I am trying to configure logging to POST logs to localhost:5403/logs/
level INFO
output net localhost:5403/logs/
format json
I understand why this doesn’t work, since “Caddy network addresses are not URLs.” (Conventions — Caddy Documentation). I wonder if there is some conventional way of handling this use case.
Error: loading initial config: loading new config: setting up custom log 'log1': opening log writer using &logging.NetWriter{Address:"localhost:5403/logs/", DialTimeout:0, addr:caddy.NetworkAddress{Network:"localhost:5403", Host:"logs/", StartPort:0x0, EndPort:0x0}}:
dial localhost:5403: unknown network localhost:5403
v2.6.3
caddy run --config .\Caddyfile
Windows
