Force caddy to re-issue certificate / clear cache
2.4.1
systemctl start caddy --config=/etc/caddy/config.json
Ubuntu 20.0.4
d. My complete Caddyfile or JSON config: I had to cut it short as the post size was being exceeded, my config is huge
    "storage": {
        "module": "s3",
        "host": "REMOVED",
        "bucket": "REMOVED",
        "access_key": "REMOVED",
        "secret_key": "REMOVED",
        "prefix": "",
        "redis_address": "REMOVED",
        "redis_password": "REMOVED",
        "redis_db": REMOVED
 "apps": {
        "http": {
            "servers": {
                "srv0": {
                    "listen": [
                        ":443"
                    "routes": [
**the below repeated 112 times for each subdomain**
                            "match": [
                                    "host": [
                                        "demo.staffconnect-app.com"
                            "handle": [
                                    "handler": "subroute",
                                    "routes": [
                                            "handle": [
                                                    "handler": "vars",
                                                    "root": "/var/www/staffconnect/app/fe/demo"
                                            "handle": [
                                                    "handler": "rewrite",
                                                    "uri": "{http.matchers.file.relative}"
                                            "match": [
                                                    "file": {
                                                        "try_files": [
                                                            "{http.request.uri.path}",
                                                            "{http.request.uri.path}/",
                                                            "/index.html"
                                            "handle": [
                                                    "encodings": {
                                                        "gzip": {}
                                                    "handler": "encode",
                                                    "prefer": [
                                                        "gzip"
                                            "handle": [
                                                    "routes": [
                                                            "handle": [
        "handler": "static_response",
        "headers": {
        "Location": [
        "status_code": 308
                                                            "match": [
        "file": {
        "try_files": [
        "{http.request.uri.path}/index.php"
        "not": [
        "path": [
                                                            "handle": [
                                                            "match": [
        "file": {
        "split_path": [
        ".php"
        "try_files": [
        "{http.request.uri.path}/index.php",
        "index.php"
                                                            "handle": [
        "handler": "reverse_proxy",
        "transport": {
        "protocol": "fastcgi",
        "split_path": [
        ".php"
        "upstreams": [
        "dial": "unix//run/php/php7.1-fpm.sock"
                                                            "match": [
        "path": [
        "*.php"
                                            "match": [
                                                    "path": [
                                                        "/showcase.php",
                                                        "/presentation.php"
                                            "handle": [
                                                    "handler": "file_server",
                                                    "hide": [
                                                        "/etc/caddy/Caddyfile"
                            "terminal": true
                    "tls_connection_policies": [
                            "match": {
                                "sni": [
                            "certificate_selection": {
                                "any_tag": [
                                    "cert97"
        "tls": {
            "certificates": {
                "load_files": [
                        "certificate": "/etc/letsencrypt/live/staffconnect-app.com/fullchain.pem",
                        "key": "/etc/letsencrypt/live/staffconnect-app.com/privkey.pem",
                        "tags": [
                            "cert97"
There are currently 112 subdomains of the form *.staffconnect-app.com being served by a wildcard SSL cert that was installed manually (tag: cert97)
I’d like to gradually have caddy takeover from the existing wildcard cert and generate an individual cert for each subdomain.
I want to do this gradually (under 50 per week) so as not to hit LetsEncrypt’s rate limits.
I assume that should I leave the current set up as is, eventually the wildcard ssl cert will expire and caddy will try to issue certs for all 112 subdomains simultaneously, hit the rate limit and fail.
I’ve tried deleting the corresponding tls_connection_policies object for a *.staffconnect-app.com sub domain eg I deleted the below from the above json config:
from “tls_connection_policies”: [
“match”: {
“sni”: [
brownformannewjersey.staffconnect-app.com
“certificate_selection”: {
“any_tag”: [
“cert97”
but after reloading and restarting caddy a new certificate for the subdomain is not generated - brownformannewjersey.staffconnect-app.com still uses the old wildcard ssl cert.
I’ve read a number of similar posts to this eg:
in the above Matt says not to just delete the certificate folders for live sites - which was what I was going to try next..
.. so I’m now at abit of a loss, any advice appreciated - how can I force caddy to ignore the cached wildcard ssl certificate and generate a certificate for an individual subdomain?
Side note: I tried to paste in my full caddy config.json file and besides exceeding this forum’s post size limit it was near impossible to continue writing in the text editor - I was getting a delay of about 40 seconds between typing on the keyboard and the text appearing on the screen.
Caddy supports both Let’s Encrypt and ZeroSSL, and will issue certificates as fast as it can. Let’s Encrypt rate limits would probably slow you down from doing this, but ZeroSSL has no rate limits. So Caddy should be able to get them all issued pretty quickly.
Is using the DNS challenge an option for that domain? If so then that would just be a single certificate to replace that one by getting a wildcard cert from LE/ZeroSSL.
I think what’s going on is that this {} at the end acts as a catch-all which ends up using one of the loaded certificates, i.e. your wildcard.
I think instead you’d have to configure the tls app to automate the certificates with the names you want (see Using Caddy to keep certificates renewed for some explanation of how to configure that) and add a new connection policy to match those domains, without requiring a tag (I think).
Thank you, I decided to test removing the entire tls_connection_policies block and the loaded wildcard ssl certificate. Caddy managed to obtain all certificates in about 4 minutes :smiley:
Nice point on the {} being a catch-all, this had me wondering.
Doing a DNS challenge is not an option at this stage as my DNS manager Zilore is not supported… they do have an api though so one day I’ll get around to trying it.
FWIW, you can use DNS challenge delegation to get around this. The duckdns plugin supports this:
