Forward Auth setup issue with Authelia
403 Forbidden
Docker Compose
  # Disable admin interface (optional, comment out if needed)
  # admin off
  # Email address for certificate management (replace with your actual email)
  email {env.CLOUDFLARE_EMAIL}
          roll_size 10MB
          roll_keep 10
          roll_keep_for 336h
      format json
  acme_dns cloudflare {env.CLOUDFLARE_API_TOKEN}
  acme_ca https://acme-v02.api.letsencrypt.org/directory
  servers {
      trusted_proxies cloudflare {
          interval 12h
          timeout 15s
  dynamic_dns {
      provider cloudflare {env.CLOUDFLARE_API_TOKEN}
      domains {
          mydomain.com
      check_interval 5m
(mybasicauth) {
  tls pkpamarthy@gmail.com {
  encode gzip zstd
  reverse_proxy 192.168.3.199:{args[0]}
(protected_endpoint) {
    forward_auth {args[0]} 192.168.3.199:9091 {
        uri /api/authz/forward-auth
        copy_headers Remote-User Remote-Groups Remote-Email Remote-Name
auth.mydomain.com {
  reverse_proxy 192.168.3.199:9091
  #import mybasicauth "9091"
adguard.mydomain.com {
  forward_auth 192.168.3.199:9091 {
        #uri /api/authz/forward-auth
        ## The following commented line is for configuring the Authelia URL in the proxy. We strongly suggest
        ## this is configured in the Session Cookies section of the Authelia configuration.
        #uri /api/authz/forward-auth?authelia_url=https://auth.mydomain.com/
        uri /api/verify?rd=https://auth.mydomain.com
   #uri /api/verify?rd=https://auth.domain.dev
  import mybasicauth "9080"
portainer.mydomain.com {
  import mybasicauth "9000"
photos.mydomain.com {
  import mybasicauth "8212"
mycloud.mydomain.com {
#  proxy / nextcloud-aio {
#    upstream 192.168.3.199:8680
#  redir http:// {uri} https://
  tls pkapamarthy@gmail.com
  reverse_proxy http://192.168.3.199:12000
I have installed authelia and able to access it using auth.mydomain.com and login with 2FA authentication. What I am struggling with is to setup redirection to auth.mydomain.com using the Forward_Auth commands. I want caddy to redirect me to auth page when I try to access adguard.mydomain.com and after successful authentication, bring me back to adguard login page. At the moment, I am running into 403 Forbidden error when I access adguard.mydomain.com but if i remove the forward auth stuff, direct access to adguard login works without issues.
My authelia config file:
# Miscellaneous https://www.authelia.com/configuration/miscellaneous/introduction/
server:
  address: 'tcp://0.0.0.0:9091/'
  buffers:
    read: 4096
    write: 4096
  endpoints:
    authz:
      forward-auth:
        implementation: 'ForwardAuth'
  #endpoints:
  #  enable_pprof: false
  #  enable_expvars: false
  #disable_healthcheck: false
#host: 127.0.0.1
#port: 9091
log:
  level: info
#default_redirection_url: https://auth.mydomain.com
totp:
  issuer: mydomain.com
authentication_backend:
  ldap:
    implementation: custom
    url: ldap://ldap.mydomain.com:389
    start_tls: false
    base_dn: dc=ldap,dc=mydomain,dc=com
    additional_users_dn: cn=users
    additional_groups_dn: cn=groups
    user: 'uid=root,cn=users,dc=ldap,dc=mydomain,dc=com'
    password: 'o'
    #users_filter:   (&(|({username_attribute}={input})({mail_attribute}={input}))(objectClass=person))
    users_filter: '(&({username_attribute}={input})(objectClass=person))'
    permit_referrals: false
    permit_unauthenticated_bind: false
    groups_filter: (&(member={dn})(objectclass=posixGroup))
    #groups_filter: (&(uniquemember={dn})(objectclass=groupOfUniqueNames))
    attributes:
      username: 'uid'
      display_name: 'gecos'
      mail: 'mail'
      group_name: 'cn'
session:
  cookies:
    - domain: 'mydomain.com'
      authelia_url: 'https://auth.mydomain.com'
      default_redirection_url: 'https://dsm.mydomain.com'
#  redis:
#   host: redis
#   port: 6379
  expiration: 1h
  inactivity: 5m
regulation:
  max_retries: 3
  find_time: 2m
  ban_time: 5m
storage:
  postgres:
    host: database
    database: authelia
    username: authelia
#  local:
#    path: /var/lib/authelia
# SMTP Notifier https://www.authelia.com/configuration/notifications/smtp/
# Set also AUTHELIA_NOTIFIER_SMTP_PASSWORD_FILE
notifier:
  smtp:
    host: smtp.gmail.com
    port: 587
    sender: 'Authelia <myemail@gmail.com>'
    username: myemail@gmail.com
access_control:
  default_policy: deny
  rules:
    - domain: '*.mydomain.com'
      policy: two_factor
      resources:
        - https://dsm.mydomain.com
        - https://photos.mydomain.com
        - https://mycloud.mydomain.com
        - https://adguard.mydomain.com
  #rules:
    ## bypass rule
  #  - domain:
  #      - "auth.mydomain.com"
  #    policy: bypass
    ## catch-all
  #  - domain:
  #      - "*.domain.com"
  #    subject:
  #      - "group:admins"
  #    policy: one_factor
I don’t see any evidence of a problem with Caddy. It doesn’t help that you didn’t properly fill out the help topic template as per the forum rules. We need to see logs and example requests to show the behaviour.
You’re probably better off asking for help from the Authelia community, they’ll be able to help you with your Authelia config.
