1. Output of caddy version:
Caddy downloaded with the dns-cloudflare add on from the official website
Ubuntu 22.04, running Caddy with systemd
sudo service caddy start
It’s the default file
admin off
acme_dns cloudflare <cloudflare_api_token_here>
(errors) {
handle_errors {
root * /var/www/internal/errors
rewrite * /{http.error.status_code}.html
(logging) {
output file /var/log/caddy/caddy.log {
roll_size 15mb
roll_keep 20
(php) {
php_fastcgi unix//run/php/php8.1-fpm.sock
www.telesphoreo.me {
import logging
redir https://telesphoreo.me{uri}
telesphoreo.me {
import logging
import errors
import php
root * /var/www/telesphoreo.me
file_server browse
encode gzip zstd
@denied path /assets/ /old_html/* /new_html/* /recyclebin/* /nitrogen/ /nexus/ /wave/
error @denied 403
blog.telesphoreo.me {
import logging
import php
root * /var/www/blog.telesphoreo.me
db2.telesphoreo.me {
import logging
import php
root * /usr/share/phpmyadmin
git.telesphoreo.me {
import logging
reverse_proxy http://localhost:3000
nexus.telesphoreo.me {
import logging
reverse_proxy http://localhost:8082
docker.telesphoreo.me {
import logging
reverse_proxy http://localhost:18444
panel.telesphoreo.me {
import logging
import php
root * /var/www/pterodactyl/public
header X-Content-Type-Options nosniff
header X-XSS-Protection "1; mode=block"
header X-Robots-Tag none
header Content-Security-Policy "frame-ancestors 'self'"
header X-Frame-Options DENY
header Referrer-Policy same-origin
request_body {
max_size 100m
respond /.ht* 403
pictochat.telesphoreo.me {
import logging
reverse_proxy http://localhost:8080
wordle.telesphoreo.me {
import logging
root * /var/www/wordle.telesphoreo.me/games/wordle
ci.plex.us.org {
import logging
reverse_proxy http://localhost:8081 {
trusted_proxies 173.245.48.0/20 103.21.244.0/22 103.22.200.0/22 103.31.4.0/22 141.101.64.0/18 108.162.192.0/18 190.93.240.0/20 188.114.96.0/20 197.234.240.0/22 198.41.128.0/17 162.158.0.0/15 104.16.0.0/13 104.24.0.0/14 172.64.0.0/13 131.0.72.0/22
discord.plex.us.org {
import logging
redir https://discord.gg/MzjRjFAcrZ
forum.plex.us.org {
import logging
redir https://plex.us.org{uri}
git.plex.us.org {
import logging
redir https://git.telesphoreo.me{uri}
httpd.plex.us.org {
import logging
reverse_proxy 172.18.0.1:27192
plan.plex.us.org {
import logging
reverse_proxy 172.18.0.1:8804
staging-docs.plex.us.org {
import logging
root * /var/www/plexus.org/build
plex.us.org {
import logging
import php
try_files {path} /index.php
root * /var/www/xenforo
respond /.ht* 403
scissors.gg {
import logging
import errors
handle /javadoc* {
root * /var/www/scissors.gg/build
try_files {path} /index.html
www.scissors.gg {
import logging
redir https://scissors.gg{uri}
vw.skyline.to {
import logging
reverse_proxy /notifications/hub/negotiate localhost:6120
reverse_proxy /notifications/hub localhost:3012
reverse_proxy localhost:6120 {
header_up X-Real-IP {>CF-Connecting-IP}
X-Frame-Options "DENY"
X-Robots-Tag "none"
-Server
Basically, I am reverse proxying a Vaultwarden instance (vw.skyline.to). The problem is, it’s behind a Cloudflare proxy and the IP addresses come from Cloudflare. This is a well known and documented problem, but there is a CF-Connecting-IP header passed which does have the users IP address. Unfortunately, I’m not finding a way to send this. In Vaultwarden, if I set the header as CF-Connecting-IP, it says no match (i.e. Caddy is not forwarding it at all). I can use X-Forwarded-To just fine, or add a X-Real-IP header to the Caddyfile (which is the Vaultwarden default). I can find very little on how to tell Caddy to use CF-Connecting-IP as the IP of the visitor. I found this ancient thread from Caddy v1 (Cloudflare: Can Caddy restore the real visitors IP address somehow? (CF-Connecting-IP)), but it appears that this does not work anymore. I used the syntax from Caddy v1, but instead of header_upstream used header_up. It still was using the Cloudflare proxies IP. I’d also like to know if there’s a way to have it apply globally, instead of just to one reverse proxy.
There are no error messages
I thought that setting up the Cloudflare DNS extension for Caddy was the solution, but apparently not. Also, research from previous threads. There was something called “realip” in Caddy v1, but all of the docs now return a 404.
