I have configured a CA that caddy need to use to generate certificates however as discussed here caddy doesn’t generate the fullchain for the host. Using the suggested approach to listen to cert_obtained, I can successfully generate the fullchain certificate for each host. However from inside the script, I can’t let caddy reload these certs.
As you can see in the logs below, there is no indication of re-caching certificates and certificate hash is the same (when generated and when requested with openssl s_client -showcerts -connect wnaji.local:443 (wnaji.local points to the ip address of the machine in /etc/hosts locally)
I have tried visiting the website as well, it only shows the caddy-root.crt and the caddy generated cert.
I logged in to the container to check /data/caddy/certificates/local/wnaji.local/wnaji.local.crt and it is already merged with the fullchain so the script is working ok but caddy is not revalidating the certificates cache.
Deleted some messages from security logger (too long post)
{"level":"info","ts":1735515098.5544586,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1735515098.561638,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1735515098.5658405,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0016e8280"}
{"level":"info","ts":1735515098.5715077,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1735515098.5715418,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"warn","ts":1735515098.5715597,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv1","http_port":80}
{"level":"debug","ts":1735515098.5716536,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{"subjects":["wnaji.local"]},{}]}},"http":{"servers":{"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"REAL_HOST":"{http.request.host}","handler":"vars"},{"REAL_IP":"{http.request.remote.host}","handler":"vars"}]},{"handle":[{"REAL_HOST":"{http.request.header.X-Forwarded-Host}","handler":"vars"}],"match":[{"header":{"X-Forwarded-Host":["*"]}}]},{"handle":[{"REAL_IP":"{http.request.header.Cf-Connecting-Ip}","handler":"vars"}],"match":[{"header":{"Cf-Connecting-Ip":["*"]}}]},{"handle":[{"handler":"headers","response":{"set":{"X-Served-By":["Grafana"]}}},{"handler":"authentication","providers":{"authorizer":{"gatekeeper_name":"admins_policy","route_matcher":"*"}}}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"grafana:3000"}]}],"match":[{"header":{"Connection":["*Upgrade*"],"Upgrade":["websocket"]}}]},{"handle":[{"handler":"reverse_proxy","headers":{"request":{"set":{"Host":["{http.vars.REAL_HOST}"],"X-Real-Ip":["{http.vars.REAL_IP}"]}}},"upstreams":[{"dial":"grafana:3000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"authenticator","portal_name":"admin_portal","route_matcher":"*"}]}]}],"match":[{"path":["*"]}]}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"REAL_HOST":"{http.request.host}","handler":"vars"},{"REAL_IP":"{http.request.remote.host}","handler":"vars"}]},{"handle":[{"REAL_HOST":"{http.request.header.X-Forwarded-Host}","handler":"vars"}],"match":[{"header":{"X-Forwarded-Host":["*"]}}]},{"handle":[{"REAL_IP":"{http.request.header.Cf-Connecting-Ip}","handler":"vars"}],"match":[{"header":{"Cf-Connecting-Ip":["*"]}}]},{"handle":[{"handler":"headers","response":{"set":{"X-Served-By":["Loki"]}}},{"handler":"authentication","providers":{"authorizer":{"gatekeeper_name":"admins_policy","route_matcher":"*"}}}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"loki:3100"}]}],"match":[{"header":{"Connection":["*Upgrade*"],"Upgrade":["websocket"]}}]},{"handle":[{"handler":"reverse_proxy","headers":{"request":{"set":{"Host":["{http.vars.REAL_HOST}"],"X-Real-Ip":["{http.vars.REAL_IP}"]}}},"upstreams":[{"dial":"loki:3100"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"REAL_HOST":"{http.request.host}","handler":"vars"},{"REAL_IP":"{http.request.remote.host}","handler":"vars"}]},{"handle":[{"REAL_HOST":"{http.request.header.X-Forwarded-Host}","handler":"vars"}],"match":[{"header":{"X-Forwarded-Host":["*"]}}]},{"handle":[{"REAL_IP":"{http.request.header.Cf-Connecting-Ip}","handler":"vars"}],"match":[{"header":{"Cf-Connecting-Ip":["*"]}}]},{"handle":[{"handler":"headers","response":{"set":{"X-Served-By":["promtail"]}}},{"handler":"authentication","providers":{"authorizer":{"gatekeeper_name":"admins_policy","route_matcher":"*"}}}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"promtail:9080"}]}],"match":[{"header":{"Connection":["*Upgrade*"],"Upgrade":["websocket"]}}]},{"handle":[{"handler":"reverse_proxy","headers":{"request":{"set":{"Host":["{http.vars.REAL_HOST}"],"X-Real-Ip":["{http.vars.REAL_IP}"]}}},"upstreams":[{"dial":"promtail:9080"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"REAL_HOST":"{http.request.host}","handler":"vars"},{"REAL_IP":"{http.request.remote.host}","handler":"vars"}]},{"handle":[{"REAL_HOST":"{http.request.header.X-Forwarded-Host}","handler":"vars"}],"match":[{"header":{"X-Forwarded-Host":["*"]}}]},{"handle":[{"REAL_IP":"{http.request.header.Cf-Connecting-Ip}","handler":"vars"}],"match":[{"header":{"Cf-Connecting-Ip":["*"]}}]},{"handle":[{"handler":"headers","response":{"set":{"X-Served-By":["Alertmanager"]}}},{"handler":"authentication","providers":{"authorizer":{"gatekeeper_name":"admins_policy","route_matcher":"*"}}}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"alertmanager:9093"}]}],"match":[{"header":{"Connection":["*Upgrade*"],"Upgrade":["websocket"]}}]},{"handle":[{"handler":"reverse_proxy","headers":{"request":{"set":{"Host":["{http.vars.REAL_HOST}"],"X-Real-Ip":["{http.vars.REAL_IP}"]}}},"upstreams":[{"dial":"alertmanager:9093"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"REAL_HOST":"{http.request.host}","handler":"vars"},{"REAL_IP":"{http.request.remote.host}","handler":"vars"}]},{"handle":[{"REAL_HOST":"{http.request.header.X-Forwarded-Host}","handler":"vars"}],"match":[{"header":{"X-Forwarded-Host":["*"]}}]},{"handle":[{"REAL_IP":"{http.request.header.Cf-Connecting-Ip}","handler":"vars"}],"match":[{"header":{"Cf-Connecting-Ip":["*"]}}]},{"handle":[{"handler":"headers","response":{"set":{"X-Served-By":["Prometheus"]}}},{"handler":"authentication","providers":{"authorizer":{"gatekeeper_name":"admins_policy","route_matcher":"*"}}}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"prometheus:9090"}]}],"match":[{"header":{"Connection":["*Upgrade*"],"Upgrade":["websocket"]}}]},{"handle":[{"handler":"reverse_proxy","headers":{"request":{"set":{"Host":["{http.vars.REAL_HOST}"],"X-Real-Ip":["{http.vars.REAL_IP}"]}}},"upstreams":[{"dial":"prometheus:9090"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"REAL_HOST":"{http.request.host}","handler":"vars"},{"REAL_IP":"{http.request.remote.host}","handler":"vars"}]},{"handle":[{"REAL_HOST":"{http.request.header.X-Forwarded-Host}","handler":"vars"}],"match":[{"header":{"X-Forwarded-Host":["*"]}}]},{"handle":[{"REAL_IP":"{http.request.header.Cf-Connecting-Ip}","handler":"vars"}],"match":[{"header":{"Cf-Connecting-Ip":["*"]}}]},{"handle":[{"encodings":{"gzip":{}},"handler":"encode","prefer":["gzip"]}]},{"group":"group9","handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"vars","root":"/usr/share/caddy"},{"handler":"headers","response":{"set":{"X-Served-By":["Caddy"]}}},{"handler":"file_server","hide":["/etc/caddy/sites-enabled/www.caddyfile","/etc/caddy/snippets/snippets_main.caddyfile"]}]}]},{"handler":"subroute","routes":[{"handle":[{"body":"Not found","handler":"static_response","status_code":404}]}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{"prefer_wildcard":true},"trusted_proxies":{"ranges":["192.168.0.0/16","172.16.0.0/12","10.0.0.0/8","127.0.0.1/8","fd00::/8","::1"],"source":"static"},"client_ip_headers":["Cf-Connecting-Ip","X-Real-IP"],"logs":{"logger_names":{"admin.wnaji.dev":["log0"],"wnaji.dev":[""],"wnaji.local":[""]},"skip_hosts":["am.wnaji.dev","grafana.wnaji.dev","loki.wnaji.dev","pm.wnaji.dev","pmt.wnaji.dev"]}},"srv1":{"listen":[":80"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"abort":true,"handler":"static_response"}],"match":[{"not":[{"client_ip":{"ranges":["192.168.0.0/16","172.16.0.0/12","10.0.0.0/8","127.0.0.1/8","fd00::/8","::1"]}}]}]},{"handle":[{"handler":"metrics"}]}]}],"terminal":true},{},{}],"automatic_https":{"disable":true,"prefer_wildcard":true},"trusted_proxies":{"ranges":["192.168.0.0/16","172.16.0.0/12","10.0.0.0/8","127.0.0.1/8","fd00::/8","::1"],"source":"static"},"client_ip_headers":["Cf-Connecting-Ip","X-Real-IP"]}},"metrics":{}}}
{"level":"warn","ts":1735515098.6594896,"logger":"pki.ca.local","msg":"installing root certificate (you might be prompted for password)","path":"storage:pki/authorities/local/root.crt"}
{"level":"info","ts":1735515098.6597884,"msg":"warning: \"certutil\" is not available, install \"certutil\" with \"apt install libnss3-tools\" or \"yum install nss-tools\" and try again"}
{"level":"info","ts":1735515098.6598015,"msg":"define JAVA_HOME environment variable to use the Java trust"}
{"level":"info","ts":1735515098.6889987,"msg":"certificate installed properly in linux trusts"}
{"level":"debug","ts":1735515098.6891181,"logger":"security","msg":"started app instance","app":"security"}
{"level":"info","ts":1735515098.6891527,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1735515098.6901045,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 7168 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
{"level":"debug","ts":1735515098.690417,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":true}
{"level":"info","ts":1735515098.6904392,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"warn","ts":1735515098.6904752,"logger":"http","msg":"HTTP/3 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"debug","ts":1735515098.6905017,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
{"level":"warn","ts":1735515098.690506,"logger":"http","msg":"HTTP/2 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"info","ts":1735515098.6905122,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
{"level":"info","ts":1735515098.690524,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["pm.wnaji.dev","wnaji.dev","wnaji.local","grafana.wnaji.dev","admin.wnaji.dev","loki.wnaji.dev","pmt.wnaji.dev","am.wnaji.dev"]}
{"level":"info","ts":1735515098.691035,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1735515098.6910675,"msg":"serving initial configuration"}
{"level":"info","ts":1735515098.694189,"logger":"tls","msg":"cleaning storage unit","storage":"FileStorage:/data/caddy"}
{"level":"info","ts":1735515098.6943884,"logger":"tls.obtain","msg":"acquiring lock","identifier":"pm.wnaji.dev"}
{"level":"info","ts":1735515098.6964662,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1735515098.6978447,"logger":"tls.obtain","msg":"acquiring lock","identifier":"grafana.wnaji.dev"}
{"level":"info","ts":1735515098.6991196,"logger":"tls.obtain","msg":"lock acquired","identifier":"grafana.wnaji.dev"}
{"level":"info","ts":1735515098.6991835,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"grafana.wnaji.dev"}
{"level":"debug","ts":1735515098.6992366,"logger":"events","msg":"event","name":"cert_obtaining","id":"058ba20d-a047-41b7-b0c6-1192525e6161","origin":"tls","data":{"identifier":"grafana.wnaji.dev"}}
{"level":"debug","ts":1735515098.700849,"logger":"tls","msg":"created CSR","identifiers":["grafana.wnaji.dev"],"san_dns_names":["grafana.wnaji.dev"],"san_emails":[],"common_name":"","extra_extensions":0}
{"level":"debug","ts":1735515098.7010946,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"local"}
{"level":"info","ts":1735515098.7018552,"logger":"tls.obtain","msg":"lock acquired","identifier":"pm.wnaji.dev"}
{"level":"info","ts":1735515098.7020116,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"pm.wnaji.dev"}
{"level":"debug","ts":1735515098.7021255,"logger":"events","msg":"event","name":"cert_obtaining","id":"c889154b-dd90-4f09-a460-5530e0c1529c","origin":"tls","data":{"identifier":"pm.wnaji.dev"}}
{"level":"debug","ts":1735515098.7022774,"logger":"tls","msg":"created CSR","identifiers":["pm.wnaji.dev"],"san_dns_names":["pm.wnaji.dev"],"san_emails":[],"common_name":"","extra_extensions":0}
{"level":"debug","ts":1735515098.7028453,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"local"}
{"level":"debug","ts":1735515098.7039602,"logger":"pki.ca.local","msg":"using intermediate signer","serial":"682604251874200514516414899705486030998329637113","not_before":"2024-12-29 02:34:13 +0000 UTC","not_after":"2026-12-29 02:34:13 +0000 UTC"}
{"level":"info","ts":1735515098.7086887,"logger":"tls.obtain","msg":"acquiring lock","identifier":"admin.wnaji.dev"}
{"level":"info","ts":1735515098.7093925,"logger":"tls.obtain","msg":"acquiring lock","identifier":"am.wnaji.dev"}
{"level":"info","ts":1735515098.7096665,"logger":"tls.obtain","msg":"lock acquired","identifier":"admin.wnaji.dev"}
{"level":"info","ts":1735515098.712084,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"admin.wnaji.dev"}
{"level":"debug","ts":1735515098.7124054,"logger":"events","msg":"event","name":"cert_obtaining","id":"7c76954c-0a74-4adb-8e07-e71e0d8d36e2","origin":"tls","data":{"identifier":"admin.wnaji.dev"}}
{"level":"debug","ts":1735515098.713924,"logger":"tls","msg":"created CSR","identifiers":["admin.wnaji.dev"],"san_dns_names":["admin.wnaji.dev"],"san_emails":[],"common_name":"","extra_extensions":0}
{"level":"debug","ts":1735515098.7142751,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"local"}
{"level":"info","ts":1735515098.7145271,"logger":"tls.obtain","msg":"acquiring lock","identifier":"wnaji.dev"}
{"level":"info","ts":1735515098.7146885,"logger":"tls.obtain","msg":"acquiring lock","identifier":"pmt.wnaji.dev"}
{"level":"info","ts":1735515098.7152116,"logger":"tls.obtain","msg":"lock acquired","identifier":"wnaji.dev"}
{"level":"info","ts":1735515098.7152731,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"wnaji.dev"}
{"level":"debug","ts":1735515098.7152932,"logger":"events","msg":"event","name":"cert_obtaining","id":"9ae843bf-feca-45c4-a157-df28ebfd64a9","origin":"tls","data":{"identifier":"wnaji.dev"}}
{"level":"debug","ts":1735515098.7153718,"logger":"tls","msg":"created CSR","identifiers":["wnaji.dev"],"san_dns_names":["wnaji.dev"],"san_emails":[],"common_name":"","extra_extensions":0}
{"level":"debug","ts":1735515098.7154784,"logger":"pki.ca.local","msg":"using intermediate signer","serial":"682604251874200514516414899705486030998329637113","not_before":"2024-12-29 02:34:13 +0000 UTC","not_after":"2026-12-29 02:34:13 +0000 UTC"}
{"level":"info","ts":1735515098.7160797,"logger":"tls.obtain","msg":"lock acquired","identifier":"am.wnaji.dev"}
{"level":"info","ts":1735515098.7162423,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"am.wnaji.dev"}
{"level":"debug","ts":1735515098.7163312,"logger":"events","msg":"event","name":"cert_obtaining","id":"0421a4af-7646-44b9-964e-1e0b57632610","origin":"tls","data":{"identifier":"am.wnaji.dev"}}
{"level":"debug","ts":1735515098.7165008,"logger":"tls","msg":"created CSR","identifiers":["am.wnaji.dev"],"san_dns_names":["am.wnaji.dev"],"san_emails":[],"common_name":"","extra_extensions":0}
{"level":"debug","ts":1735515098.716824,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"local"}
{"level":"debug","ts":1735515098.7171764,"logger":"pki.ca.local","msg":"using intermediate signer","serial":"682604251874200514516414899705486030998329637113","not_before":"2024-12-29 02:34:13 +0000 UTC","not_after":"2026-12-29 02:34:13 +0000 UTC"}
{"level":"info","ts":1735515098.715971,"logger":"tls.obtain","msg":"acquiring lock","identifier":"loki.wnaji.dev"}
{"level":"info","ts":1735515098.7138557,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"grafana.wnaji.dev","issuer":"local"}
{"level":"debug","ts":1735515098.720829,"logger":"events","msg":"event","name":"cert_obtained","id":"92633ad1-64dd-4150-a652-bdeb92b504c7","origin":"tls","data":{"certificate_path":"certificates/local/grafana.wnaji.dev/grafana.wnaji.dev.crt","csr_pem":"###","identifier":"grafana.wnaji.dev","issuer":"local","metadata_path":"certificates/local/grafana.wnaji.dev/grafana.wnaji.dev.json","private_key_path":"certificates/local/grafana.wnaji.dev/grafana.wnaji.dev.key","renewal":false,"storage_path":"certificates/local/grafana.wnaji.dev"}}
{"level":"debug","ts":1735515098.7208693,"logger":"events","msg":"invoking subscribed handler","name":"cert_obtained","id":"92633ad1-64dd-4150-a652-bdeb92b504c7","origin":"tls","data":{"certificate_path":"certificates/local/grafana.wnaji.dev/grafana.wnaji.dev.crt","csr_pem":"###","identifier":"grafana.wnaji.dev","issuer":"local","metadata_path":"certificates/local/grafana.wnaji.dev/grafana.wnaji.dev.json","private_key_path":"certificates/local/grafana.wnaji.dev/grafana.wnaji.dev.key","renewal":false,"storage_path":"certificates/local/grafana.wnaji.dev"},"subscribed_to":"cert_obtained","handler":{"command":"sh","args":["-c","/scripts/cert_obtained.sh {event.data.certificate_path}"],"timeout":30000000000}}
{"level":"info","ts":1735515098.7209432,"logger":"tls.obtain","msg":"releasing lock","identifier":"grafana.wnaji.dev"}
{"level":"warn","ts":1735515098.7212646,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [grafana.wnaji.dev]: no OCSP server specified in certificate","identifiers":["grafana.wnaji.dev"]}
{"level":"debug","ts":1735515098.7212894,"logger":"tls.cache","msg":"added certificate to cache","subjects":["grafana.wnaji.dev"],"expiration":1735558299,"managed":true,"issuer_key":"local","hash":"fc294fe6beb57f5d3921d46190b4665bff035e475259418f16c33cbbae781702","cache_size":1,"cache_capacity":10000}
{"level":"debug","ts":1735515098.7213044,"logger":"events","msg":"event","name":"cached_managed_cert","id":"1d276a0a-6140-4c68-b9d1-ee7f0977bdd0","origin":"tls","data":{"sans":["grafana.wnaji.dev"]}}
{"level":"debug","ts":1735515098.7155623,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"local"}
{"level":"debug","ts":1735515098.7221806,"logger":"pki.ca.local","msg":"using intermediate signer","serial":"682604251874200514516414899705486030998329637113","not_before":"2024-12-29 02:34:13 +0000 UTC","not_after":"2026-12-29 02:34:13 +0000 UTC"}
{"level":"info","ts":1735515098.7138119,"logger":"tls.obtain","msg":"acquiring lock","identifier":"wnaji.local"}
{"level":"debug","ts":1735515098.715853,"logger":"pki.ca.local","msg":"using intermediate signer","serial":"682604251874200514516414899705486030998329637113","not_before":"2024-12-29 02:34:13 +0000 UTC","not_after":"2026-12-29 02:34:13 +0000 UTC"}
{"level":"info","ts":1735515098.7241318,"logger":"tls.obtain","msg":"lock acquired","identifier":"pmt.wnaji.dev"}
{"level":"info","ts":1735515098.729216,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"pmt.wnaji.dev"}
{"level":"debug","ts":1735515098.7297223,"logger":"events","msg":"event","name":"cert_obtaining","id":"480a5e42-c341-4d82-ae3b-f89e34774d13","origin":"tls","data":{"identifier":"pmt.wnaji.dev"}}
{"level":"debug","ts":1735515098.7300532,"logger":"tls","msg":"created CSR","identifiers":["pmt.wnaji.dev"],"san_dns_names":["pmt.wnaji.dev"],"san_emails":[],"common_name":"","extra_extensions":0}
{"level":"debug","ts":1735515098.7307122,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"local"}
{"level":"debug","ts":1735515098.7311044,"logger":"pki.ca.local","msg":"using intermediate signer","serial":"682604251874200514516414899705486030998329637113","not_before":"2024-12-29 02:34:13 +0000 UTC","not_after":"2026-12-29 02:34:13 +0000 UTC"}
{"level":"info","ts":1735515098.732996,"logger":"tls.obtain","msg":"lock acquired","identifier":"wnaji.local"}
{"level":"info","ts":1735515098.7332463,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"wnaji.local"}
{"level":"debug","ts":1735515098.7333398,"logger":"events","msg":"event","name":"cert_obtaining","id":"84e9ea64-4912-458c-8894-3c25d75ba2cc","origin":"tls","data":{"identifier":"wnaji.local"}}
{"level":"debug","ts":1735515098.7335832,"logger":"tls","msg":"created CSR","identifiers":["wnaji.local"],"san_dns_names":["wnaji.local"],"san_emails":[],"common_name":"","extra_extensions":0}
{"level":"debug","ts":1735515098.7348685,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"local"}
{"level":"debug","ts":1735515098.7364373,"logger":"pki.ca.local","msg":"using intermediate signer","serial":"682604251874200514516414899705486030998329637113","not_before":"2024-12-29 02:34:13 +0000 UTC","not_after":"2026-12-29 02:34:13 +0000 UTC"}
{"level":"info","ts":1735515098.7369153,"logger":"tls.obtain","msg":"lock acquired","identifier":"loki.wnaji.dev"}
{"level":"info","ts":1735515098.737366,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"loki.wnaji.dev"}
{"level":"debug","ts":1735515098.7376676,"logger":"events","msg":"event","name":"cert_obtaining","id":"0915fd95-f989-44ad-8398-c0bde772ee0f","origin":"tls","data":{"identifier":"loki.wnaji.dev"}}
{"level":"debug","ts":1735515098.7381551,"logger":"tls","msg":"created CSR","identifiers":["loki.wnaji.dev"],"san_dns_names":["loki.wnaji.dev"],"san_emails":[],"common_name":"","extra_extensions":0}
{"level":"debug","ts":1735515098.7390196,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"local"}
{"level":"debug","ts":1735515098.7397146,"logger":"pki.ca.local","msg":"using intermediate signer","serial":"682604251874200514516414899705486030998329637113","not_before":"2024-12-29 02:34:13 +0000 UTC","not_after":"2026-12-29 02:34:13 +0000 UTC"}
{"level":"info","ts":1735515098.7434256,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"admin.wnaji.dev","issuer":"local"}
{"level":"debug","ts":1735515098.7436337,"logger":"events","msg":"event","name":"cert_obtained","id":"f90d4b74-9175-4c31-bd66-1115527a8dc2","origin":"tls","data":{"certificate_path":"certificates/local/admin.wnaji.dev/admin.wnaji.dev.crt","csr_pem":"###","identifier":"admin.wnaji.dev","issuer":"local","metadata_path":"certificates/local/admin.wnaji.dev/admin.wnaji.dev.json","private_key_path":"certificates/local/admin.wnaji.dev/admin.wnaji.dev.key","renewal":false,"storage_path":"certificates/local/admin.wnaji.dev"}}
{"level":"debug","ts":1735515098.7437687,"logger":"events","msg":"invoking subscribed handler","name":"cert_obtained","id":"f90d4b74-9175-4c31-bd66-1115527a8dc2","origin":"tls","data":{"certificate_path":"certificates/local/admin.wnaji.dev/admin.wnaji.dev.crt","csr_pem":"###","identifier":"admin.wnaji.dev","issuer":"local","metadata_path":"certificates/local/admin.wnaji.dev/admin.wnaji.dev.json","private_key_path":"certificates/local/admin.wnaji.dev/admin.wnaji.dev.key","renewal":false,"storage_path":"certificates/local/admin.wnaji.dev"},"subscribed_to":"cert_obtained","handler":{"command":"sh","args":["-c","/scripts/cert_obtained.sh {event.data.certificate_path}"],"timeout":30000000000}}
{"level":"info","ts":1735515098.7439406,"logger":"tls.obtain","msg":"releasing lock","identifier":"admin.wnaji.dev"}
{"level":"info","ts":1735515098.7379575,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"am.wnaji.dev","issuer":"local"}
{"level":"debug","ts":1735515098.7502737,"logger":"events","msg":"event","name":"cert_obtained","id":"727d6db0-531a-4cda-89d0-9884cdd46d75","origin":"tls","data":{"certificate_path":"certificates/local/am.wnaji.dev/am.wnaji.dev.crt","csr_pem":"###","identifier":"am.wnaji.dev","issuer":"local","metadata_path":"certificates/local/am.wnaji.dev/am.wnaji.dev.json","private_key_path":"certificates/local/am.wnaji.dev/am.wnaji.dev.key","renewal":false,"storage_path":"certificates/local/am.wnaji.dev"}}
{"level":"debug","ts":1735515098.750474,"logger":"events","msg":"invoking subscribed handler","name":"cert_obtained","id":"727d6db0-531a-4cda-89d0-9884cdd46d75","origin":"tls","data":{"certificate_path":"certificates/local/am.wnaji.dev/am.wnaji.dev.crt","csr_pem":"###","identifier":"am.wnaji.dev","issuer":"local","metadata_path":"certificates/local/am.wnaji.dev/am.wnaji.dev.json","private_key_path":"certificates/local/am.wnaji.dev/am.wnaji.dev.key","renewal":false,"storage_path":"certificates/local/am.wnaji.dev"},"subscribed_to":"cert_obtained","handler":{"command":"sh","args":["-c","/scripts/cert_obtained.sh {event.data.certificate_path}"],"timeout":30000000000}}
{"level":"info","ts":1735515098.750621,"logger":"tls.obtain","msg":"releasing lock","identifier":"am.wnaji.dev"}
{"level":"warn","ts":1735515098.751374,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [am.wnaji.dev]: no OCSP server specified in certificate","identifiers":["am.wnaji.dev"]}
{"level":"debug","ts":1735515098.7515595,"logger":"tls.cache","msg":"added certificate to cache","subjects":["am.wnaji.dev"],"expiration":1735558299,"managed":true,"issuer_key":"local","hash":"ce6423a991d66d90934d59725ae06a0c63e4637cbc831fd9b8203510d4a434d4","cache_size":2,"cache_capacity":10000}
{"level":"debug","ts":1735515098.7517345,"logger":"events","msg":"event","name":"cached_managed_cert","id":"fcf2de67-68b5-4e9c-9ba2-d8e94f6cecea","origin":"tls","data":{"sans":["am.wnaji.dev"]}}
{"level":"info","ts":1735515098.7520258,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"loki.wnaji.dev","issuer":"local"}
{"level":"debug","ts":1735515098.7522721,"logger":"events","msg":"event","name":"cert_obtained","id":"4af08d30-1cc2-4b43-b58a-322cf9fb45d1","origin":"tls","data":{"certificate_path":"certificates/local/loki.wnaji.dev/loki.wnaji.dev.crt","csr_pem":"###","identifier":"loki.wnaji.dev","issuer":"local","metadata_path":"certificates/local/loki.wnaji.dev/loki.wnaji.dev.json","private_key_path":"certificates/local/loki.wnaji.dev/loki.wnaji.dev.key","renewal":false,"storage_path":"certificates/local/loki.wnaji.dev"}}
{"level":"debug","ts":1735515098.7523887,"logger":"events","msg":"invoking subscribed handler","name":"cert_obtained","id":"4af08d30-1cc2-4b43-b58a-322cf9fb45d1","origin":"tls","data":{"certificate_path":"certificates/local/loki.wnaji.dev/loki.wnaji.dev.crt","csr_pem":"###","identifier":"loki.wnaji.dev","issuer":"local","metadata_path":"certificates/local/loki.wnaji.dev/loki.wnaji.dev.json","private_key_path":"certificates/local/loki.wnaji.dev/loki.wnaji.dev.key","renewal":false,"storage_path":"certificates/local/loki.wnaji.dev"},"subscribed_to":"cert_obtained","handler":{"command":"sh","args":["-c","/scripts/cert_obtained.sh {event.data.certificate_path}"],"timeout":30000000000}}
{"level":"info","ts":1735515098.752579,"logger":"tls.obtain","msg":"releasing lock","identifier":"loki.wnaji.dev"}
{"level":"warn","ts":1735515098.7529848,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [loki.wnaji.dev]: no OCSP server specified in certificate","identifiers":["loki.wnaji.dev"]}
{"level":"debug","ts":1735515098.7534316,"logger":"tls.cache","msg":"added certificate to cache","subjects":["loki.wnaji.dev"],"expiration":1735558299,"managed":true,"issuer_key":"local","hash":"a0d97004b60e9e9b438851375072a8bc376085f867ff18dc9fae25f8752e7fd1","cache_size":3,"cache_capacity":10000}
{"level":"debug","ts":1735515098.7535474,"logger":"events","msg":"event","name":"cached_managed_cert","id":"5c72caa7-46b8-4fe5-a3fd-1ead9c611d60","origin":"tls","data":{"sans":["loki.wnaji.dev"]}}
{"level":"warn","ts":1735515098.7501154,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [admin.wnaji.dev]: no OCSP server specified in certificate","identifiers":["admin.wnaji.dev"]}
{"level":"debug","ts":1735515098.7537384,"logger":"tls.cache","msg":"added certificate to cache","subjects":["admin.wnaji.dev"],"expiration":1735558299,"managed":true,"issuer_key":"local","hash":"1d647578f39d34e9cc882d90885d9ea22fd75a40746a1706c2d5c834dbf7e263","cache_size":4,"cache_capacity":10000}
{"level":"debug","ts":1735515098.753839,"logger":"events","msg":"event","name":"cached_managed_cert","id":"ef088575-51e7-4df8-9069-3734c3afc81b","origin":"tls","data":{"sans":["admin.wnaji.dev"]}}
{"level":"info","ts":1735515098.7492619,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"wnaji.dev","issuer":"local"}
{"level":"debug","ts":1735515098.755704,"logger":"events","msg":"event","name":"cert_obtained","id":"ee815a16-1ec1-40b1-bce9-4ab3f9bfd451","origin":"tls","data":{"certificate_path":"certificates/local/wnaji.dev/wnaji.dev.crt","csr_pem":"###","identifier":"wnaji.dev","issuer":"local","metadata_path":"certificates/local/wnaji.dev/wnaji.dev.json","private_key_path":"certificates/local/wnaji.dev/wnaji.dev.key","renewal":false,"storage_path":"certificates/local/wnaji.dev"}}
{"level":"debug","ts":1735515098.7559724,"logger":"events","msg":"invoking subscribed handler","name":"cert_obtained","id":"ee815a16-1ec1-40b1-bce9-4ab3f9bfd451","origin":"tls","data":{"certificate_path":"certificates/local/wnaji.dev/wnaji.dev.crt","csr_pem":"###","identifier":"wnaji.dev","issuer":"local","metadata_path":"certificates/local/wnaji.dev/wnaji.dev.json","private_key_path":"certificates/local/wnaji.dev/wnaji.dev.key","renewal":false,"storage_path":"certificates/local/wnaji.dev"},"subscribed_to":"cert_obtained","handler":{"command":"sh","args":["-c","/scripts/cert_obtained.sh {event.data.certificate_path}"],"timeout":30000000000}}
{"level":"info","ts":1735515098.756312,"logger":"tls.obtain","msg":"releasing lock","identifier":"wnaji.dev"}
{"level":"warn","ts":1735515098.7569404,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [wnaji.dev]: no OCSP server specified in certificate","identifiers":["wnaji.dev"]}
{"level":"debug","ts":1735515098.7571466,"logger":"tls.cache","msg":"added certificate to cache","subjects":["wnaji.dev"],"expiration":1735558299,"managed":true,"issuer_key":"local","hash":"f2f69f2a69dd9848eb2b0a53c53f98c14a4f7d78d8644f043bddacbba60c03c5","cache_size":5,"cache_capacity":10000}
{"level":"debug","ts":1735515098.7573564,"logger":"events","msg":"event","name":"cached_managed_cert","id":"068b68b0-63a5-4774-9407-4dd9f68ea4e7","origin":"tls","data":{"sans":["wnaji.dev"]}}
{"level":"info","ts":1735515098.759778,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"pm.wnaji.dev","issuer":"local"}
{"level":"debug","ts":1735515098.7600188,"logger":"events","msg":"event","name":"cert_obtained","id":"8451f5c4-76b8-4c75-b095-ec6933c62a16","origin":"tls","data":{"certificate_path":"certificates/local/pm.wnaji.dev/pm.wnaji.dev.crt","csr_pem":"###","identifier":"pm.wnaji.dev","issuer":"local","metadata_path":"certificates/local/pm.wnaji.dev/pm.wnaji.dev.json","private_key_path":"certificates/local/pm.wnaji.dev/pm.wnaji.dev.key","renewal":false,"storage_path":"certificates/local/pm.wnaji.dev"}}
{"level":"debug","ts":1735515098.7601745,"logger":"events","msg":"invoking subscribed handler","name":"cert_obtained","id":"8451f5c4-76b8-4c75-b095-ec6933c62a16","origin":"tls","data":{"certificate_path":"certificates/local/pm.wnaji.dev/pm.wnaji.dev.crt","csr_pem":"###","identifier":"pm.wnaji.dev","issuer":"local","metadata_path":"certificates/local/pm.wnaji.dev/pm.wnaji.dev.json","private_key_path":"certificates/local/pm.wnaji.dev/pm.wnaji.dev.key","renewal":false,"storage_path":"certificates/local/pm.wnaji.dev"},"subscribed_to":"cert_obtained","handler":{"command":"sh","args":["-c","/scripts/cert_obtained.sh {event.data.certificate_path}"],"timeout":30000000000}}
{"level":"info","ts":1735515098.7602973,"logger":"tls.obtain","msg":"releasing lock","identifier":"pm.wnaji.dev"}
{"level":"warn","ts":1735515098.7608335,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [pm.wnaji.dev]: no OCSP server specified in certificate","identifiers":["pm.wnaji.dev"]}
{"level":"debug","ts":1735515098.761933,"logger":"tls.cache","msg":"added certificate to cache","subjects":["pm.wnaji.dev"],"expiration":1735558299,"managed":true,"issuer_key":"local","hash":"1d915c9537d53be87f8e6d0ee7045fe8ac19c03e1f74a96c9cd0296558462457","cache_size":6,"cache_capacity":10000}
{"level":"debug","ts":1735515098.7620733,"logger":"events","msg":"event","name":"cached_managed_cert","id":"eb049d6c-d25e-4d3e-86b0-8af10b4cb72a","origin":"tls","data":{"sans":["pm.wnaji.dev"]}}
{"level":"info","ts":1735515098.762227,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"wnaji.local","issuer":"local"}
{"level":"debug","ts":1735515098.7624822,"logger":"events","msg":"event","name":"cert_obtained","id":"73208226-52a4-4fa7-b599-3de069a6d425","origin":"tls","data":{"certificate_path":"certificates/local/wnaji.local/wnaji.local.crt","csr_pem":"###","identifier":"wnaji.local","issuer":"local","metadata_path":"certificates/local/wnaji.local/wnaji.local.json","private_key_path":"certificates/local/wnaji.local/wnaji.local.key","renewal":false,"storage_path":"certificates/local/wnaji.local"}}
{"level":"debug","ts":1735515098.7625778,"logger":"events","msg":"invoking subscribed handler","name":"cert_obtained","id":"73208226-52a4-4fa7-b599-3de069a6d425","origin":"tls","data":{"certificate_path":"certificates/local/wnaji.local/wnaji.local.crt","csr_pem":"###","identifier":"wnaji.local","issuer":"local","metadata_path":"certificates/local/wnaji.local/wnaji.local.json","private_key_path":"certificates/local/wnaji.local/wnaji.local.key","renewal":false,"storage_path":"certificates/local/wnaji.local"},"subscribed_to":"cert_obtained","handler":{"command":"sh","args":["-c","/scripts/cert_obtained.sh {event.data.certificate_path}"],"timeout":30000000000}}
{"level":"info","ts":1735515098.7626753,"logger":"tls.obtain","msg":"releasing lock","identifier":"wnaji.local"}
{"level":"warn","ts":1735515098.76309,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [wnaji.local]: no OCSP server specified in certificate","identifiers":["wnaji.local"]}
{"level":"debug","ts":1735515098.7632318,"logger":"tls.cache","msg":"added certificate to cache","subjects":["wnaji.local"],"expiration":1735558299,"managed":true,"issuer_key":"local","hash":"0b9d078f048b54c9611b362caa90408412003a3e08e5fac128ea7caa586db879","cache_size":7,"cache_capacity":10000}
{"level":"debug","ts":1735515098.7633188,"logger":"events","msg":"event","name":"cached_managed_cert","id":"d5cd19ad-592f-488f-a717-cfa8e9f3505f","origin":"tls","data":{"sans":["wnaji.local"]}}
{"level":"info","ts":1735515098.7650416,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"pmt.wnaji.dev","issuer":"local"}
{"level":"debug","ts":1735515098.765271,"logger":"events","msg":"event","name":"cert_obtained","id":"661771ba-692d-4d74-b48d-419d62cbf2a0","origin":"tls","data":{"certificate_path":"certificates/local/pmt.wnaji.dev/pmt.wnaji.dev.crt","csr_pem":"###","identifier":"pmt.wnaji.dev","issuer":"local","metadata_path":"certificates/local/pmt.wnaji.dev/pmt.wnaji.dev.json","private_key_path":"certificates/local/pmt.wnaji.dev/pmt.wnaji.dev.key","renewal":false,"storage_path":"certificates/local/pmt.wnaji.dev"}}
{"level":"debug","ts":1735515098.7653368,"logger":"events","msg":"invoking subscribed handler","name":"cert_obtained","id":"661771ba-692d-4d74-b48d-419d62cbf2a0","origin":"tls","data":{"certificate_path":"certificates/local/pmt.wnaji.dev/pmt.wnaji.dev.crt","csr_pem":"###","identifier":"pmt.wnaji.dev","issuer":"local","metadata_path":"certificates/local/pmt.wnaji.dev/pmt.wnaji.dev.json","private_key_path":"certificates/local/pmt.wnaji.dev/pmt.wnaji.dev.key","renewal":false,"storage_path":"certificates/local/pmt.wnaji.dev"},"subscribed_to":"cert_obtained","handler":{"command":"sh","args":["-c","/scripts/cert_obtained.sh {event.data.certificate_path}"],"timeout":30000000000}}
{"level":"info","ts":1735515098.7654548,"logger":"tls.obtain","msg":"releasing lock","identifier":"pmt.wnaji.dev"}
{"level":"warn","ts":1735515098.765855,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [pmt.wnaji.dev]: no OCSP server specified in certificate","identifiers":["pmt.wnaji.dev"]}
{"level":"debug","ts":1735515098.765995,"logger":"tls.cache","msg":"added certificate to cache","subjects":["pmt.wnaji.dev"],"expiration":1735558299,"managed":true,"issuer_key":"local","hash":"6065d72c51f0165ff2ca1a279c854fdc3bcc96dfa7831bf4b8851eb5f276a6bd","cache_size":8,"cache_capacity":10000}
{"level":"debug","ts":1735515098.7661095,"logger":"events","msg":"event","name":"cached_managed_cert","id":"9eafad78-c9ce-4a7a-bd0e-09a61db937a8","origin":"tls","data":{"sans":["pmt.wnaji.dev"]}}
{"level":"info","ts":1735515103.862306,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1735515103.8697217,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"warn","ts":1735515103.869749,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":1}
{"level":"info","ts":1735515103.8715878,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_ip":"127.0.0.1","remote_port":"56564","headers":{"Accept-Encoding":["gzip"],"Cache-Control":["must-revalidate"],"Content-Length":["10752"],"Content-Type":["application/json"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
{"level":"info","ts":1735515103.8743622,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//[::1]:2019","//127.0.0.1:2019","//localhost:2019"]}
{"level":"info","ts":1735515103.8755226,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1735515103.8756557,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"warn","ts":1735515103.8756828,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv1","http_port":80}
{"level":"debug","ts":1735515103.8757353,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{"subjects":["wnaji.local"]},{}]}},"http":{"servers":{"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"REAL_HOST":"{http.request.host}","handler":"vars"},{"REAL_IP":"{http.request.remote.host}","handler":"vars"}]},{"handle":[{"REAL_HOST":"{http.request.header.X-Forwarded-Host}","handler":"vars"}],"match":[{"header":{"X-Forwarded-Host":["*"]}}]},{"handle":[{"REAL_IP":"{http.request.header.Cf-Connecting-Ip}","handler":"vars"}],"match":[{"header":{"Cf-Connecting-Ip":["*"]}}]},{"handle":[{"handler":"headers","response":{"set":{"X-Served-By":["Grafana"]}}},{"handler":"authentication","providers":{"authorizer":{"gatekeeper_name":"admins_policy","route_matcher":"*"}}}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"grafana:3000"}]}],"match":[{"header":{"Connection":["*Upgrade*"],"Upgrade":["websocket"]}}]},{"handle":[{"handler":"reverse_proxy","headers":{"request":{"set":{"Host":["{http.vars.REAL_HOST}"],"X-Real-Ip":["{http.vars.REAL_IP}"]}}},"upstreams":[{"dial":"grafana:3000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"authenticator","portal_name":"admin_portal","route_matcher":"*"}]}]}],"match":[{"path":["*"]}]}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"REAL_HOST":"{http.request.host}","handler":"vars"},{"REAL_IP":"{http.request.remote.host}","handler":"vars"}]},{"handle":[{"REAL_HOST":"{http.request.header.X-Forwarded-Host}","handler":"vars"}],"match":[{"header":{"X-Forwarded-Host":["*"]}}]},{"handle":[{"REAL_IP":"{http.request.header.Cf-Connecting-Ip}","handler":"vars"}],"match":[{"header":{"Cf-Connecting-Ip":["*"]}}]},{"handle":[{"handler":"headers","response":{"set":{"X-Served-By":["Loki"]}}},{"handler":"authentication","providers":{"authorizer":{"gatekeeper_name":"admins_policy","route_matcher":"*"}}}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"loki:3100"}]}],"match":[{"header":{"Connection":["*Upgrade*"],"Upgrade":["websocket"]}}]},{"handle":[{"handler":"reverse_proxy","headers":{"request":{"set":{"Host":["{http.vars.REAL_HOST}"],"X-Real-Ip":["{http.vars.REAL_IP}"]}}},"upstreams":[{"dial":"loki:3100"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"REAL_HOST":"{http.request.host}","handler":"vars"},{"REAL_IP":"{http.request.remote.host}","handler":"vars"}]},{"handle":[{"REAL_HOST":"{http.request.header.X-Forwarded-Host}","handler":"vars"}],"match":[{"header":{"X-Forwarded-Host":["*"]}}]},{"handle":[{"REAL_IP":"{http.request.header.Cf-Connecting-Ip}","handler":"vars"}],"match":[{"header":{"Cf-Connecting-Ip":["*"]}}]},{"handle":[{"handler":"headers","response":{"set":{"X-Served-By":["promtail"]}}},{"handler":"authentication","providers":{"authorizer":{"gatekeeper_name":"admins_policy","route_matcher":"*"}}}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"promtail:9080"}]}],"match":[{"header":{"Connection":["*Upgrade*"],"Upgrade":["websocket"]}}]},{"handle":[{"handler":"reverse_proxy","headers":{"request":{"set":{"Host":["{http.vars.REAL_HOST}"],"X-Real-Ip":["{http.vars.REAL_IP}"]}}},"upstreams":[{"dial":"promtail:9080"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"REAL_HOST":"{http.request.host}","handler":"vars"},{"REAL_IP":"{http.request.remote.host}","handler":"vars"}]},{"handle":[{"REAL_HOST":"{http.request.header.X-Forwarded-Host}","handler":"vars"}],"match":[{"header":{"X-Forwarded-Host":["*"]}}]},{"handle":[{"REAL_IP":"{http.request.header.Cf-Connecting-Ip}","handler":"vars"}],"match":[{"header":{"Cf-Connecting-Ip":["*"]}}]},{"handle":[{"handler":"headers","response":{"set":{"X-Served-By":["Alertmanager"]}}},{"handler":"authentication","providers":{"authorizer":{"gatekeeper_name":"admins_policy","route_matcher":"*"}}}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"alertmanager:9093"}]}],"match":[{"header":{"Connection":["*Upgrade*"],"Upgrade":["websocket"]}}]},{"handle":[{"handler":"reverse_proxy","headers":{"request":{"set":{"Host":["{http.vars.REAL_HOST}"],"X-Real-Ip":["{http.vars.REAL_IP}"]}}},"upstreams":[{"dial":"alertmanager:9093"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"REAL_HOST":"{http.request.host}","handler":"vars"},{"REAL_IP":"{http.request.remote.host}","handler":"vars"}]},{"handle":[{"REAL_HOST":"{http.request.header.X-Forwarded-Host}","handler":"vars"}],"match":[{"header":{"X-Forwarded-Host":["*"]}}]},{"handle":[{"REAL_IP":"{http.request.header.Cf-Connecting-Ip}","handler":"vars"}],"match":[{"header":{"Cf-Connecting-Ip":["*"]}}]},{"handle":[{"handler":"headers","response":{"set":{"X-Served-By":["Prometheus"]}}},{"handler":"authentication","providers":{"authorizer":{"gatekeeper_name":"admins_policy","route_matcher":"*"}}}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"prometheus:9090"}]}],"match":[{"header":{"Connection":["*Upgrade*"],"Upgrade":["websocket"]}}]},{"handle":[{"handler":"reverse_proxy","headers":{"request":{"set":{"Host":["{http.vars.REAL_HOST}"],"X-Real-Ip":["{http.vars.REAL_IP}"]}}},"upstreams":[{"dial":"prometheus:9090"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"REAL_HOST":"{http.request.host}","handler":"vars"},{"REAL_IP":"{http.request.remote.host}","handler":"vars"}]},{"handle":[{"REAL_HOST":"{http.request.header.X-Forwarded-Host}","handler":"vars"}],"match":[{"header":{"X-Forwarded-Host":["*"]}}]},{"handle":[{"REAL_IP":"{http.request.header.Cf-Connecting-Ip}","handler":"vars"}],"match":[{"header":{"Cf-Connecting-Ip":["*"]}}]},{"handle":[{"encodings":{"gzip":{}},"handler":"encode","prefer":["gzip"]}]},{"group":"group9","handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"vars","root":"/usr/share/caddy"},{"handler":"headers","response":{"set":{"X-Served-By":["Caddy"]}}},{"handler":"file_server","hide":["/etc/caddy/sites-enabled/www.caddyfile","/etc/caddy/snippets/snippets_main.caddyfile"]}]}]},{"handler":"subroute","routes":[{"handle":[{"body":"Not found","handler":"static_response","status_code":404}]}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{"prefer_wildcard":true},"trusted_proxies":{"ranges":["192.168.0.0/16","172.16.0.0/12","10.0.0.0/8","127.0.0.1/8","fd00::/8","::1"],"source":"static"},"client_ip_headers":["Cf-Connecting-Ip","X-Real-IP"],"logs":{"logger_names":{"admin.wnaji.dev":["log0"],"wnaji.dev":[""],"wnaji.local":[""]},"skip_hosts":["am.wnaji.dev","grafana.wnaji.dev","loki.wnaji.dev","pm.wnaji.dev","pmt.wnaji.dev"]}},"srv1":{"listen":[":80"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"abort":true,"handler":"static_response"}],"match":[{"not":[{"client_ip":{"ranges":["192.168.0.0/16","172.16.0.0/12","10.0.0.0/8","127.0.0.1/8","fd00::/8","::1"]}}]}]},{"handle":[{"handler":"metrics"}]}]}],"terminal":true},{},{}],"automatic_https":{"disable":true,"prefer_wildcard":true},"trusted_proxies":{"ranges":["192.168.0.0/16","172.16.0.0/12","10.0.0.0/8","127.0.0.1/8","fd00::/8","::1"],"source":"static"},"client_ip_headers":["Cf-Connecting-Ip","X-Real-IP"]}},"metrics":{}}}
{"level":"warn","ts":1735515103.9559255,"logger":"pki.ca.local","msg":"installing root certificate (you might be prompted for password)","path":"storage:pki/authorities/local/root.crt"}
{"level":"info","ts":1735515103.9563527,"msg":"warning: \"certutil\" is not available, install \"certutil\" with \"apt install libnss3-tools\" or \"yum install nss-tools\" and try again"}
{"level":"info","ts":1735515103.9563766,"msg":"define JAVA_HOME environment variable to use the Java trust"}
{"level":"info","ts":1735515104.0122855,"msg":"certificate installed properly in linux trusts"}
{"level":"debug","ts":1735515104.0124445,"logger":"security","msg":"started app instance","app":"security"}
{"level":"info","ts":1735515104.0124853,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"debug","ts":1735515104.013814,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":true}
{"level":"info","ts":1735515104.0138438,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"warn","ts":1735515104.0139952,"logger":"http","msg":"HTTP/3 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"debug","ts":1735515104.0140834,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
{"level":"warn","ts":1735515104.01412,"logger":"http","msg":"HTTP/2 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"info","ts":1735515104.0141284,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
{"level":"info","ts":1735515104.0141377,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["pm.wnaji.dev","wnaji.dev","wnaji.local","grafana.wnaji.dev","admin.wnaji.dev","loki.wnaji.dev","pmt.wnaji.dev","am.wnaji.dev"]}
{"level":"debug","ts":1735515104.0142326,"logger":"security","msg":"stopped app instance","app":"security"}
{"level":"info","ts":1735515104.0142446,"logger":"http","msg":"servers shutting down with eternal grace period"}
{"level":"info","ts":1735515104.0146883,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1735515104.0149457,"logger":"admin.api","msg":"load complete"}
{"level":"error","ts":1735515104.014911,"logger":"events.handlers.exec","msg":"background command failed","error":"signal: killed"}
{"level":"info","ts":1735515104.0193648,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
{"level":"debug","ts":1735515112.0454206,"logger":"events","msg":"event","name":"tls_get_certificate","id":"c8803fdd-e9b5-4585-8689-12c43d0ec380","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,49196,49200,159,52393,52392,52394,49195,49199,158,49188,49192,107,49187,49191,103,49162,49172,57,49161,49171,51,157,156,61,60,53,47],"ServerName":"wnaji.local","SupportedCurves":[29,23,30,25,24,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2074,2075,2076,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769,770,1026,1282,1538],"SupportedProtos":null,"SupportedVersions":[772,771],"RemoteAddr":{"IP":"185.106.*.*","Port":62822,"Zone":""},"LocalAddr":{"IP":"172.18.0.2","Port":443,"Zone":""}}}}
{"level":"debug","ts":1735515112.045781,"logger":"tls.handshake","msg":"choosing certificate","identifier":"wnaji.local","num_choices":1}
{"level":"debug","ts":1735515112.04579,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"wnaji.local","subjects":["wnaji.local"],"managed":true,"issuer_key":"local","hash":"0b9d078f048b54c9611b362caa90408412003a3e08e5fac128ea7caa586db879"}
{"level":"debug","ts":1735515112.0458148,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"185.106.*.*","remote_port":"62822","subjects":["wnaji.local"],"managed":true,"expiration":1735558299,"hash":"0b9d078f048b54c9611b362caa90408412003a3e08e5fac128ea7caa586db879"}
{"level":"info","ts":1735515122.5332406,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
{"level":"warn","ts":1735515122.5332956,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
{"level":"debug","ts":1735515122.5333157,"logger":"security","msg":"stopped app instance","app":"security"}
{"level":"info","ts":1735515122.5333645,"logger":"http","msg":"servers shutting down with eternal grace period"}
{"level":"info","ts":1735515122.5339742,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
{"level":"info","ts":1735515122.5339904,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
v2.9.0-beta.3 h1:tlqfbJMRNY6vnWwaQrnWrgS+wkDXr9GIFUD/P+HY9vA=
FROM caddy:2.9-builder-alpine AS builder
RUN xcaddy build \
--with github.com/greenpau/caddy-security@v1.1.29 \
--with github.com/caddyserver/cache-handler@v0.15.0 \
--with github.com/darkweak/storages/otter/caddy \
--with github.com/porech/caddy-maxmind-geolocation \
--with github.com/mholt/caddy-events-exec
FROM caddy:2.9-alpine
COPY --chown=root:root ./ca/ /data/myca/
COPY --chown=root:root --chmod=700 ./scripts/ /scripts/
RUN chmod +x -R /scripts
EXPOSE 80
EXPOSE 443
CMD ["caddy", "run", "--config", "/etc/caddy/Caddyfile"]
Docker version 27.4.0, build bde2b89
#!/bin/sh
CERT_PATH="/data/caddy/$1"
FULLCHAIN_PATH="/data/myca/fullchain.crt"
LAST_CHANGED_FP="/tmp/last_changed"
# Ensure required files exist
if [ ! -f "$CERT_PATH" ]; then
echo "Error: Certificate file $CERT_PATH does not exist."
exit 1
fi
if [ ! -f "$FULLCHAIN_PATH" ]; then
echo "Error: Fullchain file $FULLCHAIN_PATH does not exist."
exit 1
fi
# Backup current cert
cp "$CERT_PATH" "$CERT_PATH.bak" || {
echo "Error: Failed to back up $CERT_PATH."
exit 1
# Make fullchain
cat "$CERT_PATH.bak" "$FULLCHAIN_PATH" > "$CERT_PATH" || {
echo "Error: Failed to create fullchain at $CERT_PATH."
exit 1
# Record last changed file
echo "$CERT_PATH" > "$LAST_CHANGED_FP"
# Wait for 5 seconds to debounce reloads
sleep 5
# Check if this is still the last changed file
LAST_CHANGED=$(cat "$LAST_CHANGED_FP")
if [ "$LAST_CHANGED" = "$CERT_PATH" ]; then
# Reload Caddy
caddy reload --config "$CADDY_CONFIG" --force || {
echo "Error: Failed to reload Caddy."
exit 1
# Clean up
rm "$LAST_CHANGED_FP"
fi
- caddy
build: ./caddy
- 443:443
# - 2019:2019
- ./caddy/sites:/etc/caddy/sites-enabled
- ./caddy/snippets:/etc/caddy/snippets
- ./caddy/scripts:/scripts
# - caddy_data:/data
- caddy_logs:/logs
- geo_db:/geodb
- CADDY_CONFIG=/etc/caddy/Caddyfile
- CADDY_GLOBAL_CONFIG=${CADDY_GLOBAL_CONFIG}
- CADDY_JWT_SHARED_KEY=${CADDY_JWT_SHARED_KEY}
- CADDY_AUTH_USER=${CADDY_AUTH_USER}
- CADDY_AUTH_EMAIL=${CADDY_AUTH_EMAIL}
- CADDY_AUTH_PASSWORD=${CADDY_AUTH_PASSWORD}
My caddy file is broken up to multiple snippets and segments which is working fine. I will show the snippet related to PKI below. Otherwise everything is running ok
{$CADDY_GLOBAL_CONFIG}
# Enable metrics
metrics
servers {
trusted_proxies static private_ranges
client_ip_headers Cf-Connecting-Ip X-Real-IP
# Import other globals
import /etc/caddy/snippets/globals_*.caddyfile
globals_pki.caddyfile
pki {
ca {
intermediate {
cert /data/myca/caddy-root.crt
key /data/myca/caddy-root.key
# Enable local internal certificates
local_certs
auto_https prefer_wildcard
events {
on cert_obtained exec sh -c "/scripts/cert_obtained.sh {event.data.certificate_path}"
