First record does not look like a TLS handshake
Windows 8, running it from powerShell, installed with choco
xcaddy run
Not relevant here
# That's global config thingy
    # Without this, caddy binds to port 80, not the one stated for some reason
    auto_https disable_redirects
# Where we listen
https://:8443 {
    # I think this adds certificates?
    tls E:\patht\cert.pem E:\path\key.pem
    # Actual proxy
    reverse_proxy {
        # Where do we reroute, new endpoint/worker is entered after a space
        to https://localhost:8444
        # Load balancing policy, it's a custom one
        lb_policy ww3token
        # That's for certificates to work, but this works on dev
            tls_client_auth E:\path\cert.pem E:\path\key.pem
            tls tls_insecure_skip_verify
I get TLS handshake error when sending following request
curl -X post -v --insecure https://localhost:8443/authenticate/debug
Caddy error:
{"level":"error","ts":1649768326.5529923,"logger":"http.log.error","msg":"tls: first record does not look like a TLS handshake","request":{"remote_addr":"[::1]:56321","proto":"HTTP/2.0","method":"post","host":"localhost:8443","uri":"/authenticate/debug","headers":{"User-Agent":["curl/7.70.0"],"Accept":["*/*"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"localhost"}},"duration":0.0012266,"status":502,"err_id":"ent9um9km","err_trace":"reverseproxy.statusError (reverseproxy.go:886)"}
Curl log
$ curl -X post -v --insecure https://localhost:8443/authenticate/debug
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0*   Trying ::1:8443...
* Connected to localhost (::1) port 8443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*   CAfile: C:/Users/jniesyto/AppData/Local/Programs/Git/mingw64/ssl/certs/ca-bundle.crt
  CApath: none
} [5 bytes data]
} [512 bytes data]
{ [122 bytes data]
{ [15 bytes data]
{ [1451 bytes data]
{ [520 bytes data]
{ [36 bytes data]
} [1 bytes data]
} [36 bytes data]
*  subject: CN=example.org; C=US; ST=Virginia; L=Blacksburg; O=Test; OU=Test
*  start date: Mar 14 11:22:19 2022 GMT
*  expire date: Mar 14 11:22:19 2023 GMT
*  issuer: CN=example.org; C=US; ST=Virginia; L=Blacksburg; O=Test; OU=Test
*  SSL certificate verify result: self signed certificate (18), continuing anyway.
} [5 bytes data]
* Using Stream ID: 1 (easy handle 0xe61380)
} [5 bytes data]
> post /authenticate/debug HTTP/2
> Host: localhost:8443
> user-agent: curl/7.70.0
> accept: */*
{ [5 bytes data]
{ [130 bytes data]
} [5 bytes data]
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Tue, 12 Apr 2022 12:58:46 GMT
{ [0 bytes data]
As I’ve found on this forum, it could mean that client sends http request while server is expecting an https request. The problem is that as you can see in my curl, and caddy config, I do send https requests, and my server is made with node’s https library, so it does expect HTTPS. I’m at a loss now, don’t know where the issue is
Are you certain that’s the HTTPS port of your upstream app? Caddy doesn’t think so.
Well, turns out that some minor changes I’ve made broke the server, so it wasn’t listening
