.1.99:1234 {
output stdout
route {
forward_proxy {
basic_auth user2 asdf
192.168.1.99:1235 {
output stdout
file_server {
root /var/www/html/custom.html
