Nginx config
server {
proxy_max_temp_file_size 0;
fastcgi_buffers 32 8k;
client_max_body_size 500m;
client_body_buffer_size 1024k;
listen 80;
server_name admin.examples.com;
charset utf-8;
access_log /home/admin.examples.com.access.log main;
location ^~/graphql {
proxy_pass http://127.0.0.1:9002;
proxy_redirect off;
proxy_set_header Host $host;
location / {
proxy_pass http://127.0.0.1:7001;
proxy_redirect off;
proxy_set_header Host $http_host;
proxy_set_header X-NginX-Proxy true;
How do I write this configuration if I want to use a caddy ? Can someone help me with this problem? Thank you~
