Really pedantic issue but the emojis in this forum have a white background when used in reactions, which clashes with the dark theme. Here’s an example of how this looks:
FWIW I use https://darkreader.org/ and it’s not a problem for me
But that said, it’s not something we can fix, really. The plugin we use for emoji reactions is GitHub - gdpelican/retort: A reactions plugin for Discourse if you want to report it there.
Curious. It says here that this issue is fixed. Maybe when the plugin needs to be updated on the server?
We’re using the latest version as far as I can tell, v1.2.3
Well I’ve opened an issue there for some clarification. I suspect they will need some clarification on the setup there.
This topic was automatically closed after 90 days. New replies are no longer allowed.
