Forward_auth Requires seperate authentication for user and website?
I have caddy established as a reverse proxy with authelia for authentication. This works fine for the most part. Just recently, I launched a new application that comes in two parts: a UI and an API. When visiting the UI, I’m redirected to authelia for authenication. After that, I visit the UI like normal.
However, I also made sure that the API was behind authelia. I figured that a user authenticated with the UI would be able to authorize themselves for API use as well.
Whats weird to me is that the UI’s network requests to the API are being redirected to the authentication portal. This is background traffic that the UI uses… surely it would piggy back off the users authentication? I guess not.
I have no errors, just unexpected behavior. The API calls from my UI are being directed to the auth portal, even though the user is already authenticated.
ARG CADDY_VERSION=2.7.6
FROM caddy:${CADDY_VERSION}-builder AS builder
RUN xcaddy build \
    --with github.com/caddy-dns/route53
FROM caddy:${CADDY_VERSION}-alpine
I am running Caddy in Docker. This is my docker file:
# Route53 plugin
(tls_config) {
    dns route53 {
      max_retries 10
# Authelia SSO Portal
auth.company-bi.com {
  import tls_config
  reverse_proxy 10.0.2.250:9091
# Schedule app
schedule.company-bi.com, schedule-api.company-bi.com {
  import tls_config
  forward_auth 10.0.2.250:9091 {
    uri /api/authz/forward-auth
    copy_headers Remote-User Remote-Groups Remote-Email Remote-Name
  reverse_proxy http://internal-main-alb-1928384756.us-west-1.elb.amazonaws.com {
I am sure this is just some kind of configuration issue. Without exposing my API to unauthenticated users, how should I make sure the UI can use the API via the users existing authentication info?
The UI is the client for the API?
Authelia sets an authelia_session cookie on a successful login, to authenticate each subsequent request: Session | Configuration | Authelia
The client (i.e. the UI code) will need to include this cookie when sending API requests to a protected backend. I don’t think the browser would automatically include this cookie like it would for normal browsing activity.
I think it’s because you’re using separate domains for the API and UI, so the cookie was only set for the UI domain but not for the API domain. I think you can configure Authelia to have it set the cookie for other domains as well.
